Pass array arguments in terminal InDesignServer sampleclient
Participant ,
Sep 02, 2018 Sep 02, 2018
Hi all,
In terminal, the below command is working
/Users/user/Desktop/IDS_Sever/sampleclient -host localhost:18384 /Users/user/Desktop/Test/t.jsx myArg="/Users/user/Desktop/Test/"
In Jsx file, to retrieve
var nw = app.scriptArgs.get("myArg");   // get the value to nw
I want to pass array as arguments and It is not working.
/Users/user/Desktop/IDS_Sever/sampleclient -host localhost:18384 /Users/user/Desktop/Test/t.jsx myArg=["/Users/user/Desktop/Test/","/Users/user/Desktop/Test/sample.xml", "1", 5758, "45454"]
File(nw[0]).remove(); // get like this, Script result (xsd__boolean): false
Please give any helps!!
thanks,
John.
Scripting
773
Community Expert , Sep 03, 2018 Sep 03, 2018
I don't have an IDS installation handy but you could try the following. Seems the argument takes only string as value, so you need to convert the argument to array before using it. You can do that using two ways mentioned below
var arg = app.scriptArgs.get("myArg");
var argAsArray = eval(arg)
For the code above you would send your argument as "[1,2,3,4]". However i would not recommend this method as this has a possibility that eval can evaluate anything that is a valid javascript and could lead to
For the code above you would send your argument as "[1,2,3,4]". However i would not recommend this method as this has a possibility that eval can evaluate anything that is a valid javascript and could lead to issues if a malicious js snippet is sent in as an argument.
The second method is that you send in argument as a delimiter separated string which can then be split to obtain the array
var argAsArray = arg.split(",")  //if , is used as delimiter of the list
For the above code snippet the argument would be "1,2,3,4"
-Manan
Participant ,
Sep 09, 2018 Sep 09, 2018
Thank you for your valuable answer..
