Hello everyone, i want to buy some images but first i have some questions.
1. If someone can tell me the difference between STANDARD LICENSE and ENHANCED LICENSE?
2. What's the meaning of "Up to 500,000 copies or views of the asset"?
3. Can each one be used for commercial purposes?
Thank you very much!
Both licenses are equal in all but two points. You can use the license on a commercial project without a problem.
Only the 500k-run limit is different.
Let me explain by an example:
You use the picture in an add that is published by a newspaper having a printed run of 100k per isue.
You want to use that add for 5 issues: use standard license.
You want to use that add for more than 5 issues: you need the extended license.
Also extended licenses (at least with what I get shown) can be used for promine
...Copy link to clipboard
Moved from Creative Cloud forum.
Thank you!
Also extended licenses (at least with what I get shown) can be used for prominent merchandiseing (let‘s say printing on the cover of a product). This is not as you pictured:
Yes i know. You help me a lot. Thank you!
