7 Replies Latest reply on Sep 13, 2018 10:06 PM by hooplife
    Premiere CC 2018 Crashes every time
    hooplife Level 1
      I can't open the Premier CC 2018.  Crashes every time I open it.
        • 1. Re: Premiere CC 2018 Crashes every time
          Ann Bens Adobe Community Professional & MVP
          Might want to do what is says: read the crash report.
          • 2. Re: Premiere CC 2018 Crashes every time
            Vidya Sagar Adobe Employee
            Hi hooplife,
            Sorry for the trouble. As Ann Bens mentioned, we need crash report; share a screenshot with us. FAQ: How do I capture and post a screen shot or video?
            What are the system specs(OS version, RAM, GPU, CPU)? What is the version of Premiere Pro? FAQ: How to find the exact version of Premiere Pro you're using?
            Are there any third party plugins installed in the machine? Are you logged in as an Administrator?
            Vidya
            • 3. Re: Premiere CC 2018 Crashes every time
              hooplife Level 1
              Here is my system specs
              Below is the crash report
              Process:               Adobe Premiere Pro CC 2018 [621]
              Path:                  /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
              Identifier:            com.adobe.PremierePro.CC12
              Version:               12.1.2 (12.1.2)
              Code Type:             X86-64 (Native)
              Parent Process:        ??? [1]
              Responsible:           Adobe Premiere Pro CC 2018 [621]
              User ID:               501
              Date/Time:             2018-09-03 15:59:38.357 +0300
              OS Version:            Mac OS X 10.12.6 (16G1114)
              Report Version:        12
              Anonymous UUID:        7A86804E-6F42-4489-F0CC-E3686B0A4E70
              Sleep/Wake UUID:       521AA26C-6AB5-4692-B425-3896DCBDE07F
              Time Awake Since Boot: 1200 seconds
              Time Since Wake:       380 seconds
              System Integrity Protection: enabled
              Crashed Thread:        0  Dispatch queue: com.apple.main-thread
              Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
              Exception Codes:       0x0000000000000001, 0x0000000000000000
              Exception Note:        EXC_CORPSE_NOTIFY
              Termination Signal:    Illegal instruction: 4
              Termination Reason:    Namespace SIGNAL, Code 0x4
              Terminating Process:   exc handler [0]
              Application Specific Information:
              dyld: in dlopen()
              BUG IN LIBTRACE: MH not found
              Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
              0   libsystem_trace.dylib          0x00007fffa8e80e97 _os_trace_image_was_unloaded + 271
              1   dyld                          0x00000001049c6cb2 dyld::removeImage(ImageLoader*) + 343
              2   dyld                          0x00000001049ca6c7 dyld::garbageCollectImages() + 870
              3   dyld                          0x00000001049d254b dlopen + 907
              4   libdyld.dylib                  0x00007fffa8c4b832 dlopen + 59
              5   com.adobe.dvacore.framework    0x00000001001274e5 dvacore::config::lazyloader::LoadAndInitDependency(char const*) + 1605
              6   com.adobe.Mezzanine.framework 0x000000010f706ec9 MZ::(anonymous namespace)::FullInitializer::FullInitializer(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool, bool) + 12889
              7   com.adobe.Mezzanine.framework 0x000000010f703414 MZ::Initializer::Initializer(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool, bool) + 84
              8   com.adobe.Frontend.framework  0x00000001027e11e8 FE::(anonymous namespace)::FullInitializer::FullInitializer() + 1672
              9   com.adobe.Frontend.framework  0x00000001027e0ac5 FE::Initializer::Initializer() + 149
              10  com.adobe.Frontend.framework  0x0000000102822911 FE::AppMain(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 353
              11  com.adobe.Frontend.framework  0x00000001028240c3 FE::Run(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int) + 659
              12  com.adobe.PremierePro.CC12    0x0000000100007bc0 main + 896
              13  libdyld.dylib                  0x00007fffa8c4e235 start + 1
              Thread 1:
              0   libsystem_kernel.dylib        0x00007fffa8d7d44e __workq_kernreturn + 10
              1   libsystem_pthread.dylib        0x00007fffa8e67621 _pthread_wqthread + 1426
              2   libsystem_pthread.dylib        0x00007fffa8e6707d start_wqthread + 13
              Thread 2:
              1   libsystem_pthread.dylib        0x00007fffa8e6748e _pthread_wqthread + 1023
              Thread 3:
              Thread 4:: Dispatch queue: com.apple.root.default-qos
              0   libsystem_kernel.dylib        0x00007fffa8d7cc22 __psynch_mutexwait + 10
              1   libsystem_pthread.dylib        0x00007fffa8e67dfa _pthread_mutex_lock_wait + 100
              2   libsystem_pthread.dylib        0x00007fffa8e65519 _pthread_mutex_lock_slow + 285
              3   libdyld.dylib                  0x00007fffa8c4a118 dyldGlobalLockAcquire() + 16
              4   dyld                          0x00000001049d2230 dlopen + 112
              5   libdyld.dylib                  0x00007fffa8c4b832 dlopen + 59
              6   com.apple.CoreFoundation      0x00007fff934860b6 _CFBundleDlfcnCheckLoaded + 102
              7   com.apple.CoreFoundation      0x00007fff934ecf4e _CFBundleLoadExecutableAndReturnError + 318
              8   com.apple.CoreFoundation      0x00007fff93524b82 CFBundleGetFunctionPointerForName + 50
              9   com.adobe.ASLFoundation.framework 0x0000000102660cdb ASL::Module::GetProcAddress(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 363
              10  com.adobe.PluginSupport.framework 0x00000001071205ca ML::PluginImpl::GetEntryPoint(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 138
              11  com.adobe.VideoFilterHost.framework 0x0000000107a7a3fb ML::AEPluginVideoFilterModule::GetEntryPoint() + 347
              12  com.adobe.VideoFilterHost.framework 0x0000000107aa5515 ML::AEVideoFilterModule::GlobalSetup(bool) + 245
              13  com.adobe.VideoFilterHost.framework 0x0000000107aa4f1f ML::AEVideoFilterModule::SetupFilter() + 79
              14  com.adobe.VideoFilterHost.framework 0x0000000107a7cb6b ML::AEVideoFilter::Create(ASL::InterfaceRef<ML::AEVideoFilterModule, ML::IPluginModule>) + 155
              15  com.adobe.VideoFilterHost.framework 0x0000000107aa4e77 ML::AEVideoFilterModule::CreateFilter(ASL::InterfaceRef<BE::IVideoFilter, BE::IVideoFilter>&) + 39
              16  com.adobe.VideoFilterHost.framework 0x0000000107ae3b4a ML::VideoFilterFactory::CreateVideoFilter(ASL::InterfaceRef<ML::IVideoFilterModule, ML::IVideoFilterModule>) const + 186
              17  com.adobe.VideoFilterHost.framework 0x0000000107ae3de3 ML::VideoFilterFactory::CreateVideoFilter(dvacore::utility::ImmutableString const&, int) const + 67
              18  com.adobe.EncoderHost.framework 0x000000010f0134bd EncoderHost::StandardFilterWrapper::CreateVideoFilter() + 221
              19  com.adobe.EncoderHost.framework 0x000000010f0151c1 EncoderHost::StandardFilterWrapper::IsUnderlyingVideoFilterHealthy() + 33
              20  com.adobe.EncoderHost.framework 0x000000010f02f6a1 EncoderHost::StandardFilterWrapperLumetri::UpdateMainDropList() + 209
              21  com.adobe.EncoderHost.framework 0x000000010f02f14a EncoderHost::StandardFilterWrapperLumetri::GetFilterParams(ASL::InterfaceRef<MF::IExporte rParam, MF::IExporterParam>) + 4490
              22  com.adobe.EncoderHost.framework 0x000000010f000a4b EncoderHost::StandardFilterContainer::SetupParamContainer(bool, bool) + 811
              23  com.adobe.EncoderHost.framework 0x000000010ef7bfad EncoderHost::Encoder::LoadPreset(ASL::InterfaceRef<EncoderHost::IPreset, EncoderHost::IPreset>, bool, unsigned int*, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >*) + 1949
              24  com.adobe.Mezzanine.framework 0x000000010fa37bdd MZ::SequenceSettingsCache::GetSequencePreviewPresetFromCache(std::__1::basic_string<unsig ned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 4285
              25  com.adobe.Mezzanine.framework 0x000000010fa3c7dc MZ::(anonymous namespace)::SequenceSettingsCacheImpl::PreloadCodecsAsync() + 1340
              26  com.adobe.dvacore.framework    0x00000001001f0f82 dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymou s namespace)::AllocatedFunctionWithSerialNumber> >::CallFunctionWithExceptionHandler(boost::function<void ()> const&) + 34
              27  com.adobe.dvacore.framework    0x00000001001f222f dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymou s namespace)::AllocatedFunctionWithSerialNumber> >::OnThreadExecute(boost::shared_ptr<dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymou s namespace)::AllocatedFunctionWithSerialNumber> > > const&) + 191
              28  com.adobe.dvacore.framework    0x00000001001fcab2 dvacore::threads::ExecuteTopLevelFunction(boost::function<void ()> const&) + 98
              29  com.adobe.dvacore.framework    0x00000001002108ff dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
              30  libdispatch.dylib              0x00007fffa8c188fc _dispatch_client_callout + 8
              31  libdispatch.dylib              0x00007fffa8c27196 _dispatch_queue_override_invoke + 743
              32  libdispatch.dylib              0x00007fffa8c1a6b5 _dispatch_root_queue_drain + 476
              33  libdispatch.dylib              0x00007fffa8c1a48c _dispatch_worker_thread3 + 99
              34  libsystem_pthread.dylib        0x00007fffa8e675a2 _pthread_wqthread + 1299
              35  libsystem_pthread.dylib        0x00007fffa8e6707d start_wqthread + 13
              Thread 5:
              0   libsystem_kernel.dylib        0x00007fffa8d7dd96 kevent + 10
              1   com.adobe.dvatransport.framework 0x000000010412fbac boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 268
              2   com.adobe.dvatransport.framework 0x000000010412f65c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 380
              3   com.adobe.dvatransport.framework 0x000000010412f325 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181
              4   com.adobe.dvatransport.framework 0x0000000104124c42 SkyConnectionEnv::MainLoop() + 162
              5   com.adobe.dvatransport.framework 0x00000001041245f9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
              6   com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
              7   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              8   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              9   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 6:
              0   libsystem_kernel.dylib        0x00007fffa8d7cbf2 __psynch_cvwait + 10
              1   libsystem_pthread.dylib        0x00007fffa8e687fa _pthread_cond_wait + 712
              2   com.adobe.dvatransport.framework 0x000000010412f5e7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 263
              4   com.adobe.dvatransport.framework 0x000000010413a75a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
              5   com.adobe.dvacore.framework    0x00000001001b21e3 boost_asio_detail_posix_thread_function + 19
              6   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              7   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              8   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 7:
              2   com.adobe.dvacore.framework    0x00000001000f3831 boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 65
              3   com.adobe.dvacore.framework    0x00000001000f356b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 171
              4   com.adobe.dvacore.framework    0x000000010020eb41 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::thread s::AllocatedFunctionT<boost::function<void ()> > >&, int) + 145
              5   com.adobe.dvacore.framework    0x000000010020d029 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 153
              6   com.adobe.dvacore.framework    0x000000010020a16f dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 367
              7   com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
              8   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              9   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              10  libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 8:: VulcanMsgRecv
              0   libsystem_kernel.dylib        0x00007fffa8d7cdf6 __recvfrom + 10
              1   VulcanMessage5.dylib          0x000000010bc3a2b8 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
              2   VulcanMessage5.dylib          0x000000010bc3967c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
              3   VulcanMessage5.dylib          0x000000010bc38974 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
              4   VulcanMessage5.dylib          0x000000010bc38838 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
              5   VulcanMessage5.dylib          0x000000010bc33477 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
              6   VulcanMessage5.dylib          0x000000010bc33f06 vcfoundation::io::Serializer::InternalDeserialize() + 30
              7   VulcanMessage5.dylib          0x000000010bc3389f vcfoundation::io::Serializer::Deserialize() + 9
              8   VulcanMessage5.dylib          0x000000010bc37924 vcfoundation::ncomm::Connection::ReadIn() + 22
              9   VulcanMessage5.dylib          0x000000010bc3737d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
              10  VulcanMessage5.dylib          0x000000010bc3706a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
              11  VulcanMessage5.dylib          0x000000010bc36fbd vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
              12  VulcanMessage5.dylib          0x000000010bc2a7f8 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
              13  VulcanMessage5.dylib          0x000000010bc29a36 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
              14  VulcanMessage5.dylib          0x000000010bc381bc vcfoundation::thread::AbstractThread::Run() + 72
              15  VulcanMessage5.dylib          0x000000010bc3a0b9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
              16  libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              17  libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              18  libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 9:: com.apple.audio.IOThread.client
              0   libsystem_kernel.dylib        0x00007fffa8d7534a mach_msg_trap + 10
              1   libsystem_kernel.dylib        0x00007fffa8d74797 mach_msg + 55
              2   com.apple.audio.CoreAudio      0x00007fff93029935 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 127
              3   com.apple.audio.CoreAudio      0x00007fff930298a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
              4   com.apple.audio.CoreAudio      0x00007fff930268d0 HALC_ProxyIOContext::IOWorkLoop() + 1196
              5   com.apple.audio.CoreAudio      0x00007fff93026264 HALC_ProxyIOContext::IOThreadEntry(void*) + 128
              6   com.apple.audio.CoreAudio      0x00007fff93025fa3 HALB_IOThread::Entry(void*) + 75
              Thread 10:
              Thread 11:
              Thread 12:
              Thread 13:
              Thread 14:
              0   libsystem_kernel.dylib        0x00007fffa8d7539e semaphore_timedwait_trap + 10
              1   com.apple.CoreServices.CarbonCore 0x00007fff943ccd1b MPWaitOnSemaphore + 71
              2   REDR3D.dylib                  0x0000000135f87c87 0x135e40000 + 1342599
              3   REDR3D.dylib                  0x0000000135f3ee02 0x135e40000 + 1043970
              4   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              5   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              6   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 15:
              2   REDR3D.dylib                  0x0000000135f88807 0x135e40000 + 1345543
              Thread 16:
              Thread 17:
              Thread 18:
              Thread 19:
              2   com.apple.CoreFoundation      0x00007fff934c0434 __CFRunLoopServiceMachPort + 212
              3   com.apple.CoreFoundation      0x00007fff934bf8c1 __CFRunLoopRun + 1361
              4   com.apple.CoreFoundation      0x00007fff934bf114 CFRunLoopRunSpecific + 420
              5   com.apple.AVCVideoServices    0x000000013e74dad2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
              Thread 20:
              Thread 0 crashed with X86 Thread State (64-bit):
                rax: 0x0000000125054010  rbx: 0x00000000000000b2  rcx: 0x00007fffa8e8edb0  rdx: 0x00000000000000ab
                rdi: 0x0000000000000000  rsi: 0x0000000125054000  rbp: 0x00007fff5fbfb370  rsp: 0x00007fff5fbfb320
                 r8: 0x00000000000001f0   r9: 0x00000001247b2400  r10: 0x0000000000031001  r11: 0xffff8001c4bbe5e0
                r12: 0x00000001247b2800  r13: 0x00000001431eb000  r14: 0x00000001247b2808  r15: 0x4dd9090210e20031
                rip: 0x00007fffa8e80e97  rfl: 0x0000000000010246  cr2: 0x000000014bbce50b
              Logical CPU:     0
              Error Code:      0x00000000
              Trap Number:     6
              Binary Images:
                     0x100000000 -        0x100007ff7 +com.adobe.PremierePro.CC12 (12.1.2 - 12.1.2) <4B73B4B4-B982-34C9-81B2-A9A664CB8847> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
                     0x10000d000 -        0x100013fff +com.adobe.AdobeCrashReporter (7.7 - 7.7.0) <FA36FB74-CC30-3BFC-BC2C-4025E64F8C6A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                     0x10001f000 -        0x100020ff3 +com.adobe.boost-system.framework (12.1.2 - 12.1.2.69) <24EF9CA8-E663-3396-B593-3E275BE83204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                     0x100028000 -        0x10002cfff +com.adobe.boost-date-time.framework (12.1.2 - 12.1.2.69) <E4727EFC-83A2-31C7-8740-6AAB964723D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                     0x10003d000 -        0x10004aff7 +com.adobe.boost-threads.framework (12.1.2 - 12.1.2.69) <60EB538A-DB63-33DA-B351-2189E2945EA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                     0x100068000 -        0x100075fff +com.adobe.boost-filesystem.framework (12.1.2 - 12.1.2.69) <169D6D1B-EBBF-3529-B93E-0107A43FB7D7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                     0x10008a000 -        0x1000a3fff +com.adobe.dvaunittesting.framework (12.1.2 - 12.1.2.69) <3BF41758-7436-3E39-A4DF-C7BB0C2EE018> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                     0x1000d8000 -        0x100450fff +com.adobe.dvacore.framework (12.1.2 - 12.1.2.69) <4E8C8538-6240-36EF-B307-BEFF249EB67B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                     0x10075e000 -        0x100792fff +com.adobe.dvaappsupport.framework (12.1.2 - 12.1.2.69) <5234904E-FF9B-3AB9-8229-3F01CDF6B746> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
                     0x1007ea000 -        0x100ed7fff +com.adobe.dvaui.framework (12.1.2 - 12.1.2.69) <7DDB6DAD-68D9-37FD-AEB7-6BBC905B8848> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                     0x101ac7000 -        0x101cd8ff7 +com.adobe.MBCProvider.framework (12.1.2 - 12.1.2.69) <433E47AB-1261-3BBE-A0EF-0D1B655BB5D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                     0x101e8c000 -        0x101eb1fff +com.adobe.dvamediaui.framework (12.1.2 - 12.1.2.69) <6F1A328B-D44F-39AD-9101-9AB84944D299> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
                     0x101f13000 -        0x102070fff +com.adobe.dvamediabrowser.framework (12.1.2 - 12.1.2.69) <D8DD93F0-663B-33CA-8902-AF52126A58CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
                     0x10231a000 -        0x1023c8ff7 +com.adobe.TransmitVRHost.framework (12.1.2 - 12.1.2.69) <0496432C-78E7-3E98-AC62-64DA66CE449C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitVRHost.framework/Versions/A/TransmitVRHost
                     0x1024ec000 -        0x1024eeff7 +com.adobe.PRM.framework (12.1.2 - 12.1.2.69) <CDE494A8-D9E9-39F4-852A-7E04445D83DE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                     0x1024f9000 -        0x102566fff +com.adobe.dvamediatypes.framework (12.1.2 - 12.1.2.69) <CF1C0566-8AF5-3ED5-9935-86E98B060B29> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                     0x10261b000 -        0x102673ff7 +com.adobe.ASLFoundation.framework (12.1.2 - 12.1.2.69) <C7FE2F6C-F42D-3131-BA2C-D1A005CFF2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                     0x1026e7000 -        0x10291ffff +com.adobe.Frontend.framework (12.1.2 - 12.1.2.69) <145FFDBF-A0FF-3651-A931-F972C952031B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
                     0x102c9c000 -        0x102e5eff7 +com.adobe.amtlib (10.0.0.250 - 10.0.0.250) <172741F8-9E54-317F-A72B-51D05CC05182> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                     0x102e79000 -        0x102f4cfff +com.adobe.dvascripting.framework (12.1.2 - 12.1.2.69) <DC030805-7C1A-3B1A-A027-90AFC649C226> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
                     0x103191000 -        0x1031b3fff +com.adobe.ASLMessaging.framework (12.1.2 - 12.1.2.69) <5F55175A-5BAC-39B2-93ED-2908DC2EEE0E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                     0x103203000 -        0x103ae8fc7 +com.adobe.dvaaccelerate.framework (12.1.2 - 12.1.2.69) <6B237AA5-FB0C-39B9-BB20-D7A942D98464> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
                     0x103bed000 -        0x103e4afe7 +com.adobe.dvaaudiodsp.framework (12.1.2 - 12.1.2.69) <818F0533-0CB6-3289-B4D7-1C3B69A10DDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
                     0x104101000 -        0x104103ff7 +com.adobe.Memory.framework (12.1.2 - 12.1.2.69) <29A797B7-5BD7-3A40-8275-DAAC57B061ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                     0x10410b000 -        0x104163ff7 +com.adobe.dvatransport.framework (12.1.2 - 12.1.2.69) <88F78E08-C945-39A2-BA73-D052FEB1A166> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                     0x104200000 -        0x104221fff +com.adobe.dvamarshal.framework (12.1.2 - 12.1.2.69) <97B637CC-1E4F-3A2B-A206-C4A175EDF68C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                     0x104265000 -        0x1044b4fff +com.adobe.dynamiclink.framework (12.1.2 - 12.1.2.69) <FDFB3C59-C8C9-3261-8C76-12E44E5A0C3C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                     0x1047b6000 -        0x104859fff +com.adobe.MediaFoundation.framework (12.1.2 - 12.1.2.69) <419C7E97-5046-3739-A6A2-555E0236466B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                     0x104946000 -        0x10496fff7 +com.adobe.SweetPeaSupport.framework (12.1.2 - 12.1.2.69) <EF1AFE64-61B8-3503-8D95-C2429C9AE27D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                     0x1049c5000 -        0x104a02dc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
                     0x104a50000 -        0x104acafff +com.adobe.AudioRenderer.framework (12.1.2 - 12.1.2.69) <97A27DC9-971D-364A-8948-EEF7D3211025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                     0x104b91000 -        0x104cbdff7 +com.adobe.dvacaptioning.framework (12.1.2 - 12.1.2.69) <5C9A446F-8338-3529-AF9F-2EE687B445EF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                     0x104db1000 -        0x104dfcfff +com.adobe.dvatemporalxmp.framework (12.1.2 - 12.1.2.69) <A5051B93-5997-306D-8D19-E16FECF946A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                     0x104e32000 -        0x104ebbff7 +com.adobe.dvametadata.framework (12.1.2 - 12.1.2.69) <74880A28-97DC-3774-AA80-41730CFF3699> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                     0x104f8b000 -        0x105c85ff7 +com.adobe.Backend.framework (12.1.2 - 12.1.2.69) <8A85E254-7073-30F3-8D08-0E24F00A13D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                     0x106c8c000 -        0x106cb5fff +com.adobe.MLFoundation.framework (12.1.2 - 12.1.2.69) <70A8FD1A-3FF3-3D05-8678-ECB3D808F60C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                     0x106d10000 -        0x106e68fd7 +com.adobe.ImageRenderer.framework (12.1.2 - 12.1.2.69) <8D838BA1-F6A6-3BD5-A04C-D8832165554D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                     0x106faf000 -        0x10705ffff +com.adobe.VideoFrame.framework (12.1.2 - 12.1.2.69) <AACAF49F-0186-38D4-9AC5-F2F8D6E5C7BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                     0x1070f9000 -        0x107147ff7 +com.adobe.PluginSupport.framework (12.1.2 - 12.1.2.69) <E3E53E37-97C4-3727-91D2-07B0BC61FD06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                     0x1071b2000 -        0x1071eefff +com.adobe.AudioSupport.framework (12.1.2 - 12.1.2.69) <BD56A6CB-3540-359C-BD3C-C9736202C285> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                     0x10726c000 -        0x107284fff +com.adobe.MediaUtils.framework (12.1.2 - 12.1.2.69) <FFB2D8D5-4B45-3833-AE5D-EC3F7FEAFFBF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                     0x1072a8000 -        0x107440fff +com.adobe.ImporterHost.framework (12.1.2 - 12.1.2.69) <69FE0A9E-9B5B-3B82-9662-DA60B115E91B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                     0x1076ca000 -        0x10771dff7 +com.adobe.AudioFilterHost.framework (12.1.2 - 12.1.2.69) <81C4C349-0F0A-3D2E-8DFC-12419277E082> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                     0x1077aa000 -        0x1078d1ff7 +com.adobe.VideoRenderer.framework (12.1.2 - 12.1.2.69) <75A24572-0877-3454-85AD-8A0594EFCD0B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                     0x107a57000 -        0x107b86fff +com.adobe.VideoFilterHost.framework (12.1.2 - 12.1.2.69) <7604CA03-B7FD-38DC-AD07-4E5734FA128C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                     0x107d09000 -        0x107d21fff +com.adobe.ProjectSupport.framework (12.1.2 - 12.1.2.69) <D2E66A75-7DA9-3021-8991-58367227D7D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                     0x107d58000 -        0x107ea9ff7 +com.adobe.dvametadataDB.framework (12.1.2 - 12.1.2.69) <4708F30C-E326-37AE-B6EE-DA3BF602C229> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                     0x107ef4000 -        0x108008fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.162860) <9C4D43CC-0925-3157-85D3-266A1F093831> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                     0x108167000 -        0x1081d0ff7 +com.adobe.DynamicLinkMedia.framework (12.1.2 - 12.1.2.69) <060E5F73-BF96-39F7-884F-79F5579C8C0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                     0x1082be000 -        0x1082d2fff +com.adobe.CCLibrariesSupport.framework (12.1.2 - 12.1.2.69) <8B9F7E1C-E419-3431-A29D-8FCA6D177F2F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
                     0x108307000 -        0x108329ff7 +com.adobe.dvavulcansupport.framework (12.1.2 - 12.1.2.69) <535CE33D-2DC8-3972-AD5E-6CF385043CDA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
                     0x10835f000 -        0x1083bcfff +com.adobe.csxsmanager.framework (12.1.2 - 12.1.2.69) <7544549A-7115-313A-836B-3F1BD8C0B5B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
                     0x108443000 -        0x108474ff7 +com.adobe.boost-program-options.framework (12.1.2 - 12.1.2.69) <228DFA51-8A91-3A05-AC26-872AE6517D9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_opt ions
                     0x1084d1000 -        0x10856bfff +com.adobe.boost-regex.framework (12.1.2 - 12.1.2.69) <411D4511-E2D7-33E6-AB96-0B00C7D34887> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                     0x1085e1000 -        0x108713fff +com.adobe.dvastorage.framework (12.1.2 - 12.1.2.69) <70DEA66D-58FF-39F6-95E3-417C78F050FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
                     0x10877e000 -        0x1088defff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 42 - 79.162860) <1F29F6FF-53E8-39A1-9B5E-0A27BBE9FDE7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                     0x108a1b000 -        0x108a37ffb +com.adobe.libzip.framework (12.1.2 - 12.1.2.69) <A0AA6A5E-AA7A-38A5-ADF7-3A54AAC02880> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
                     0x108a4f000 -        0x108f4aff7 +com.adobe.ATEWrapper.framework (12.1.2 - 12.1.2.69) <CAD2611D-B7D8-341E-B13F-4A2D87F311AA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
                     0x1094b9000 -        0x10973ffcb +com.adobe.PlugPlug (8.0.0.55 - 8.0.0.55) <B685BDFA-3EA3-3BF7-A88A-5EE5164DBCED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                     0x1099b8000 -        0x109c69ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libxerces-c-3.1.dylib
                     0x109e19000 -        0x109ecbfff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libgit2.dylib
                     0x109eef000 -        0x109fe9fff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                     0x109ffa000 -        0x10a0b5fff +com.adobe.dvaaudiofilterhost.framework (12.1.2 - 12.1.2.69) <B68A17BE-0CD9-35FA-8D86-4AED6C0AC62C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
                     0x10a1dc000 -        0x10a33aff7 +com.adobe.dvaaudiofilters.framework (12.1.2 - 12.1.2.69) <2090E919-55A3-36B8-8C3C-CE2CC321A444> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
                     0x10a52d000 -        0x10a589ff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <DD6F8D1F-69EE-335A-8654-72B24E25423D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                     0x10a5cf000 -        0x10a60dff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                     0x10a635000 -        0x10a761ff7  com.apple.AudioVideoBridging (503.2 - 503.2) <90DFEC17-1857-3C9E-BDFC-41AFE115296A> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
                     0x10a816000 -        0x10a82ffff  libexpat.1.dylib (15.1) <588CA992-60BB-363B-BEE7-3CC0A26C1AFA> /usr/lib/libexpat.1.dylib
                     0x10a839000 -        0x10a84dff3  com.apple.AudioServerApplication (1.0 - 200.9) <4977039B-FC27-3D6E-9B3E-81B3071ADBB3> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServer Application
                     0x10a85d000 -        0x10a86cfff  com.apple.TimeSync (1.0 - 503.1) <D06817FE-7DEC-3F8C-9484-2EA4CFBC0889> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
                     0x10a87e000 -        0x10a937fff +com.adobe.dvanet.framework (12.1.2 - 12.1.2.69) <FA83A194-6156-3BA8-B834-0F666F2DB153> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                     0x10aa5a000 -        0x10b1bdfff +com.adobe.EAClient.framework (12.1.2 - 12.1.2.69) <F57BDECE-C558-370B-AB80-1BDAF7FA4B74> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
                     0x10bbcb000 -        0x10bbeffff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanControl.dylib
                     0x10bc1c000 -        0x10bc57ff7 +VulcanMessage5.dylib (5.3.0.18 - 5.3.0.18 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <9E8F32A6-84F5-33EF-854C-9D0590105050> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanMessage5.dylib
                     0x10bca1000 -        0x10bcb9fff +com.adobe.TeamProjectsLocalClient.framework (12.1.2 - 12.1.2.69) <674A1891-89B4-3035-94E7-82AA716912BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLoc alClient
                     0x10bcf3000 -        0x10bdb3ff7 +com.adobe.dvaeve.framework (12.1.2 - 12.1.2.69) <9EBF04FD-F699-35CD-9080-903E763BA3A7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                     0x10bf0d000 -        0x10c000ff7 +com.adobe.dvanetsync.framework (12.1.2 - 12.1.2.69) <81666DDC-1449-36B0-9CC2-91F88EEA266C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
                     0x10c174000 -        0x10c2e6ff7 +com.adobe.dvaworkspace.framework (12.1.2 - 12.1.2.69) <5167E87B-9BFF-3482-8ED3-D97177623CDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                     0x10c5ee000 -        0x10c6aeff7 +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.162860) <E8B0F4F8-F9FB-3A4E-9B6F-A3C4CAB5D995> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompare AndMerge
                     0x10c819000 -        0x10c9e8fff +com.adobe.GPUFoundation.framework (12.1.2 - 12.1.2.69) <95B23730-940A-3BC4-B774-7BF7A28767C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                     0x10cb21000 -        0x10cb34fff +com.adobe.RuntimeInstaller.framework (12.1.2 - 12.1.2.69) <56CF8516-E47B-34D7-8CA7-028B4FAA623B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
                     0x10cb53000 -        0x10cc37ff7 +com.mainconcept.mc.mfimport (10.5 - 10.5.17.5963) <C3926B1A-0AB4-37B6-9F44-39E399CD2B94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
                     0x10cc46000 -        0x10cdcdfff +com.adobe.atl-audio.framework (12.1.2 - 12.1.2.69) <44F6270C-417D-3B01-A05A-8AEFE2E1F2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
                     0x10cdf7000 -        0x10cecdfff +com.adobe.dvaaudiodevice.framework (12.1.2 - 12.1.2.69) <A95196BF-AF0A-30B2-9186-2AF95ACA18FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                     0x10d087000 -        0x10d15bfff +com.adobe.OpticalFlow.framework (12.1.2 - 12.1.2.69) <3D947580-654E-3718-AF85-801839184764> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
                     0x10d221000 -        0x10d22dfff +com.adobe.BravoInitializer.framework (12.1.2 - 12.1.2.69) <436469E3-B3AE-320B-B960-3EB40539BCA8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
                     0x10d24a000 -        0x10d356fff +com.adobe.ACE (AdobeACE 2.20.02.40104 - 2.20.02.40104) <4E99F32C-DF9A-30DE-ADCB-75498D2B206C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                     0x10d36f000 -        0x10d868fff +com.adobe.AGM (AdobeAGM 4.30.87.40104 - 4.30.87.40104) <D7DD88C5-47A8-3771-AA98-D3898889A554> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                     0x10d915000 -        0x10d92bfff +com.adobe.BIB (AdobeBIB 1.2.03.40104 - 1.2.03.40104) <8FB4C147-F145-3886-BBC9-66F4027EBAE5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                     0x10d934000 -        0x10dc34ff7 +com.adobe.CoolType (AdobeCoolType 5.17.00.40104.1 - 5.17.00.40104) <BD3DFF22-2E03-391E-8E1A-933AA0046204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                     0x10dc86000 -        0x10ddb0ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
                     0x10de06000 -        0x10de26ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.40104 - 1.1.40104) <3D52E2D3-C27B-314F-83B6-BCBA00F6D87D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                     0x10de2e000 -        0x10de3efff +com.adobe.ProjectConverterHost.framework (12.1.2 - 12.1.2.69) <3BA089F2-EE8C-39FF-9E0C-E7DD6D23F06B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHo st
                     0x10de66000 -        0x10de87fff +com.adobe.ImmersiveVideo.framework (12.1.2 - 12.1.2.69) <36E93CA8-ECAF-352D-B139-FA538A56DD19> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
                     0x10deab000 -        0x10df17ff7 +com.adobe.DisplaySurface.framework (12.1.2 - 12.1.2.69) <C9B98269-28C9-3F52-96EA-C0AE3D9E3CAC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
                     0x10df97000 -        0x10e350fff +com.adobe.UIFramework.framework (12.1.2 - 12.1.2.69) <868C7FBC-6E27-3059-A2A1-95247905D36B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
                     0x10eb87000 -        0x10ebacff7 +com.adobe.dvavirtualui.framework (12.1.2 - 12.1.2.69) <46C049C3-FD4D-3880-950F-7F43883330EE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavirtualui.framework/Versions/A/dvavirtualui
                     0x10ec07000 -        0x10ec6fff7 +com.adobe.PlayerHost.framework (12.1.2 - 12.1.2.69) <2D45B21F-9E60-3F8E-94F4-0D6D99365F91> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                     0x10ed4b000 -        0x10ee17ff7 +com.adobe.ExporterHost.framework (12.1.2 - 12.1.2.69) <8CA3E0BA-FB21-373B-95BC-B1BAF9164374> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                     0x10ef33000 -        0x10f0c5fff +com.adobe.EncoderHost.framework (12.1.2 - 12.1.2.69) <8C6A2EBD-ED0A-3438-9C22-3F67AAF19BBE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                     0x10f2c6000 -        0x10f331ff7 +com.adobe.RecorderHost.framework (12.1.2 - 12.1.2.69) <CEDFCFD3-8C14-3995-B21E-0D88C75DA73B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
                     0x10f42a000 -        0x10f45eff7 +com.adobe.AudioFilters.framework (12.1.2 - 12.1.2.69) <91453FBC-53DC-3B29-A566-75527CBC3A55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                     0x10f4d2000 -        0x10ff60fff +com.adobe.Mezzanine.framework (12.1.2 - 12.1.2.69) <15380DB2-236C-3B52-A156-BE7A11113AD0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
                     0x110b53000 -        0x110b8bff7 +com.adobe.MediaCoreUI.framework (12.1.2 - 12.1.2.69) <FC3FFAE7-F381-34B8-96A1-DB959675BA38> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                     0x110beb000 -        0x110e4bff7 +com.adobe.SettingsUI.framework (12.1.2 - 12.1.2.69) <E52003A4-B314-3F16-AE88-BFF7941F7DBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                     0x1112c3000 -        0x11172cfff +com.adobe.HSL.framework (12.1.2 - 12.1.2.69) <D575B13E-1FEA-3BDB-B5B9-B853FAA8021D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
                     0x111d98000 -        0x111ddbfff +com.adobe.TransmitHost.framework (12.1.2 - 12.1.2.69) <037FEF47-EC5C-3762-BFB9-858AB74779FF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
                     0x111e3e000 -        0x111f03ff7 +com.adobe.exo.framework (12.1.2 - 12.1.2.69) <968342CE-E32F-3E52-811C-B7F1B9EE4B84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/exo.framework/Versions/A/exo
                     0x1120ce000 -        0x112113ff7 +com.adobe.dynamiclinkUI.framework (12.1.2 - 12.1.2.69) <1F3F6F73-FEA2-3210-B6C6-4CAB1870B85F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
                     0x1121a8000 -        0x11223cfff +com.adobe.drawbotagm.framework (12.1.2 - 12.1.2.69) <3CC7CD7A-D378-3C33-9ED0-274F038E9E42> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
                     0x1122fa000 -        0x1124eefe7 +com.adobe.CodecSupport.framework (12.1.2 - 12.1.2.69) <8FE9AE4A-B2D3-3765-9CA2-51AABA7D2CD8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
                     0x11269d000 -        0x112836fef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.17.5963) <6566B253-5F5D-38B7-9667-E1D62249F4BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
                     0x112845000 -        0x112ad7fcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.17.5963) <9CF5072E-9C3F-3E48-B18A-48D8DB988539> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
                     0x112aee000 -        0x112cc6fe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.17.5963) <3D65323B-3AA2-399F-923A-3C7E670957D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
                     0x112cd9000 -        0x114242fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
                     0x11443e000 -        0x114484fef +com.adobe.ProResOpt.framework (12.1.2 - 12.1.2.69) <93A0800B-59F1-3E14-9128-8C0547C640B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
                     0x1144bb000 -        0x1144c7fff +com.adobe.QT64Utils.framework (12.1.2 - 12.1.2.69) <2FC70546-FAC0-36B3-AA2E-D6C30AD71A68> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
                     0x1144df000 -        0x1149c0fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libDNxHR.dylib
                     0x114aaf000 -        0x114c1dff7 +libSonyRawDev.dylib (3) <0DEAB123-EEB1-3567-BEB4-074484F55878> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libSonyRawDev.dylib
                     0x114cb9000 -        0x115f15fff +libArriRawSDK.dylib (0) <EB0D5F76-6989-3DAC-8560-35016D7E4D47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libArriRawSDK.dylib
                     0x11663a000 -        0x116716fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmp4decMT.dylib
                     0x116775000 -        0x11687ffff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDDecoder.dylib
                     0x116920000 -        0x116a22fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDEncoder.dylib
                     0x116ad1000 -        0x116b0eff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.6.5.dylib
                     0x116b1a000 -        0x116c3afef +libiomp5.dylib (0) <24D4D9F0-95F7-3930-9662-CD356D42B2C1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libiomp5.dylib
                     0x116caa000 -        0x116cd9ff7 +libcilkrts.5.dylib (0) <04FF28DE-1EA4-3A82-ACED-7B8BD7CA100A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcilkrts.5.dylib
                     0x116cf7000 -        0x116d1cff7 +com.adobe.QTParser.framework (12.1.2 - 12.1.2.69) <451126BD-5016-3F2C-A571-CC87C87CF169> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                     0x116d44000 -        0x116e29fdf +libProResDecoder.dylib (0) <F006F4E9-D737-3E29-949E-113035495E4B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libProResDecoder.dylib
                     0x116e6a000 -        0x116ea5fff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.dylib
                     0x116eb3000 -        0x116ed9ff7 +com.adobe.TimeCarving.framework (12.1.2 - 12.1.2.69) <EF7B833B-1611-3F22-92F5-55CDD228697E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
                     0x116f1d000 -        0x116f9dfff +com.adobe.MediaFinder.framework (12.1.2 - 12.1.2.69) <9656E167-BFDD-38CE-AA0F-252BA63C6BF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
                     0x1170a0000 -        0x117249fff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
                     0x117375000 -        0x117409fff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <ED3A028B-68A7-37D8-9127-F99AB0970B65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
                     0x11749e000 -        0x11753aff7 +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <265AC5A0-FA72-3D47-99CF-9371A7582B62> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
                     0x1175da000 -        0x117622ff7 +com.adobe.ahclientframework (3.0.0.7 - 3.0.0.7) <4D54E721-153B-3DE0-BC31-5B1500295EEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                     0x11765a000 -        0x11767afff +com.adobe.AMEAppFoundation.framework (12.1.2 - 12.1.2.69) <93F41D3D-9879-3EE7-8B42-EBEBAE7EA6D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                     0x1176cb000 -        0x1176d0fff +com.adobe.dvaundo.framework (12.1.2 - 12.1.2.69) <15A81932-504B-31EA-89C0-92BF8EA83387> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
                     0x1176de000 -        0x117778fff +com.adobe.essentialsound.framework (12.1.2 - 12.1.2.69) <83657D4C-A0A8-3D72-B581-1C7E858EECA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
                     0x117882000 -        0x1178dbfff +com.adobe.FontEngine.framework (12.1.2 - 12.1.2.69) <2DB8738C-F712-3FAB-B598-1177C00F8E20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
                     0x11796f000 -        0x117986fff +com.adobe.TitleLayer.framework (12.1.2 - 12.1.2.69) <589EF00E-F74A-398C-AC9A-5810FF6151A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
                     0x117b23000 -        0x117b2bff7 +com.adobe.TitleImageManager.framework (12.1.2 - 12.1.2.69) <4006371A-05F0-3F0B-93CF-66B4AE75C274> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
                     0x117b3a000 -        0x117bbeff7 +com.adobe.TitleCharacterFactory.framework (12.1.2 - 12.1.2.69) <2610FFB0-AB4E-350E-8B63-689E590039D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFac tory
                     0x117c42000 -        0x117d91ff7 +com.adobe.TitleCG.framework (12.1.2 - 12.1.2.69) <5B6BCB7E-DA1E-3551-93FF-118B4535FD86> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
                     0x117e9e000 -        0x1180cbfff +com.adobe.TitleLayout.framework (12.1.2 - 12.1.2.69) <8B58ECBA-468E-3BA8-8BD7-FCA86B167518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
                     0x1185d9000 -        0x118629fff +com.adobe.TitleRenderer.framework (12.1.2 - 12.1.2.69) <0BBB073A-A497-39E3-BA4E-8E4AD308857A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
                     0x1186b9000 -        0x11870cff7 +com.adobe.dvaaudiofilterhostui.framework (12.1.2 - 12.1.2.69) <6F650B83-DF5D-3693-9D24-CB28E876D6C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhost ui
                     0x1187e7000 -        0x1188b7fff +com.adobe.dvametadataUI.framework (12.1.2 - 12.1.2.69) <8695151E-E481-3EF6-83D2-62A819D4D67E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                     0x118a04000 -        0x118a0eff7 +com.adobe.dvamarkerUI.framework (12.1.2 - 12.1.2.69) <20C88E1E-80B8-3B90-A141-DBE43575A58D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
                     0x118a33000 -        0x118c45fff +com.adobe.EACodec.framework (12.1.2 - 12.1.2.69) <74428346-9289-3935-9E2C-A43C9383AF82> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
                     0x118d23000 -        0x118fe3ff7 +com.adobe.EAMedia.framework (12.1.2 - 12.1.2.69) <D4B5E45E-0040-3A67-B9EA-8F1D8522BC14> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
                     0x119346000 -        0x119850ff7 +com.adobe.EAProjectBridge.framework (12.1.2 - 12.1.2.69) <6AFF03E3-AF61-3AE6-AB89-192F9D835371> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
                     0x119eaf000 -        0x119ec8fff +com.adobe.dvastoryparser.framework (12.1.2 - 12.1.2.69) <BE91B646-3223-3A8A-9C4C-A46E480CF6B6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
                     0x119ee9000 -        0x119f11ff7 +com.adobe.dvatypekit.framework (12.1.2 - 12.1.2.69) <594817A4-3D82-3333-B5AF-DBA5AE97DDDF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
                     0x119f50000 -        0x119ffbfff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
                     0x11a027000 -        0x11a03cff7 +com.adobe.postprocess.framework (12.1.2 - 12.1.2.69) <A90C6102-223B-3B36-A5F3-60E4ACEB690A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
                     0x11a06d000 -        0x11a3defe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.17.5963) <68C4B627-70A1-3451-8178-5B00CBDC4779> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
                     0x11a517000 -        0x11a729fc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.17.5963) <ABB8EB0E-532F-3C65-84A3-3D1206FC2E89> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
                     0x11a73b000 -        0x11a9ccfff +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.17.5963) <9C81FC97-3172-30C6-AB48-AB49515BA1D6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
                     0x11a9f9000 -        0x11aa35ff7 +com.adobe.boost-serialization.framework (12.1.2 - 12.1.2.69) <006B6435-0439-3B99-8820-20EF07908B34> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
                     0x11ab02000 -        0x11b04eff7 +com.adobe.TeamProjectsLocalLib.framework (12.1.2 - 12.1.2.69) <07742390-2F94-3303-B21D-D7BBF4D2C132> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalL ib
                     0x11b5fe000 -        0x11bb94b27 +adobe.cloudservices.liveedit.LiveEditClient (1.0 - 1) <9A981AA5-734D-3591-A029-96B2DAF10888> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LiveEditClient.framework/Versions/A/LiveEditClient
                     0x11bfb1000 -        0x11c485ff7 +com.adobe.Dialogs.framework (12.1.2 - 12.1.2.69) <C436E904-AE02-38C3-8EA8-14B552E64C0C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
                     0x11ca55000 -        0x11cb0cff7 +com.adobe.PProDynamicLinkServer.framework (12.1.2 - 12.1.2.69) <6CBD4908-B736-3D35-A4AA-FBF6C989DB70> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkSe rver
                     0x11ccd0000 -        0x11ce79fff +com.adobe.EAPrBridge.framework (12.1.2 - 12.1.2.69) <C80D2C85-95AB-3D4B-BBAB-F5A8F9B6B50E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
                     0x11d10b000 -        0x11d122ff7 +com.adobe.dvacaptioningui.framework (12.1.2 - 12.1.2.69) <684F757A-CE8A-376B-A88F-1E3F1E4E4607> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
                     0x11d14a000 -        0x11d326ff7 +com.adobe.RendererGPU.framework (12.1.2 - 12.1.2.69) <9E5C7BA8-3A0E-3A78-B69E-D3CE87494016> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
                     0x11d468000 -        0x11d63dff7 +com.adobe.IngestCore.framework (12.1.2 - 12.1.2.69) <0B61D9D8-35A2-36AD-8DAF-6EF0342ACE1A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
                     0x11d972000 -        0x11da36fff +com.adobe.IngestDialog.framework (12.1.2 - 12.1.2.69) <0696C3F1-A7ED-3FE8-AE93-334B0EFF4F9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
                     0x11dbef000 -        0x11dc1eff7 +com.adobe.dvacontrolsurfacehost.framework (12.1.2 - 12.1.2.69) <2E26F17D-512F-3D0C-B47E-15A436C04DA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurface host
                     0x11dca8000 -        0x11dcdbfff +com.adobe.dvaaudiodeviceui.framework (12.1.2 - 12.1.2.69) <8D705EA9-5C4A-37BB-B534-1B1C0CD1CF49> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
                     0x11dd36000 -        0x11dd67fff +com.adobe.Registration.framework (12.1.2 - 12.1.2.69) <98218561-A270-3828-91E0-96E44F38184A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
                     0x11dda0000 -        0x11ddb5ff7 +com.adobe.OnBoardingBase.framework (12.1.2 - 12.1.2.69) <F9007BB0-1CF9-32B1-BD5E-229B213F4C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoardingBase.framework/Versions/A/OnBoardingBase
                     0x11ddef000 -        0x11df3dfff +com.adobe.MobileAppLayer.framework (12.1.2 - 12.1.2.69) <3160CBBA-F49F-3DEE-A586-D496564AA3E5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MobileAppLayer.framework/Versions/A/MobileAppLayer
                     0x11e274000 -        0x11e3c0fff +com.adobe.ScriptLayerPPro.framework (12.1.2 - 12.1.2.69) <85CED389-8750-39BE-893A-0F6DC25BDA06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
                     0x11e5ba000 -        0x11e993ff7 +com.adobe.ScriptLayerPProQE.framework (12.1.2 - 12.1.2.69) <E60D0D25-8AC8-3ADE-AEC1-7B6BB2C548E7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
                     0x11f376000 -        0x11f3afff7 +com.adobe.HandlerAudioMiniMixer.framework (12.1.2 - 12.1.2.69) <7570454C-7BDA-3A5D-B00A-4CCB27DC676C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniM ixer
                     0x11f422000 -        0x11f4ddff7 +com.adobe.HandlerColor.framework (12.1.2 - 12.1.2.69) <C4E933D5-5F56-3A76-9C7C-1C00A328C92D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
                     0x11f609000 -        0x11f635ff7 +com.adobe.HandlerCSXS.framework (12.1.2 - 12.1.2.69) <2F0CCDDA-3650-3ADA-A8CA-25FA87B4E122> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
                     0x11f6b2000 -        0x11f8ccff7 +com.adobe.HandlerEffectControls.framework (12.1.2 - 12.1.2.69) <4A4AB44C-0EAD-3496-9359-3478834CD518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectCont rols
                     0x11fb71000 -        0x11fbb5ff7 +com.adobe.HandlerMediaBrowser.framework (12.1.2 - 12.1.2.69) <9B16483B-6AB3-3E24-96A2-F7F925DC4619> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
                     0x11fc6d000 -        0x11fdd1fff +com.adobe.HandlerProgramMonitor.framework (12.1.2 - 12.1.2.69) <7AC73AB3-D2FA-360B-A19A-1CF5042AF0B8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMon itor
                     0x11ffea000 -        0x1202beff7 +com.adobe.HandlerProject.framework (12.1.2 - 12.1.2.69) <DF846AD2-04FF-3F47-BAAF-646651AA1689> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
                     0x12072e000 -        0x120a56ff7 +com.adobe.HandlerTimeline.framework (12.1.2 - 12.1.2.69) <66195A9B-954E-3616-9967-0FF5202AF7F6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
                     0x120e26000 -        0x120e7cff7 +com.adobe.HandlerTools.framework (12.1.2 - 12.1.2.69) <F8E6F606-EAAA-3D64-B2FE-39827AAD02BB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
                     0x120fa6000 -        0x12115dff7 +com.adobe.HandlerTitler.framework (12.1.2 - 12.1.2.69) <1863F354-F666-3565-8873-1EC5CA65EFA0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
                     0x1214b0000 -        0x12150afff +com.adobe.HandlerAudioClipMixer.framework (12.1.2 - 12.1.2.69) <16776F6C-A52E-347E-8451-2D3BDA5167B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipM ixer
                     0x1215c7000 -        0x121667ff7 +com.adobe.HandlerAudioMixer.framework (12.1.2 - 12.1.2.69) <E3D2B286-E9D9-35CC-9400-2FC60570FB90> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
                     0x121774000 -        0x1217c8fff +com.adobe.HandlerCaptions.framework (12.1.2 - 12.1.2.69) <253CB6E4-EE41-313A-B033-E84192E8B59F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
                     0x121866000 -        0x1218eafff +com.adobe.HandlerCapture.framework (12.1.2 - 12.1.2.69) <6C3FB66F-018E-3434-9302-FE9AF70B35A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
                     0x1219f5000 -        0x121a3dff7 +com.adobe.HandlerEditToTape.framework (12.1.2 - 12.1.2.69) <C826C51D-D1B3-3955-A070-5A1383EBD9D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
                     0x121ae5000 -        0x121b53fff +com.adobe.HandlerEffects.framework (12.1.2 - 12.1.2.69) <8D6F4079-4A81-3AB8-B2C4-D0F6C9AEBDEE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
                     0x121c1a000 -        0x121c33ff7 +com.adobe.HandlerEssentialSound.framework (12.1.2 - 12.1.2.69) <AD99F017-8C49-33B4-B78F-AD693FCB2ADE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEssentialSound.framework/Versions/A/HandlerEssentialS ound
                     0x121c81000 -        0x121ca0ff7 +com.adobe.HandlerEvents.framework (12.1.2 - 12.1.2.69) <27D4B764-ACE7-394F-8B42-021CA925919F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
                     0x121cf4000 -        0x121d08ff7 +com.adobe.HandlerGetProperties.framework (12.1.2 - 12.1.2.69) <F6583899-3713-3A40-86C3-65EEE84AFCD2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperti es
                     0x121d3f000 -        0x121ec7ff7 +com.adobe.HandlerGraphics.framework (12.1.2 - 12.1.2.69) <D8932F8B-8420-35FD-A5CA-09C9D6BEB1C9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGraphics.framework/Versions/A/HandlerGraphics
                     0x122142000 -        0x122159ff7 +com.adobe.HandlerHistory.framework (12.1.2 - 12.1.2.69) <90FDBC3E-6DA7-31EE-9E4B-84A436F11B93> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
                     0x122196000 -        0x1221b7fff +com.adobe.HandlerInfo.framework (12.1.2 - 12.1.2.69) <D38E5CE9-4073-3F84-ACA2-A891A10C7AEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
                     0x122204000 -        0x122248ff7 +com.adobe.HandlerMarkerList.framework (12.1.2 - 12.1.2.69) <16F37EC8-0C68-3DBC-9125-288FEFCE9EF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
                     0x1222ee000 -        0x12233ffff +com.adobe.HandlerMetadataEditor.framework (12.1.2 - 12.1.2.69) <0B0E30F2-E36A-3FBD-9D31-14B8D2A20369> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEd itor
                     0x1223f8000 -        0x1223fcfff +com.adobe.HandlerProgress.framework (12.1.2 - 12.1.2.69) <9ADC2841-083C-3DCA-BB34-565949086C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
                     0x12240f000 -        0x12241fff7 +com.adobe.HandlerScopes.framework (12.1.2 - 12.1.2.69) <E40CD507-7749-3D75-9585-4803E5EED496> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
                     0x122447000 -        0x1225d1ff7 +com.adobe.HandlerSourceMonitor.framework (12.1.2 - 12.1.2.69) <9AC7779E-369C-3AF6-A256-667AC8F2ADBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonit or
                     0x12279c000 -        0x1227a5ff7 +com.adobe.HandlerStoryPanel.framework (12.1.2 - 12.1.2.69) <5A6FBEB5-467E-3253-BEDC-36C8B3BF1207> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
                     0x1227c5000 -        0x1227f1ff7 +com.adobe.HandlerTimecode.framework (12.1.2 - 12.1.2.69) <110975EB-9974-3598-AF65-39F0449B2F3F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
                     0x122856000 -        0x122b71fff +com.adobe.dvaadameve.framework (12.1.2 - 12.1.2.69) <D839908C-CEB6-3152-AF34-F930AF4F891D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                     0x1231ff000 -        0x1233a5fff +com.adobe.dvaaudiofiltersui.framework (12.1.2 - 12.1.2.69) <734266EF-9DA3-34C2-BB10-1ABDA9103CFA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofiltersui.framework/Versions/A/dvaaudiofiltersui
                     0x1236e5000 -        0x123766fff +com.adobe.ControlSurface.framework (12.1.2 - 12.1.2.69) <EBD39BF2-2EB4-32CD-8CD9-F747A6BD13D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
                     0x123810000 -        0x123830ff7 +com.adobe.OnBoarding.framework (12.1.2 - 12.1.2.69) <4B808FC0-40EE-3DD7-AECE-6936F46C5568> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoarding.framework/Versions/A/OnBoarding
                     0x12388a000 -        0x1239f8ff7 +com.adobe.Batch.framework (12.1.2 - 12.1.2.69) <AF7F59B9-2E08-374C-8599-A40538A29BE8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
                     0x123cda000 -        0x123cf5ff7 +com.adobe.IngestGlue.framework (12.1.2 - 12.1.2.69) <A0A8EB59-2206-3F2E-A0E7-EB43B41314FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
                     0x123d3a000 -        0x123edcfff +com.adobe.headlights.LogSessionFramework (7.4.1.112.46866) <F8E6A446-3724-3F70-A396-E1A01325FE0A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                     0x124078000 -        0x124176ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
                     0x1241a4000 -        0x124248fff +com.adobe.dvascriptingES.framework (12.1.2 - 12.1.2.69) <3483CB3E-1DC2-3486-961F-8520D8A3FB28> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
                     0x124340000 -        0x124384ff7 +com.adobe.dvastorypanel.framework (12.1.2 - 12.1.2.69) <8C9C700C-1C8B-3700-B30A-929AB6303AFD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorypanel.framework/Versions/A/dvastorypanel
                     0x12441f000 -        0x1244abff7 +com.adobe.essentialsoundui.framework (12.1.2 - 12.1.2.69) <AB7B2F5C-D98B-36FD-8CAA-50D896B60C04> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsoundui.framework/Versions/A/essentialsoundui
                     0x1245dd000 -        0x124651ff7 +com.adobe.ScriptLayer.framework (12.1.2 - 12.1.2.69) <408C5B51-D263-3A41-82D3-7F00E0FD95CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
                     0x124fc1000 -        0x124febfff  GLRendererFloat (14.0.16) <32A016EE-63CF-3D07-9BAB-C4EB3E8E479D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                     0x124ff5000 -        0x124ff7ffb  com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                     0x1295d7000 -        0x12977dfff  GLEngine (14.0.16) <E8C60E20-6414-32B2-8964-41882943D9C1> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                     0x12a800000 -        0x12b254ff7  com.apple.driver.AppleIntelKBLGraphicsGLDriver (10.25.17 - 10.2.5) <EFBF3628-9022-3843-9499-0ADE8FC2C9C8> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntel KBLGraphicsGLDriver
                     0x12b780000 -        0x12b781fff +com.adobe.TransmitDesktopAudio.framework (12.1.2 - 12.1.2.69) <DC555A97-F712-317D-9758-29CBCF49B940> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesk topAudio
                     0x12c4a9000 -        0x12c4bbff3  libTraditionalChineseConverter.dylib (70) <EA69A689-C005-3636-B647-A20DE3715E2D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                     0x12c4c4000 -        0x12c4e0ffb  libJapaneseConverter.dylib (70) <F96283F0-C366-30FE-853E-9C5C0F44FE14> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                     0x12c4e6000 -        0x12c4f5ffb  libSimplifiedChineseConverter.dylib (70) <9DF419B1-9049-3FB1-B6BB-85267B8E3B06> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                     0x12fcc4000 -        0x12fcc8fff  libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                     0x12fcd1000 -        0x12fcf7fef +com.mainconcept.mc.enc.dv (10.5 - 10.5.17.5963) <C8D63373-D045-39AA-B486-72076413C2A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
                     0x12fd0c000 -        0x12fd10fff  com.apple.audio.AppleHDAHALPlugIn (279.48 - 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                     0x12fed0000 -        0x12fef2fff  libKoreanConverter.dylib (70) <6C272E7B-5507-3B42-A885-500FED07DDE4> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                     0x1306c1000 -        0x1306c7ff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.17.5963) <8339AD25-167D-3BFE-A37A-D914F6A10B32> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
                     0x130900000 -        0x13098efff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (10.25.17 - 10.2.5) <1DABF9B1-3110-31CC-A50B-1351183E4AF3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleInte lKBLGraphicsMTLDriver
                     0x135e40000 -        0x136063fe7 +REDR3D.dylib (0) <3F88935C-39CB-3D8F-AA68-478BEF1CC694> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDR3D.dylib
                     0x137344000 -        0x13741afff +REDCuda.dylib (0) <DC0FCD27-04BD-319F-A701-7369107E056E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDCuda.dylib
                     0x138a1e000 -        0x138c0fff7 +REDOpenCL.dylib (0) <D54DBEDF-8CEB-3FFF-9C86-D92670D10D66> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDOpenCL.dylib
                     0x138d18000 -        0x138d1aff7 +T.dylib (0) <291DE13A-BFAF-37FF-A00C-B493F87B2817> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/T.dylib
                     0x139d80000 -        0x139daaff7 +com.adobe.EASequenceRenderer.framework (12.1.2 - 12.1.2.69) <BA94E812-51CE-3D7C-8936-F88F0E00EAD3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRend erer
                     0x13a1e4000 -        0x13a260ff7 +com.adobe.ExporterMPEG2.framework (12.1.2 - 12.1.2.69) <9C5C4423-F378-30C1-AB6B-A714BAFBD550> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
                     0x13a2e6000 -        0x13a2f5fff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.17.5963) <8011D934-1E46-3917-A050-F1BD6C7DB12A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
                     0x13a325000 -        0x13a515fe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.17.5963) <111832A9-C088-350C-8096-0EDF0BEA00D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
                     0x13a589000 -        0x13a691ff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.17.5963) <FA2E5FB7-A906-38AC-A19D-16D3B5B031E2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
                     0x13a999000 -        0x13aae5fe7 +com.adobe.ExporterMPEG4.framework (12.1.2 - 12.1.2.69) <85D17E66-6CD9-3C84-A9B3-FDF3AA8DF0C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
                     0x13ac05000 -        0x13add3fff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.17.5963) <6DC87BB2-C6B8-3606-B594-4A456FD44149> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
                     0x13ae47000 -        0x13b1c0fff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.17.5963) <16AA44F7-D279-35D8-AD8D-7D48BFB06E65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
                     0x13b31a000 -        0x13b3c0fef +com.adobe.IPPMPEGDecoder.framework (12.1.2 - 12.1.2.69) <FB14E648-0856-368C-A42B-E0138F91A643> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
                     0x13b780000 -        0x13b8b6ff7 +com.adobe.ExporterMXF.framework (12.1.2 - 12.1.2.69) <AF061E97-35D2-3ACB-85A1-F3233147E223> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
                     0x13b9f5000 -        0x13ba1fff7 +libMOG_Framework.5.0.14.dylib (0) <4D5416B3-194E-30A2-B35B-7F500E754E1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.14.dylib
                     0x13ba9d000 -        0x13c227fff +libMXF_SDK.5.0.14.dylib (0) <29E0F2C6-A091-3C82-9962-A0DB3071FC4E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.14.dylib
                     0x13d47d000 -        0x13d527fff +com.adobe.ExporterXDCAMHD.framework (12.1.2 - 12.1.2.69) <89CE6B00-959C-3315-866A-D15E348BCC18> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
                     0x13d5cf000 -        0x13d5d9fff +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.5963) <1727D243-B2DD-3047-B68A-98BCA1A00A7E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
                     0x13d5df000 -        0x13d5f7fff +com.adobe.ImporterAVFoundation.framework (12.1.2 - 12.1.2.69) <A24E42DF-FAAA-31A2-9AD7-24741C960F80> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFo undation
                     0x13d618000 -        0x13d648ff7 +com.adobe.PlatformAudioCodecs.framework (12.1.2 - 12.1.2.69) <D09914DB-85F8-30E1-B618-9ED666CEAD6C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
                     0x13d67a000 -        0x13d769fff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.17.0258) <C86FD5AF-C224-31B6-B073-023A5217E3F9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
                     0x13d77b000 -        0x13d78eff7 +com.adobe.ImporterDataStream.framework (12.1.2 - 12.1.2.69) <E78A8666-3F9A-3169-9239-F93497100971> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterDataStream.bundle/Contents/MacOS/ImporterDataSt ream
                     0x13d7b4000 -        0x13d855fff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 018 - 79.162672) <E5812E75-AF80-3066-B077-2A74FCF23C5A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
                     0x13d8fd000 -        0x13d980ff7 +com.adobe.ImporterRED.framework (12.1.2 - 12.1.2.69) <1CEDD72E-20C3-31B1-A2E6-A216D01CC5E6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
                     0x13da13000 -        0x13dbe3fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
                     0x13ddb3000 -        0x13ddc1ff7 +com.adobe.PremiereFiltersMetaPlugin.framework (12.1.2 - 12.1.2.69) <FA8AE1CB-9997-36C8-8AAC-F11CBE825C94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereF iltersMetaPlugin
                     0x13ddd3000 -        0x13dde2ff7 +com.adobe.TransitionsMetaPlugin.framework (12.1.2 - 12.1.2.69) <AF8E096B-A87A-3F44-868E-4B7533602178> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMe taPlugin
                     0x13ddf5000 -        0x13e24afff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
                     0x13e70d000 -        0x13e71fff7 +com.adobe.TransmitDV.framework (12.1.2 - 12.1.2.69) <F888C04F-C05B-3901-AF92-100FB4FBC18D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
                     0x13e73d000 -        0x13e767ff7  com.apple.AVCVideoServices (1.0 - 42) <FEAE1854-5F7E-3B3E-B6EA-BD825B3CB467> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                     0x13e7a2000 -        0x13e7a9ff7 +com.adobe.TransmitFullScreen.framework (12.1.2 - 12.1.2.69) <B81D958C-5209-3296-95BA-377CCFD5A52B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullSc reen
                     0x13e7b8000 -        0x13e814fff +com.adobe.PlayerMediaCore.framework (12.1.2 - 12.1.2.69) <A50C7094-8BB4-3254-9D8B-ECD64499B48B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
                     0x13e87e000 -        0x13e8b1fff +com.adobe.RendererCPU.framework (12.1.2 - 12.1.2.69) <D6F9D3C4-B510-36D9-B730-DEA05C755E47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
                     0x13e8f2000 -        0x13eacafff +com.adobe.TransmitScopes.framework (12.1.2 - 12.1.2.69) <C390FFD2-1720-35AF-9413-83110826D152> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
                     0x1402ef000 -        0x140372fff +com.adobe.TransmitVR.framework (12.1.2 - 12.1.2.69) <EBAE97DE-9EAC-3484-BD5E-7F2D7419B9CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitVR.bundle/Contents/MacOS/TransmitVR
                     0x140412000 -        0x140461fff +com.adobe.ExporterQuickTimeHost.framework (12.1.2 - 12.1.2.69) <5A393D08-B475-384B-979C-879E85E127DB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQui ckTimeHost
                     0x1404a3000 -        0x1404bbff7 +com.adobe.QTWriter.framework (12.1.2 - 12.1.2.69) <31B98252-B41F-35AE-86F6-D9BB27EFA16D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
                     0x14060c000 -        0x14064bfff +com.adobe.ExporterMPEGPreview.framework (12.1.2 - 12.1.2.69) <96227B34-145C-359F-9382-2C9E5B69918B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGP review
                     0x140682000 -        0x1406bbff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.17.5963) <D4FB82FE-A372-38EA-B45F-5ACC4A72A273> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
                     0x14103f000 -        0x1410acfff +com.adobe.ICUData (4.0 - 3.61) <604A18BB-29F6-34EC-98D4-3CC65EA9298C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                     0x1410c1000 -        0x1411a6fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.39392 - 3.8.0.39392) <B14D700D-5B31-353D-947A-CCE76A2CF281> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                     0x141258000 -        0x141270fff +M.dylib (0) <BA9E08E4-7A64-32C8-901E-7834B7B2C32B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/M.dylib
                     0x141284000 -        0x141287ff3 +VAL.dylib (0) <E6CCE008-C8CE-39B6-B4C9-D0B25ADA3EE2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VAL.dylib
                     0x141298000 -        0x141365ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.39530) <5C13ACD4-BD1F-3DF5-B8A7-B388E27D7660> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                     0x1413ad000 -        0x1413deff7 +com.adobe.ARE (AdobeARE 1.5.02.40104 - 1.5.02.40104) <C6C3440E-3FD8-36A9-9D5E-90E999486EE6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                     0x1413ef000 -        0x14174ffff +com.adobe.MPS (AdobeMPS 5.8.1.40104 - 5.8.1.40104) <02FC8477-213B-310D-8330-A648E85BE77C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                     0x1419e2000 -        0x1421acfff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.40112) <4EB2970C-AC64-3E1B-B67A-4B7B23581025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                     0x14288f000 -        0x1428b4fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.39392 - 3.8.0.39392) <FC4F241D-05A6-36E1-8CFE-8FDC58F2AB2B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                     0x1428e1000 -        0x142907fff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.39392 - 3.8.0.39392) <A2837D5A-14F4-3A5C-BD33-2DFA5039CF99> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedE xpat
                     0x142af4000 -        0x142b96ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                     0x142bc1000 -        0x142bc8fff +LIST.dylib (0) <D20BF7AA-F2BF-3AFD-B47A-BFCBBB8D1376> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LIST.dylib
                     0x142bd9000 -        0x142be6fff +BEZ.dylib (0) <D365A64F-DA8F-3582-8D7F-F7487986C909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEZ.dylib
                     0x142bf1000 -        0x142bf5fff +BM.dylib (0) <8F54C751-9641-305B-AD33-838C90FEF4AD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BM.dylib
                     0x142fac000 -        0x143030fff +U.dylib (0) <43C3CC11-0C31-32B3-BF12-375624B4BCC6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/U.dylib
                     0x1431eb000 -        0x1432d7ff7 +MEE.dylib (0) <83D216FE-DD20-38FC-BCFE-218287BB4559> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MEE.dylib
                     0x1433d0000 -        0x143427ff7 +display.dylib (0) <23CB95FF-9595-3DC1-81D1-97C343EB4E1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/display.dylib
                     0x143475000 -        0x143495fff +FILE.dylib (0) <0995DABB-6017-3BB9-A9D3-D28ACE7BC3FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FILE.dylib
                     0x1434cb000 -        0x143510fff +SLU.dylib (0) <30AD4361-3AF8-3F0B-8F3B-9534F6AEDEAA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SLU.dylib
                     0x14359f000 -        0x1435b7fff +PREF.dylib (0) <C6F46919-5B11-35E8-9D31-7B058C54ACA1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREF.dylib
                     0x1435d9000 -        0x14360bff7 +MC.dylib (0) <8745408B-9DCB-3DC2-B648-33E43349ED36> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MC.dylib
                     0x14365c000 -        0x14366dfff +PLUG.dylib (0) <73416E55-A2C3-398D-AF2F-BCF809F5209F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PLUG.dylib
                     0x143686000 -        0x1436bbff7 +COR.dylib (0) <2DA5CF16-8294-3FCB-B452-33B436060C1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/COR.dylib
                     0x143716000 -        0x1439ecff7 +PF.dylib (0) <718ACB33-4985-3756-95E1-6CECFCDE9458> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PF.dylib
                     0x143b67000 -        0x144044fff +TXT.dylib (0) <565FC3ED-E9E3-38D4-BD34-4769C298410C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TXT.dylib
                     0x14461b000 -        0x14466bff7 +TDL.dylib (0) <9EB1F420-1D58-35F5-9A88-D2412C19CE27> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDL.dylib
                     0x1446ab000 -        0x1446f9ff7 +TDB.dylib (0) <AE1B295A-3190-34BA-8C60-3EBE8859AC23> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDB.dylib
                     0x144766000 -        0x1447a1ff7 +OM.dylib (0) <1FD80A95-3F36-3B83-8E75-E480794E78C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OM.dylib
                     0x1447df000 -        0x144804fff +P.dylib (0) <CBFB6FB1-CD61-37EB-8402-575D62FB394B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/P.dylib
                     0x14481e000 -        0x144847fff +PREM.dylib (0) <1C98433E-50AA-3690-B57B-0B284C119A0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREM.dylib
                     0x144899000 -        0x1448e8fff +SND.dylib (0) <E9C7F81E-F718-38EF-A89F-4AA5B5B7302A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SND.dylib
                     0x144966000 -        0x144995fff +RG.dylib (0) <83F4B8FF-28C3-3F37-B478-08C66EDC09F5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RG.dylib
                     0x1449d7000 -        0x144a2bff7 +MSK.dylib (0) <1A21A0F7-CD8A-326C-A3CA-2E08FED05C3D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MSK.dylib
                     0x144a7e000 -        0x144a96fff +PR.dylib (0) <004CB06D-C1BE-3159-B6CC-A985D57FC92C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PR.dylib
                     0x144acb000 -        0x144ad2fff +SAM.dylib (0) <FDF6A8ED-6054-3E8F-B0AC-199D0F63A598> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SAM.dylib
                     0x14aa0e000 -        0x14ac63fff +PIN.dylib (0) <AEB340E2-1C60-3853-8702-9B1247AB3795> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PIN.dylib
                     0x14aec2000 -        0x14af69ff7 +FLT.dylib (0) <1EADE55E-4FB0-3F22-B848-4BBAB0B34204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLT.dylib
                     0x14b0a9000 -        0x14b162fff +FRP.dylib (0) <37F400AB-08B8-3868-8841-FB0CE30935B5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FRP.dylib
                     0x14b256000 -        0x14b278fff +SegMatServices.dylib (0) <1DB59F6A-8061-3E11-9D08-7997652F766F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SegMatServices.dylib
                     0x14b2c2000 -        0x14ba27ff7 +BEE.dylib (0) <E32F7614-52EB-3EEF-AACF-BCF02D5AD109> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEE.dylib
                     0x14c6a7000 -        0x14c6f0ff7 +FLO.dylib (0) <4D52795F-3A52-39E4-8CCA-DB1DE1D1A4A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLO.dylib
                     0x14c712000 -        0x14c74cfef +libtbb.dylib (0) <10144FAB-48B9-34ED-833B-A3F7E65BC4ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbb.dylib
                     0x14c78f000 -        0x14c7b3fff +libtbbmalloc.dylib (0) <4AED21B6-C175-31A4-BA52-70A811C1B0F8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbbmalloc.dylib
                     0x14c7eb000 -        0x14c9fdfcf +com.adobe.AIDE (1.5.0 - 1.5.0.40084) <F51445AC-916B-3012-8872-9E633C7AF505> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                     0x14ca2d000 -        0x14cae8fff +com.adobe.dvaplayer.framework (12.1.2 - 12.1.2.69) <4DE4839D-0EC6-3C20-947C-3BACF0B5CB1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                     0x14cc72000 -        0x14cc83ff7 +com.adobe.GPUKernels.framework (12.1.2 - 12.1.2.69) <2BAAC10B-71D2-35A3-9E91-E163A5D2EE88> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
                     0x14cc92000 -        0x14cca9ff7 +com.adobe.eaurl.framework (12.1.2 - 12.1.2.69) <317BA78E-888B-3312-AA15-77E2E787720A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
                     0x14ccd6000 -        0x150856fdf +com.adobe.psl (AdobePSL 15.1.0.38776 - 15.1.0.38776) <22036635-21E0-35A5-8103-CCD034766DE3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                     0x150d4e000 -        0x150e3fff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                     0x150e8c000 -        0x151d32fe7 +libmkl_intel_lp64.dylib (0) <3A603969-1A39-3CAB-8CED-1350DFA6DFC7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_lp64.dylib
                     0x151f0a000 -        0x153836fff +libmkl_intel_thread.dylib (0) <B03E1F34-4E4E-3FBE-A9DE-14D37A5E440A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_thread.dylib
                     0x153eac000 -        0x1555d0f4f +libmkl_core.dylib (0) <ED21EAB7-AFC8-3C50-8480-E28823A5D4CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_core.dylib
                     0x155874000 -        0x155a46fff +libicui18n.dylib (0) <1B56F6C7-045A-3A03-99C1-57D1A91A7909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicui18n.dylib
                     0x155bf6000 -        0x155d3afff +libicuuc.dylib (0) <77E17D41-9214-3C2D-B526-CE0D81FAEC05> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicuuc.dylib
                     0x155e0c000 -        0x155e1bfff +libv8_libbase.dylib (0) <7CD26441-BBE7-3BFF-9935-7BCC739ADE37> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libbase.dylib
                     0x155e35000 -        0x155e40fff +libv8_libplatform.dylib (0) <9EA88668-D5D6-3FC1-B9C6-CE1E53D228CE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libplatform.dylib
                     0x155e53000 -        0x156902ff7 +libv8.dylib (0) <1A68B9C1-DC1C-3A70-83A4-73890130CAF9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8.dylib
                  0x7fff8e0e7000 -     0x7fff8e42cff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                  0x7fff8fc5e000 -     0x7fff8fc62ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <00D11B5C-E29F-3938-A8DD-D40A26201821> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                  0x7fff8fc63000 -     0x7fff8fe24fff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                  0x7fff8fe25000 -     0x7fff8fec7ff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                  0x7fff8ff92000 -     0x7fff8ff92fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                  0x7fff8ff93000 -     0x7fff8ffaaffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                  0x7fff8ffab000 -     0x7fff904c4feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                  0x7fff904c5000 -     0x7fff90636ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                  0x7fff90637000 -     0x7fff9064bffb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                  0x7fff9064c000 -     0x7fff90a42fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                  0x7fff90a43000 -     0x7fff90a59fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                  0x7fff90a5a000 -     0x7fff90a60fff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                  0x7fff90a61000 -     0x7fff90a75ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                  0x7fff90a76000 -     0x7fff90bfdfe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                  0x7fff90bfe000 -     0x7fff90cb0fff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                  0x7fff90cb1000 -     0x7fff90cb1fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                  0x7fff90f70000 -     0x7fff91d49ff3  com.apple.AppKit (6.9 - 1504.83.101) <12BF4F22-5FDE-309E-8A19-BC97CC293D46> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff91d5b000 -     0x7fff91d5bfff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                  0x7fff91d5c000 -     0x7fff91dcaff7  com.apple.ApplicationServices.ATS (377 - 422.3) <73C230CF-3213-3DCA-B528-664FEC76A90C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                  0x7fff91e64000 -     0x7fff91f93fff  libFontParser.dylib (194.13) <BE507D17-17D0-37E8-A317-6921118BD283> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                  0x7fff91f94000 -     0x7fff91fdefff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                  0x7fff9203b000 -     0x7fff9206efff  libTrueTypeScaler.dylib (194.13) <F982F582-E2C8-3902-9C79-BB3F4B8199D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                  0x7fff920db000 -     0x7fff92185ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                  0x7fff92186000 -     0x7fff921d7fff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                  0x7fff921d8000 -     0x7fff921e7ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                  0x7fff921e8000 -     0x7fff92235fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                  0x7fff92236000 -     0x7fff92271fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                  0x7fff92272000 -     0x7fff9227dfff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                  0x7fff9227e000 -     0x7fff9248aff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <AF56E94D-5F38-3718-99A3-D23BA0B56BA9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x7fff9248b000 -     0x7fff9248bfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <860636FF-F3B1-32AB-BD6E-75357FB16625> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                  0x7fff925f4000 -     0x7fff929d0fff  com.apple.CFNetwork (811.8 - 811.8) <3FB812CB-F4BF-3C47-B772-042FC4D59A33> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                  0x7fff929ea000 -     0x7fff929eafff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                  0x7fff929eb000 -     0x7fff929eefff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                  0x7fff929ef000 -     0x7fff92cf8fff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x7fff92cf9000 -     0x7fff92cfcff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                  0x7fff92cfd000 -     0x7fff92d02fff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                  0x7fff92d03000 -     0x7fff92d9aff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                  0x7fff92d9b000 -     0x7fff92db5fff  com.apple.openscripting (1.7 - 172.1) <78F3256B-AF4C-324A-A591-ECA4443A469F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                  0x7fff92db6000 -     0x7fff92db7ff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                  0x7fff92db8000 -     0x7fff92dbaff7  com.apple.securityhi (9.0 - 55006) <3CC6C7D1-613E-36A9-8159-113A634AEE6C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                  0x7fff92dbb000 -     0x7fff92dc1ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                  0x7fff92dc2000 -     0x7fff92ea1ffb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                  0x7fff92ea2000 -     0x7fff92ea2fff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                  0x7fff92fec000 -     0x7fff93079fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                  0x7fff9307a000 -     0x7fff9308dfff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                  0x7fff9308e000 -     0x7fff93389fff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                  0x7fff9338a000 -     0x7fff93437ff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                  0x7fff93438000 -     0x7fff938d1ff7  com.apple.CoreFoundation (6.9 - 1349.90) <F07A2387-602E-3D9E-8708-3B3430BD7D82> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff938d2000 -     0x7fff93f54fff  com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                  0x7fff93f55000 -     0x7fff94198ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                  0x7fff94199000 -     0x7fff941feff7  com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                  0x7fff941ff000 -     0x7fff942b0fff  com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                  0x7fff942b1000 -     0x7fff942fcff7  com.apple.CoreMediaIO (805.0 - 4932) <B12C56E0-2FE8-3734-8C45-4B03CAA18A0B> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                  0x7fff942fd000 -     0x7fff942fdfff  com.apple.CoreServices (775.19 - 775.19) <5046FF69-034E-3570-AC30-D14AA469F669> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                  0x7fff942fe000 -     0x7fff9434ffff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                  0x7fff94350000 -     0x7fff9462bff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                  0x7fff9462c000 -     0x7fff9465ffff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                  0x7fff94660000 -     0x7fff94668ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                  0x7fff94669000 -     0x7fff947d5ff7  com.apple.LaunchServices (775.19 - 775.19) <76F27409-F3E0-31A7-BA40-060FBD10CB8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                  0x7fff947d6000 -     0x7fff94886ffb  com.apple.Metadata (10.7.0 - 1075.40) <B734F567-EC70-39AF-BB86-46C97065580F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                  0x7fff94887000 -     0x7fff948e6fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <E6EB5564-B9AB-366F-ACF0-723D394482C0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                  0x7fff948e7000 -     0x7fff94957fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                  0x7fff94958000 -     0x7fff9499dff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                  0x7fff94a26000 -     0x7fff94b73ffb  com.apple.CoreText (352.0 - 544.16) <543AFBA5-4E6B-3F81-BC45-81ED9707BD9C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                  0x7fff94b74000 -     0x7fff94ba9ff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                  0x7fff94baa000 -     0x7fff94c1bffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <64338DCB-8204-3B62-A9C5-0CDDC89F60D6> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                  0x7fff94c5a000 -     0x7fff94d18ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                  0x7fff94d19000 -     0x7fff94d1efff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                  0x7fff94eb0000 -     0x7fff95256fff  com.apple.Foundation (6.9 - 1349.91) <F24B1521-454A-3AE7-B41F-F8FA95BA0490> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                  0x7fff95282000 -     0x7fff952b3ff7  com.apple.GSS (4.0 - 2.0) <30A77A95-CBD4-3BD7-9BFF-8426071F5D9D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                  0x7fff95373000 -     0x7fff95416fff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <5C79A832-84A9-3DC0-9F46-F2B10A3072DC> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                  0x7fff95417000 -     0x7fff954adff7  com.apple.framework.IOKit (2.0.2 - 1324.60.4) <454036AD-86AA-3ABB-8C53-B5F654A6824D> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  0x7fff954ae000 -     0x7fff954b4ffb  com.apple.IOSurface (159.12 - 159.12) <E3D6FCED-F938-30A3-AD08-0998B674A492> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                  0x7fff95507000 -     0x7fff95667fef  com.apple.ImageIO.framework (3.3.0 - 1599.13) <443879A7-48C6-37ED-AC0B-166EEEABA662> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                  0x7fff95668000 -     0x7fff9566cfff  libGIF.dylib (1599.13) <11C5D9D7-B8A1-3D53-BA50-B25976FE6379> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                  0x7fff9566d000 -     0x7fff9575dff7  libJP2.dylib (1599.13) <C495FB08-0CD2-36FC-8196-FAD3D598A010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                  0x7fff9575e000 -     0x7fff95781ffb  libJPEG.dylib (1599.13) <D22E2431-76A5-39B4-AF0B-174CF282A1CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                  0x7fff95782000 -     0x7fff957a9ff7  libPng.dylib (1599.13) <561865FA-A51B-3EFF-ABFF-B4566B90B1A2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                  0x7fff957aa000 -     0x7fff957acff3  libRadiance.dylib (1599.13) <6559253B-8FE2-3884-BC93-95BB7705A6D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                  0x7fff957ad000 -     0x7fff957fbffb  libTIFF.dylib (1599.13) <8FC594B3-6BBF-3A70-9994-203E9B330B5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                  0x7fff95959000 -     0x7fff96563fff  com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                  0x7fff96564000 -     0x7fff9657dff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                  0x7fff9657e000 -     0x7fff965b4fff  com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                  0x7fff96807000 -     0x7fff9680dfff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                  0x7fff96823000 -     0x7fff96d5cff7  com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                  0x7fff96d5d000 -     0x7fff96db8fff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                  0x7fff96db9000 -     0x7fff96dd1fff  com.apple.MetalKit (1.0 - 76.1) <BA9002FF-00C1-32C8-BC06-634C81C3DB02> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
                  0x7fff96dd2000 -     0x7fff97651fff  com.apple.ModelIO (1.0 - 1) <366820F9-6795-3D93-AAF2-630D94B395E6> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
                  0x7fff976a1000 -     0x7fff976a9fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                  0x7fff97880000 -     0x7fff97888ff7  libcldcpuengine.dylib (2.8.5) <8086D6FA-2006-3582-B20E-4209D81ACC58> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                  0x7fff97889000 -     0x7fff978d7ff3  com.apple.opencl (2.8.6 - 2.8.6) <A6140AC4-7579-3AC2-B7EE-08A8899BC811> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                  0x7fff978d8000 -     0x7fff978f1ffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                  0x7fff978f2000 -     0x7fff978fdff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                  0x7fff978fe000 -     0x7fff97900fff  libCVMSPluginSupport.dylib (14.0.16) <AA2468D1-9169-3424-8EE4-0470E9050E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                  0x7fff97901000 -     0x7fff97904ff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                  0x7fff97905000 -     0x7fff97909fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                  0x7fff9790a000 -     0x7fff97913ff7  libGFXShared.dylib (14.0.16) <170D07F3-2D30-3D4B-80A0-971E0A765709> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                  0x7fff97914000 -     0x7fff9791ffff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                  0x7fff97920000 -     0x7fff9795cff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                  0x7fff9795d000 -     0x7fff97ad3ff3  libGLProgrammability.dylib (14.0.16) <A81F1B95-445C-3191-ADB1-07BAEA5A204D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                  0x7fff97ad4000 -     0x7fff97b15ff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                  0x7fff9847d000 -     0x7fff9848bfff  com.apple.opengl (14.0.16 - 14.0.16) <B428BB89-8FE1-3527-BF3E-F8F0A1060884> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                  0x7fff98fdd000 -     0x7fff991ddfff  com.apple.QuartzCore (1.11 - 453.39.4) <31B739DC-81E1-3249-9A43-E501FECA8240> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                  0x7fff991de000 -     0x7fff99233fff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                  0x7fff9972e000 -     0x7fff99745ff7  com.apple.ScriptingBridge (1.3.3 - 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
                  0x7fff99746000 -     0x7fff99a48ff7  com.apple.security (7.0 - 57740.60.20) <A7DA9073-C3C2-3FEA-B531-471AB9F40609> /System/Library/Frameworks/Security.framework/Versions/A/Security
                  0x7fff99a49000 -     0x7fff99abefff  com.apple.securityfoundation (6.0 - 55132.50.7) <1276FFB8-05B8-3760-9EA7-2037B7FE2FBC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                  0x7fff99ae9000 -     0x7fff99aecff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                  0x7fff99e73000 -     0x7fff99ee2ff7  com.apple.SystemConfiguration (1.14 - 1.14) <B471E0FA-3AC6-3A34-82C8-4FCF4B389368> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                  0x7fff99ee3000 -     0x7fff9a291fff  com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                  0x7fff9bfbe000 -     0x7fff9bfc5ffb  com.apple.APFS (1.0 - 1) <6E79797E-26BD-3E49-891C-03B223F7BD59> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
                  0x7fff9c739000 -     0x7fff9c754ff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                  0x7fff9c755000 -     0x7fff9c762ff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                  0x7fff9c763000 -     0x7fff9c785ffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <6C01014A-49D0-312D-A4EF-BFB5B7882F9C> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                  0x7fff9c786000 -     0x7fff9c795feb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                  0x7fff9c87f000 -     0x7fff9c90a97f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                  0x7fff9c93a000 -     0x7fff9c942ffb  com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                  0x7fff9c947000 -     0x7fff9c999fff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <B272678B-2EA8-3F04-BB0F-3CE62D1E4F58> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                  0x7fff9c9a3000 -     0x7fff9c9aaff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                  0x7fff9cd3d000 -     0x7fff9cdbbff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                  0x7fff9cde4000 -     0x7fff9ce21ffb  com.apple.bom (14.0 - 194.1) <0CBECAF1-B5E0-302F-99EC-D7ED14E12B84> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                  0x7fff9da46000 -     0x7fff9da6dff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                  0x7fff9da6e000 -     0x7fff9dafaff7  com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                  0x7fff9e392000 -     0x7fff9e39bffb  com.apple.CommonAuth (4.0 - 2.0) <44E4467E-90BB-3CC4-9E57-9B09D7E90081> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                  0x7fff9e520000 -     0x7fff9e8ffff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                  0x7fff9e900000 -     0x7fff9e930fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                  0x7fff9e9cb000 -     0x7fff9e9d3ffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                  0x7fff9eae4000 -     0x7fff9eaf4fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                  0x7fff9ee2f000 -     0x7fff9ee5fff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                  0x7fff9f0f0000 -     0x7fff9f17fff7  com.apple.CoreSymbolication (62046) <9685A34A-C6FD-3681-8F7E-211D48298DD2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                  0x7fff9f180000 -     0x7fff9f2bffe7  com.apple.coreui (2.1 - 431.3) <8D0FA478-9B6C-3D6D-8ADF-8677BA0BF134> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                  0x7fff9f2c0000 -     0x7fff9f390ff3  com.apple.CoreUtils (5.1 - 510.31) <7FBB03B5-13E2-3284-B5DF-6C73AD774479> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                  0x7fff9f3e0000 -     0x7fff9f445ff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <926A9CE7-6F3F-3EB6-A392-81FF485F0B7A> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                  0x7fff9f446000 -     0x7fff9f454ff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                  0x7fff9f4c6000 -     0x7fff9f4d0ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                  0x7fff9f4d1000 -     0x7fff9f4d5ff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDispla y
                  0x7fff9f50b000 -     0x7fff9f580ffb  com.apple.datadetectorscore (7.0 - 539.1) <84F04DEF-DF0A-3F93-AEE9-B6FAC781164B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                  0x7fff9f5bc000 -     0x7fff9f5fbfff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                  0x7fff9f5fc000 -     0x7fff9f70dfff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                  0x7fff9f712000 -     0x7fff9f7e7fff  com.apple.DiskImagesFramework (444.50.16 - 444.50.16) <533370F7-DB79-311C-99DE-6A04BBF72EFD> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                  0x7fff9f8a0000 -     0x7fff9f8a2ffb  com.apple.EFILogin (2.0 - 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                  0x7fff9f9f5000 -     0x7fff9fe26ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                  0x7fffa117d000 -     0x7fffa117dfff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                  0x7fffa118a000 -     0x7fffa1195ff3  libGPUSupportMercury.dylib (14.0.16) <1216909A-E38E-335F-9F46-9362753AE0D1> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                  0x7fffa144e000 -     0x7fffa146afff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                  0x7fffa1483000 -     0x7fffa1b35fff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                  0x7fffa1b7b000 -     0x7fffa1bf1ff3  com.apple.Heimdal (4.0 - 2.0) <9541C717-96FF-32D3-8F0B-5048525DAA70> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                  0x7fffa220c000 -     0x7fffa2213ffb  com.apple.IOAccelerator (311.16.2 - 311.16.2) <96FA28B6-B03D-3A5E-AF07-0AE4486D2968> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                  0x7fffa2215000 -     0x7fffa2229ff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                  0x7fffa222a000 -     0x7fffa224cfff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                  0x7fffa22e8000 -     0x7fffa22f8ff3  com.apple.IntlPreferences (2.0 - 216) <15B0DF1F-24C3-3A51-9032-1DD150B7D321> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                  0x7fffa2333000 -     0x7fffa24eafff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                  0x7fffa25e6000 -     0x7fffa26a8ff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                  0x7fffa2b5a000 -     0x7fffa2b5dfff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                  0x7fffa2c36000 -     0x7fffa2c6aff3  com.apple.MediaKit (16 - 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                  0x7fffa2e0b000 -     0x7fffa2e84ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
                  0x7fffa2e96000 -     0x7fffa2ff1fdf  com.apple.mobiledevice (988.70.1.100.34 - 988.70.1.100.34) <5D9B7AC8-4B6C-3CBF-BCB1-558D2B754C21> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
                  0x7fffa3011000 -     0x7fffa3039ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <E2FE1821-C7CC-3C35-BEB3-6DC693F5128D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                  0x7fffa30eb000 -     0x7fffa30f6fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                  0x7fffa39ce000 -     0x7fffa3a0fff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <ED3CFDFC-878E-30C2-929B-C2CD43D702DE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                  0x7fffa40bc000 -     0x7fffa40f6ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                  0x7fffa40f7000 -     0x7fffa4111fff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                  0x7fffa4112000 -     0x7fffa4121ff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                  0x7fffa412a000 -     0x7fffa414dff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                  0x7fffa4e17000 -     0x7fffa4e1afff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                  0x7fffa4ea9000 -     0x7fffa4f36fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                  0x7fffa4f57000 -     0x7fffa51bdfeb  com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                  0x7fffa539c000 -     0x7fffa53a8ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                  0x7fffa5a94000 -     0x7fffa5b08fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                  0x7fffa5f47000 -     0x7fffa5f4dff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                  0x7fffa5fd9000 -     0x7fffa609fff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                  0x7fffa6113000 -     0x7fffa6114fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                  0x7fffa6115000 -     0x7fffa62a5ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                  0x7fffa6d74000 -     0x7fffa6e34fff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                  0x7fffa727f000 -     0x7fffa7285fff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                  0x7fffa7356000 -     0x7fffa7358ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                  0x7fffa73ad000 -     0x7fffa73c8ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
                  0x7fffa73c9000 -     0x7fffa73d4fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
                  0x7fffa73d5000 -     0x7fffa7465ff7  libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
                  0x7fffa7466000 -     0x7fffa7467ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
                  0x7fffa7468000 -     0x7fffa767bfff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
                  0x7fffa7697000 -     0x7fffa769efff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
                  0x7fffa769f000 -     0x7fffa769ffff  libOpenScriptingUtil.dylib (172.1) <0F1BA407-97D1-36F6-882D-A355EAAD5E00> /usr/lib/libOpenScriptingUtil.dylib
                  0x7fffa76a0000 -     0x7fffa76a4ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
                  0x7fffa76a5000 -     0x7fffa76a6ffb  libSystem.B.dylib (1238.60.2) <03D8D904-05E2-3A15-B14E-3472703550DC> /usr/lib/libSystem.B.dylib
                  0x7fffa7712000 -     0x7fffa773dff3  libarchive.2.dylib (41.70.2) <907D1FB1-9A65-33F5-AFC8-0B6E5AE9D83A> /usr/lib/libarchive.2.dylib
                  0x7fffa773e000 -     0x7fffa77bafc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
                  0x7fffa77be000 -     0x7fffa77beff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
                  0x7fffa77bf000 -     0x7fffa77cfff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
                  0x7fffa77d0000 -     0x7fffa77deff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
                  0x7fffa77df000 -     0x7fffa7835ff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
                  0x7fffa7836000 -     0x7fffa785fff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
                  0x7fffa7860000 -     0x7fffa7870ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
                  0x7fffa7871000 -     0x7fffa7887fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
                  0x7fffa7888000 -     0x7fffa7888ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
                  0x7fffa7889000 -     0x7fffa788aff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
                  0x7fffa7944000 -     0x7fffa7a28ff7  libcrypto.0.9.8.dylib (64.50.7) <B34BC0FA-18ED-37C5-9D46-393803CADEBB> /usr/lib/libcrypto.0.9.8.dylib
                  0x7fffa7bba000 -     0x7fffa7bc5fff  libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
                  0x7fffa7bc6000 -     0x7fffa7c19ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
                  0x7fffa7c1a000 -     0x7fffa7c6cfff  libcurl.4.dylib (95.70.4) <D81AEB1D-8501-3EEC-9651-D6D476C2A387> /usr/lib/libcurl.4.dylib
                  0x7fffa7c6d000 -     0x7fffa7c74ff3  libdscsym.dylib (148.3) <2A78774F-6679-3B72-9903-B295B9825872> /usr/lib/libdscsym.dylib
                  0x7fffa7c96000 -     0x7fffa7c96fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
                  0x7fffa7ca4000 -     0x7fffa7ca5fff  libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
                  0x7fffa7ca6000 -     0x7fffa7cabff7  libheimdal-asn1.dylib (498.50.9) <92C953A2-5E1D-39E9-875E-92F29A12D6FB> /usr/lib/libheimdal-asn1.dylib
                  0x7fffa7cac000 -     0x7fffa7d9eff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
                  0x7fffa7d9f000 -     0x7fffa7fc4ffb  libicucore.A.dylib (57167.0.1) <E720801C-2D92-3108-B853-469551EDF21F> /usr/lib/libicucore.A.dylib
                  0x7fffa7fca000 -     0x7fffa7fcbfff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
                  0x7fffa7fcc000 -     0x7fffa7fe5ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
                  0x7fffa7fe6000 -     0x7fffa7ffcff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
                  0x7fffa7ffd000 -     0x7fffa82a5ff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
                  0x7fffa82d8000 -     0x7fffa8352ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
                  0x7fffa8353000 -     0x7fffa8725047  libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
                  0x7fffa8728000 -     0x7fffa872cfff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
                  0x7fffa872d000 -     0x7fffa875efff  libpcap.A.dylib (67.60.2) <B2D36AD8-D5C8-3875-AC81-4787A15E44C2> /usr/lib/libpcap.A.dylib
                  0x7fffa877b000 -     0x7fffa8797ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
                  0x7fffa8798000 -     0x7fffa87d1fff  libsandbox.1.dylib (592.70.2) <1A879867-1FB4-382F-8139-CCF034D835E9> /usr/lib/libsandbox.1.dylib
                  0x7fffa87d2000 -     0x7fffa87e4ffb  libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
                  0x7fffa87e5000 -     0x7fffa87e6ff3  libspindump.dylib (231.3) <9E50A114-FC58-3E22-9027-5002B60005BE> /usr/lib/libspindump.dylib
                  0x7fffa87e7000 -     0x7fffa8935ff7  libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
                  0x7fffa8958000 -     0x7fffa8990ff3  libssl.0.9.8.dylib (64.50.7) <3B6EAD4B-F7FA-369C-AB54-755B08219D2A> /usr/lib/libssl.0.9.8.dylib
                  0x7fffa8991000 -     0x7fffa89e1fff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
                  0x7fffa89f3000 -     0x7fffa8a25fff  libtidy.A.dylib (15.18.1) <513B2676-8EE0-3A4C-845C-CACDD25280CA> /usr/lib/libtidy.A.dylib
                  0x7fffa8a26000 -     0x7fffa8a29ff7  libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
                  0x7fffa8a2a000 -     0x7fffa8a37fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
                  0x7fffa8a38000 -     0x7fffa8b27ff3  libxml2.2.dylib (30.18) <75135C3D-47B1-3217-AC2B-B566E2E1A4A3> /usr/lib/libxml2.2.dylib
                  0x7fffa8b28000 -     0x7fffa8b51fff  libxslt.1.dylib (15.9.1) <A1EFC225-2115-3710-A2FD-B11FDE15B01F> /usr/lib/libxslt.1.dylib
                  0x7fffa8b52000 -     0x7fffa8b63ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
                  0x7fffa8b72000 -     0x7fffa8b76ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
                  0x7fffa8b77000 -     0x7fffa8b81fff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
                  0x7fffa8b82000 -     0x7fffa8b89fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
                  0x7fffa8b8a000 -     0x7fffa8b92fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
                  0x7fffa8b93000 -     0x7fffa8c16fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
                  0x7fffa8c17000 -     0x7fffa8c48fff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
                  0x7fffa8c49000 -     0x7fffa8c4effb  libdyld.dylib (433.5) <990CF9D7-4AD1-310D-A4B4-010F6D84FFD8> /usr/lib/system/libdyld.dylib
                  0x7fffa8c4f000 -     0x7fffa8c4fffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
                  0x7fffa8c50000 -     0x7fffa8c5cfff  libkxld.dylib (3789.72.11) <FB155780-34ED-3EC4-A478-764061D1EC32> /usr/lib/system/libkxld.dylib
                  0x7fffa8c5d000 -     0x7fffa8c5dfff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
                  0x7fffa8c5e000 -     0x7fffa8c63ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
                  0x7fffa8c64000 -     0x7fffa8c66ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
                  0x7fffa8c67000 -     0x7fffa8c68ffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
                  0x7fffa8c69000 -     0x7fffa8c81ff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
                  0x7fffa8c82000 -     0x7fffa8c82ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
                  0x7fffa8c83000 -     0x7fffa8d10fef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
                  0x7fffa8d11000 -     0x7fffa8d14ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
                  0x7fffa8d15000 -     0x7fffa8d18fff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
                  0x7fffa8d19000 -     0x7fffa8d31fff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
                  0x7fffa8d32000 -     0x7fffa8d38fff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
                  0x7fffa8d39000 -     0x7fffa8d62ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
                  0x7fffa8d63000 -     0x7fffa8d85ff7  libsystem_kernel.dylib (3789.72.11) <EADB8F12-726C-3E26-855B-062924729F42> /usr/lib/system/libsystem_kernel.dylib
                  0x7fffa8d86000 -     0x7fffa8dcdfe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
                  0x7fffa8dce000 -     0x7fffa8decff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
                  0x7fffa8ded000 -     0x7fffa8e46ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
                  0x7fffa8e47000 -     0x7fffa8e50ff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
                  0x7fffa8e51000 -     0x7fffa8e5aff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
                  0x7fffa8e5b000 -     0x7fffa8e63fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
                  0x7fffa8e64000 -     0x7fffa8e6eff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
                  0x7fffa8e6f000 -     0x7fffa8e72ff7  libsystem_sandbox.dylib (592.70.2) <19320A42-2E3B-361B-BBDA-2F5F2E87B100> /usr/lib/system/libsystem_sandbox.dylib
                  0x7fffa8e73000 -     0x7fffa8e74ff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
                  0x7fffa8e75000 -     0x7fffa8e7cffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
                  0x7fffa8e7d000 -     0x7fffa8e90ff7  libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
                  0x7fffa8e91000 -     0x7fffa8e96ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
                  0x7fffa8e97000 -     0x7fffa8ec0ff7  libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
              External Modification Summary:
                Calls made by other processes targeting this process:
                  task_for_pid: 1
                  thread_create: 0
                  thread_set_state: 0
                Calls made by this process:
                  task_for_pid: 0
                  thread_create: 0
                  thread_set_state: 0
                Calls made by all processes on this machine:
                  task_for_pid: 997
                  thread_create: 0
                  thread_set_state: 0
              VM Region Summary:
              ReadOnly portion of Libraries: Total=1.1G resident=0K(0%) swapped_out_or_unallocated=1.1G(100%)
              Writable regions: Total=445.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=445.1M(100%)
                                              VIRTUAL   REGION
              REGION TYPE                        SIZE    COUNT (non-coalesced)
              ATS (font support)                32.0M       11
              ATS (font support) (reserved)        4K        2         reserved VM address space (unallocated)
              Accelerate framework               128K        2
              Activity Tracing                   256K        2
              CG backing stores                 10.7M        2
              CoreUI image file                  112K        2
              Image IO                          5484K        3
              Kernel Alloc Once                    8K        2
              MALLOC                           251.0M       77
              MALLOC guard page                   48K       10
              Memory Tag 242                      12K        2
              STACK GUARD                       56.1M       22
              Stack                             18.2M       22
              VM_ALLOCATE                       75.7M      174
              VM_ALLOCATE (reserved)              36K        2         reserved VM address space (unallocated)
              __DATA                            92.5M      767
              __GLSLBUILTINS                    2588K        2
              __IMAGE                            528K        2
              __LINKEDIT                       453.9M      328
              __NV_CUDA                         8184K        4
              __TEXT                           703.7M      589
              __UNICODE                          556K        2
              mapped file                      151.2M       20
              shared memory                     16.4M       12
              TOTAL                              1.8G     2037
              TOTAL, minus reserved VM space     1.8G     2037
              Model: MacBookPro14,2, BootROM MBP142.0167.B00, 2 processors, Intel Core i5, 3.1 GHz, 8 GB, SMC 2.44f1
              Graphics: kHW_IntelIrisGraphics650Item, Intel Iris Plus Graphics 650, Built-In
              Memory Module: BANK 0/DIMM0, 4 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3039
              Memory Module: BANK 1/DIMM0, 4 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3039
              AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x171), Broadcom BCM43xx 1.0 (7.21.171.133.1a2)
              Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
              Network Service: Wi-Fi, AirPort, en0
              USB Device: USB 3.0 Bus
              USB Device: iBridge
              Thunderbolt Bus: MacBook Pro, Apple Inc., 22.2
              • 4. Re: Premiere CC 2018 Crashes every time
                hooplife Level 1
                Does anybody know?
                • 6. Re: Premiere CC 2018 Crashes every time
                  hooplife Level 1
                  I am on
                  Adobe Premier CC 2018 is the version I am trying to open
                  Yes I am the administrator on this machine.
                  3rd party plugins I am not sure what you mean I have some other programs that I use for my work
                  • 7. Re: Premiere CC 2018 Crashes every time
                    hooplife Level 1
                    Thanks for help everyone.  CC 2017 is still working so if CC 2018 doesn't work and crashes every time just uninstall it and use CC 2017.
