Premiere CC 2018 Crashes every time
Contributor ,
Sep 03, 2018 Sep 03, 2018
I can't open the Premier CC 2018.  Crashes every time I open it.
1.3K
Contributor , Sep 13, 2018 Sep 13, 2018
Thanks for help everyone.  CC 2017 is still working so if CC 2018 doesn't work and crashes every time just uninstall it and use CC 2017.
Might want to do what is says: read the crash report.
Adobe Employee ,
Hi hooplife,
Sorry for the trouble. As Ann Bens mentioned, we need crash report; share a screenshot with us. FAQ: How do I capture and post a screen shot or video?
What are the system specs(OS version, RAM, GPU, CPU)? What is the version of Premiere Pro? FAQ: How to find the exact version of Premiere Pro you're using?
Are there any third party plugins installed in the machine? Are you logged in as an Administrator?
Vidya
Contributor ,
Here is my system specs
Below is the crash report
Process:               Adobe Premiere Pro CC 2018 [621]
Path:                  /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
Identifier:            com.adobe.PremierePro.CC12
Version:               12.1.2 (12.1.2)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Adobe Premiere Pro CC 2018 [621]
User ID:               501
Date/Time:             2018-09-03 15:59:38.357 +0300
OS Version:            Mac OS X 10.12.6 (16G1114)
Report Version:        12
Anonymous UUID:        7A86804E-6F42-4489-F0CC-E3686B0A4E70
Sleep/Wake UUID:       521AA26C-6AB5-4692-B425-3896DCBDE07F
Time Awake Since Boot: 1200 seconds
Time Since Wake:       380 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Illegal instruction: 4
Termination Reason:    Namespace SIGNAL, Code 0x4
Terminating Process:   exc handler [0]
Application Specific Information:
dyld: in dlopen()
BUG IN LIBTRACE: MH not found
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_trace.dylib          0x00007fffa8e80e97 _os_trace_image_was_unloaded + 271
1   dyld                          0x00000001049c6cb2 dyld::removeImage(ImageLoader*) + 343
2   dyld                          0x00000001049ca6c7 dyld::garbageCollectImages() + 870
3   dyld                          0x00000001049d254b dlopen + 907
4   libdyld.dylib                  0x00007fffa8c4b832 dlopen + 59
5   com.adobe.dvacore.framework    0x00000001001274e5 dvacore::config::lazyloader::LoadAndInitDependency(char const*) + 1605
6   com.adobe.Mezzanine.framework 0x000000010f706ec9 MZ::(anonymous namespace)::FullInitializer::FullInitializer(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool, bool) + 12889
7   com.adobe.Mezzanine.framework 0x000000010f703414 MZ::Initializer::Initializer(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool, bool) + 84
8   com.adobe.Frontend.framework  0x00000001027e11e8 FE::(anonymous namespace)::FullInitializer::FullInitializer() + 1672
9   com.adobe.Frontend.framework  0x00000001027e0ac5 FE::Initializer::Initializer() + 149
10  com.adobe.Frontend.framework  0x0000000102822911 FE::AppMain(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 353
11  com.adobe.Frontend.framework  0x00000001028240c3 FE::Run(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int) + 659
12  com.adobe.PremierePro.CC12    0x0000000100007bc0 main + 896
13  libdyld.dylib                  0x00007fffa8c4e235 start + 1
Thread 1:
0   libsystem_kernel.dylib        0x00007fffa8d7d44e __workq_kernreturn + 10
1   libsystem_pthread.dylib        0x00007fffa8e67621 _pthread_wqthread + 1426
2   libsystem_pthread.dylib        0x00007fffa8e6707d start_wqthread + 13
Thread 2:
1   libsystem_pthread.dylib        0x00007fffa8e6748e _pthread_wqthread + 1023
Thread 3:
Thread 4:: Dispatch queue: com.apple.root.default-qos
0   libsystem_kernel.dylib        0x00007fffa8d7cc22 __psynch_mutexwait + 10
1   libsystem_pthread.dylib        0x00007fffa8e67dfa _pthread_mutex_lock_wait + 100
2   libsystem_pthread.dylib        0x00007fffa8e65519 _pthread_mutex_lock_slow + 285
3   libdyld.dylib                  0x00007fffa8c4a118 dyldGlobalLockAcquire() + 16
4   dyld                          0x00000001049d2230 dlopen + 112
5   libdyld.dylib                  0x00007fffa8c4b832 dlopen + 59
6   com.apple.CoreFoundation      0x00007fff934860b6 _CFBundleDlfcnCheckLoaded + 102
7   com.apple.CoreFoundation      0x00007fff934ecf4e _CFBundleLoadExecutableAndReturnError + 318
8   com.apple.CoreFoundation      0x00007fff93524b82 CFBundleGetFunctionPointerForName + 50
9   com.adobe.ASLFoundation.framework 0x0000000102660cdb ASL::Module::GetProcAddress(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 363
10  com.adobe.PluginSupport.framework 0x00000001071205ca ML::PluginImpl::GetEntryPoint(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 138
11  com.adobe.VideoFilterHost.framework 0x0000000107a7a3fb ML::AEPluginVideoFilterModule::GetEntryPoint() + 347
12  com.adobe.VideoFilterHost.framework 0x0000000107aa5515 ML::AEVideoFilterModule::GlobalSetup(bool) + 245
13  com.adobe.VideoFilterHost.framework 0x0000000107aa4f1f ML::AEVideoFilterModule::SetupFilter() + 79
14  com.adobe.VideoFilterHost.framework 0x0000000107a7cb6b ML::AEVideoFilter::Create(ASL::InterfaceRef<ML::AEVideoFilterModule, ML::IPluginModule>) + 155
15  com.adobe.VideoFilterHost.framework 0x0000000107aa4e77 ML::AEVideoFilterModule::CreateFilter(ASL::InterfaceRef<BE::IVideoFilter, BE::IVideoFilter>&) + 39
16  com.adobe.VideoFilterHost.framework 0x0000000107ae3b4a ML::VideoFilterFactory::CreateVideoFilter(ASL::InterfaceRef<ML::IVideoFilterModule, ML::IVideoFilterModule>) const + 186
17  com.adobe.VideoFilterHost.framework 0x0000000107ae3de3 ML::VideoFilterFactory::CreateVideoFilter(dvacore::utility::ImmutableString const&, int) const + 67
18  com.adobe.EncoderHost.framework 0x000000010f0134bd EncoderHost::StandardFilterWrapper::CreateVideoFilter() + 221
19  com.adobe.EncoderHost.framework 0x000000010f0151c1 EncoderHost::StandardFilterWrapper::IsUnderlyingVideoFilterHealthy() + 33
20  com.adobe.EncoderHost.framework 0x000000010f02f6a1 EncoderHost::StandardFilterWrapperLumetri::UpdateMainDropList() + 209
21  com.adobe.EncoderHost.framework 0x000000010f02f14a EncoderHost::StandardFilterWrapperLumetri::GetFilterParams(ASL::InterfaceRef<MF::IExporterParam, MF::IExporterParam>) + 4490
22  com.adobe.EncoderHost.framework 0x000000010f000a4b EncoderHost::StandardFilterContainer::SetupParamContainer(bool, bool) + 811
23  com.adobe.EncoderHost.framework 0x000000010ef7bfad EncoderHost::Encoder::LoadPreset(ASL::InterfaceRef<EncoderHost::IPreset, EncoderHost::IPreset>, bool, unsigned int*, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >*) + 1949
24  com.adobe.Mezzanine.framework 0x000000010fa37bdd MZ::SequenceSettingsCache::GetSequencePreviewPresetFromCache(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 4285
25  com.adobe.Mezzanine.framework 0x000000010fa3c7dc MZ::(anonymous namespace)::SequenceSettingsCacheImpl::PreloadCodecsAsync() + 1340
26  com.adobe.dvacore.framework    0x00000001001f0f82 dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymous namespace)::AllocatedFunctionWithSerialNumber> >::CallFunctionWithExceptionHandler(boost::function<void ()> const&) + 34
27  com.adobe.dvacore.framework    0x00000001001f222f dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymous namespace)::AllocatedFunctionWithSerialNumber> >::OnThreadExecute(boost::shared_ptr<dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymous namespace)::AllocatedFunctionWithSerialNumber> > > const&) + 191
28  com.adobe.dvacore.framework    0x00000001001fcab2 dvacore::threads::ExecuteTopLevelFunction(boost::function<void ()> const&) + 98
29  com.adobe.dvacore.framework    0x00000001002108ff dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
30  libdispatch.dylib              0x00007fffa8c188fc _dispatch_client_callout + 8
31  libdispatch.dylib              0x00007fffa8c27196 _dispatch_queue_override_invoke + 743
32  libdispatch.dylib              0x00007fffa8c1a6b5 _dispatch_root_queue_drain + 476
33  libdispatch.dylib              0x00007fffa8c1a48c _dispatch_worker_thread3 + 99
34  libsystem_pthread.dylib        0x00007fffa8e675a2 _pthread_wqthread + 1299
35  libsystem_pthread.dylib        0x00007fffa8e6707d start_wqthread + 13
Thread 5:
0   libsystem_kernel.dylib        0x00007fffa8d7dd96 kevent + 10
1   com.adobe.dvatransport.framework 0x000000010412fbac boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 268
2   com.adobe.dvatransport.framework 0x000000010412f65c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 380
3   com.adobe.dvatransport.framework 0x000000010412f325 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181
4   com.adobe.dvatransport.framework 0x0000000104124c42 SkyConnectionEnv::MainLoop() + 162
5   com.adobe.dvatransport.framework 0x00000001041245f9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6   com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
7   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
8   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
9   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
Thread 6:
0   libsystem_kernel.dylib        0x00007fffa8d7cbf2 __psynch_cvwait + 10
1   libsystem_pthread.dylib        0x00007fffa8e687fa _pthread_cond_wait + 712
2   com.adobe.dvatransport.framework 0x000000010412f5e7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 263
4   com.adobe.dvatransport.framework 0x000000010413a75a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_io_service_runner>::run() + 42
5   com.adobe.dvacore.framework    0x00000001001b21e3 boost_asio_detail_posix_thread_function + 19
6   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
7   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
8   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
Thread 7:
2   com.adobe.dvacore.framework    0x00000001000f3831 boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 65
3   com.adobe.dvacore.framework    0x00000001000f356b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 171
4   com.adobe.dvacore.framework    0x000000010020eb41 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 145
5   com.adobe.dvacore.framework    0x000000010020d029 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 153
6   com.adobe.dvacore.framework    0x000000010020a16f dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 367
7   com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
8   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
9   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
10  libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
Thread 8:: VulcanMsgRecv
0   libsystem_kernel.dylib        0x00007fffa8d7cdf6 __recvfrom + 10
1   VulcanMessage5.dylib          0x000000010bc3a2b8 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2   VulcanMessage5.dylib          0x000000010bc3967c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3   VulcanMessage5.dylib          0x000000010bc38974 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4   VulcanMessage5.dylib          0x000000010bc38838 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5   VulcanMessage5.dylib          0x000000010bc33477 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6   VulcanMessage5.dylib          0x000000010bc33f06 vcfoundation::io::Serializer::InternalDeserialize() + 30
7   VulcanMessage5.dylib          0x000000010bc3389f vcfoundation::io::Serializer::Deserialize() + 9
8   VulcanMessage5.dylib          0x000000010bc37924 vcfoundation::ncomm::Connection::ReadIn() + 22
9   VulcanMessage5.dylib          0x000000010bc3737d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10  VulcanMessage5.dylib          0x000000010bc3706a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11  VulcanMessage5.dylib          0x000000010bc36fbd vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12  VulcanMessage5.dylib          0x000000010bc2a7f8 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13  VulcanMessage5.dylib          0x000000010bc29a36 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14  VulcanMessage5.dylib          0x000000010bc381bc vcfoundation::thread::AbstractThread::Run() + 72
15  VulcanMessage5.dylib          0x000000010bc3a0b9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16  libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
17  libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
18  libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
Thread 9:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        0x00007fffa8d7534a mach_msg_trap + 10
1   libsystem_kernel.dylib        0x00007fffa8d74797 mach_msg + 55
2   com.apple.audio.CoreAudio      0x00007fff93029935 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 127
3   com.apple.audio.CoreAudio      0x00007fff930298a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4   com.apple.audio.CoreAudio      0x00007fff930268d0 HALC_ProxyIOContext::IOWorkLoop() + 1196
5   com.apple.audio.CoreAudio      0x00007fff93026264 HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6   com.apple.audio.CoreAudio      0x00007fff93025fa3 HALB_IOThread::Entry(void*) + 75
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
0   libsystem_kernel.dylib        0x00007fffa8d7539e semaphore_timedwait_trap + 10
1   com.apple.CoreServices.CarbonCore 0x00007fff943ccd1b MPWaitOnSemaphore + 71
2   REDR3D.dylib                  0x0000000135f87c87 0x135e40000 + 1342599
3   REDR3D.dylib                  0x0000000135f3ee02 0x135e40000 + 1043970
4   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
5   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
6   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
Thread 15:
2   REDR3D.dylib                  0x0000000135f88807 0x135e40000 + 1345543
Thread 16:
Thread 17:
Thread 18:
Thread 19:
2   com.apple.CoreFoundation      0x00007fff934c0434 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      0x00007fff934bf8c1 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation      0x00007fff934bf114 CFRunLoopRunSpecific + 420
5   com.apple.AVCVideoServices    0x000000013e74dad2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
Thread 20:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000125054010  rbx: 0x00000000000000b2  rcx: 0x00007fffa8e8edb0  rdx: 0x00000000000000ab
  rdi: 0x0000000000000000  rsi: 0x0000000125054000  rbp: 0x00007fff5fbfb370  rsp: 0x00007fff5fbfb320
   r8: 0x00000000000001f0   r9: 0x00000001247b2400  r10: 0x0000000000031001  r11: 0xffff8001c4bbe5e0
  r12: 0x00000001247b2800  r13: 0x00000001431eb000  r14: 0x00000001247b2808  r15: 0x4dd9090210e20031
  rip: 0x00007fffa8e80e97  rfl: 0x0000000000010246  cr2: 0x000000014bbce50b
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     6
Binary Images:
       0x100000000 -        0x100007ff7 +com.adobe.PremierePro.CC12 (12.1.2 - 12.1.2) <4B73B4B4-B982-34C9-81B2-A9A664CB8847> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
       0x10000d000 -        0x100013fff +com.adobe.AdobeCrashReporter (7.7 - 7.7.0) <FA36FB74-CC30-3BFC-BC2C-4025E64F8C6A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x10001f000 -        0x100020ff3 +com.adobe.boost-system.framework (12.1.2 - 12.1.2.69) <24EF9CA8-E663-3396-B593-3E275BE83204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
       0x100028000 -        0x10002cfff +com.adobe.boost-date-time.framework (12.1.2 - 12.1.2.69) <E4727EFC-83A2-31C7-8740-6AAB964723D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
       0x10003d000 -        0x10004aff7 +com.adobe.boost-threads.framework (12.1.2 - 12.1.2.69) <60EB538A-DB63-33DA-B351-2189E2945EA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
       0x100068000 -        0x100075fff +com.adobe.boost-filesystem.framework (12.1.2 - 12.1.2.69) <169D6D1B-EBBF-3529-B93E-0107A43FB7D7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
       0x10008a000 -        0x1000a3fff +com.adobe.dvaunittesting.framework (12.1.2 - 12.1.2.69) <3BF41758-7436-3E39-A4DF-C7BB0C2EE018> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
       0x1000d8000 -        0x100450fff +com.adobe.dvacore.framework (12.1.2 - 12.1.2.69) <4E8C8538-6240-36EF-B307-BEFF249EB67B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
       0x10075e000 -        0x100792fff +com.adobe.dvaappsupport.framework (12.1.2 - 12.1.2.69) <5234904E-FF9B-3AB9-8229-3F01CDF6B746> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
       0x1007ea000 -        0x100ed7fff +com.adobe.dvaui.framework (12.1.2 - 12.1.2.69) <7DDB6DAD-68D9-37FD-AEB7-6BBC905B8848> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
       0x101ac7000 -        0x101cd8ff7 +com.adobe.MBCProvider.framework (12.1.2 - 12.1.2.69) <433E47AB-1261-3BBE-A0EF-0D1B655BB5D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
       0x101e8c000 -        0x101eb1fff +com.adobe.dvamediaui.framework (12.1.2 - 12.1.2.69) <6F1A328B-D44F-39AD-9101-9AB84944D299> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
       0x101f13000 -        0x102070fff +com.adobe.dvamediabrowser.framework (12.1.2 - 12.1.2.69) <D8DD93F0-663B-33CA-8902-AF52126A58CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
       0x10231a000 -        0x1023c8ff7 +com.adobe.TransmitVRHost.framework (12.1.2 - 12.1.2.69) <0496432C-78E7-3E98-AC62-64DA66CE449C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitVRHost.framework/Versions/A/TransmitVRHost
       0x1024ec000 -        0x1024eeff7 +com.adobe.PRM.framework (12.1.2 - 12.1.2.69) <CDE494A8-D9E9-39F4-852A-7E04445D83DE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
       0x1024f9000 -        0x102566fff +com.adobe.dvamediatypes.framework (12.1.2 - 12.1.2.69) <CF1C0566-8AF5-3ED5-9935-86E98B060B29> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
       0x10261b000 -        0x102673ff7 +com.adobe.ASLFoundation.framework (12.1.2 - 12.1.2.69) <C7FE2F6C-F42D-3131-BA2C-D1A005CFF2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
       0x1026e7000 -        0x10291ffff +com.adobe.Frontend.framework (12.1.2 - 12.1.2.69) <145FFDBF-A0FF-3651-A931-F972C952031B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
       0x102c9c000 -        0x102e5eff7 +com.adobe.amtlib (10.0.0.250 - 10.0.0.250) <172741F8-9E54-317F-A72B-51D05CC05182> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x102e79000 -        0x102f4cfff +com.adobe.dvascripting.framework (12.1.2 - 12.1.2.69) <DC030805-7C1A-3B1A-A027-90AFC649C226> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
       0x103191000 -        0x1031b3fff +com.adobe.ASLMessaging.framework (12.1.2 - 12.1.2.69) <5F55175A-5BAC-39B2-93ED-2908DC2EEE0E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
       0x103203000 -        0x103ae8fc7 +com.adobe.dvaaccelerate.framework (12.1.2 - 12.1.2.69) <6B237AA5-FB0C-39B9-BB20-D7A942D98464> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
       0x103bed000 -        0x103e4afe7 +com.adobe.dvaaudiodsp.framework (12.1.2 - 12.1.2.69) <818F0533-0CB6-3289-B4D7-1C3B69A10DDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
       0x104101000 -        0x104103ff7 +com.adobe.Memory.framework (12.1.2 - 12.1.2.69) <29A797B7-5BD7-3A40-8275-DAAC57B061ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
       0x10410b000 -        0x104163ff7 +com.adobe.dvatransport.framework (12.1.2 - 12.1.2.69) <88F78E08-C945-39A2-BA73-D052FEB1A166> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
       0x104200000 -        0x104221fff +com.adobe.dvamarshal.framework (12.1.2 - 12.1.2.69) <97B637CC-1E4F-3A2B-A206-C4A175EDF68C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
       0x104265000 -        0x1044b4fff +com.adobe.dynamiclink.framework (12.1.2 - 12.1.2.69) <FDFB3C59-C8C9-3261-8C76-12E44E5A0C3C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
       0x1047b6000 -        0x104859fff +com.adobe.MediaFoundation.framework (12.1.2 - 12.1.2.69) <419C7E97-5046-3739-A6A2-555E0236466B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
       0x104946000 -        0x10496fff7 +com.adobe.SweetPeaSupport.framework (12.1.2 - 12.1.2.69) <EF1AFE64-61B8-3503-8D95-C2429C9AE27D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
       0x1049c5000 -        0x104a02dc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
       0x104a50000 -        0x104acafff +com.adobe.AudioRenderer.framework (12.1.2 - 12.1.2.69) <97A27DC9-971D-364A-8948-EEF7D3211025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
       0x104b91000 -        0x104cbdff7 +com.adobe.dvacaptioning.framework (12.1.2 - 12.1.2.69) <5C9A446F-8338-3529-AF9F-2EE687B445EF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
       0x104db1000 -        0x104dfcfff +com.adobe.dvatemporalxmp.framework (12.1.2 - 12.1.2.69) <A5051B93-5997-306D-8D19-E16FECF946A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
       0x104e32000 -        0x104ebbff7 +com.adobe.dvametadata.framework (12.1.2 - 12.1.2.69) <74880A28-97DC-3774-AA80-41730CFF3699> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
       0x104f8b000 -        0x105c85ff7 +com.adobe.Backend.framework (12.1.2 - 12.1.2.69) <8A85E254-7073-30F3-8D08-0E24F00A13D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
       0x106c8c000 -        0x106cb5fff +com.adobe.MLFoundation.framework (12.1.2 - 12.1.2.69) <70A8FD1A-3FF3-3D05-8678-ECB3D808F60C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
       0x106d10000 -        0x106e68fd7 +com.adobe.ImageRenderer.framework (12.1.2 - 12.1.2.69) <8D838BA1-F6A6-3BD5-A04C-D8832165554D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
       0x106faf000 -        0x10705ffff +com.adobe.VideoFrame.framework (12.1.2 - 12.1.2.69) <AACAF49F-0186-38D4-9AC5-F2F8D6E5C7BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
       0x1070f9000 -        0x107147ff7 +com.adobe.PluginSupport.framework (12.1.2 - 12.1.2.69) <E3E53E37-97C4-3727-91D2-07B0BC61FD06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
       0x1071b2000 -        0x1071eefff +com.adobe.AudioSupport.framework (12.1.2 - 12.1.2.69) <BD56A6CB-3540-359C-BD3C-C9736202C285> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
       0x10726c000 -        0x107284fff +com.adobe.MediaUtils.framework (12.1.2 - 12.1.2.69) <FFB2D8D5-4B45-3833-AE5D-EC3F7FEAFFBF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
       0x1072a8000 -        0x107440fff +com.adobe.ImporterHost.framework (12.1.2 - 12.1.2.69) <69FE0A9E-9B5B-3B82-9662-DA60B115E91B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
       0x1076ca000 -        0x10771dff7 +com.adobe.AudioFilterHost.framework (12.1.2 - 12.1.2.69) <81C4C349-0F0A-3D2E-8DFC-12419277E082> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
       0x1077aa000 -        0x1078d1ff7 +com.adobe.VideoRenderer.framework (12.1.2 - 12.1.2.69) <75A24572-0877-3454-85AD-8A0594EFCD0B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
       0x107a57000 -        0x107b86fff +com.adobe.VideoFilterHost.framework (12.1.2 - 12.1.2.69) <7604CA03-B7FD-38DC-AD07-4E5734FA128C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
       0x107d09000 -        0x107d21fff +com.adobe.ProjectSupport.framework (12.1.2 - 12.1.2.69) <D2E66A75-7DA9-3021-8991-58367227D7D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
       0x107d58000 -        0x107ea9ff7 +com.adobe.dvametadataDB.framework (12.1.2 - 12.1.2.69) <4708F30C-E326-37AE-B6EE-DA3BF602C229> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
       0x107ef4000 -        0x108008fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.162860) <9C4D43CC-0925-3157-85D3-266A1F093831> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x108167000 -        0x1081d0ff7 +com.adobe.DynamicLinkMedia.framework (12.1.2 - 12.1.2.69) <060E5F73-BF96-39F7-884F-79F5579C8C0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
       0x1082be000 -        0x1082d2fff +com.adobe.CCLibrariesSupport.framework (12.1.2 - 12.1.2.69) <8B9F7E1C-E419-3431-A29D-8FCA6D177F2F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
       0x108307000 -        0x108329ff7 +com.adobe.dvavulcansupport.framework (12.1.2 - 12.1.2.69) <535CE33D-2DC8-3972-AD5E-6CF385043CDA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
       0x10835f000 -        0x1083bcfff +com.adobe.csxsmanager.framework (12.1.2 - 12.1.2.69) <7544549A-7115-313A-836B-3F1BD8C0B5B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
       0x108443000 -        0x108474ff7 +com.adobe.boost-program-options.framework (12.1.2 - 12.1.2.69) <228DFA51-8A91-3A05-AC26-872AE6517D9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_options
       0x1084d1000 -        0x10856bfff +com.adobe.boost-regex.framework (12.1.2 - 12.1.2.69) <411D4511-E2D7-33E6-AB96-0B00C7D34887> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
       0x1085e1000 -        0x108713fff +com.adobe.dvastorage.framework (12.1.2 - 12.1.2.69) <70DEA66D-58FF-39F6-95E3-417C78F050FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
       0x10877e000 -        0x1088defff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 42 - 79.162860) <1F29F6FF-53E8-39A1-9B5E-0A27BBE9FDE7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
       0x108a1b000 -        0x108a37ffb +com.adobe.libzip.framework (12.1.2 - 12.1.2.69) <A0AA6A5E-AA7A-38A5-ADF7-3A54AAC02880> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
       0x108a4f000 -        0x108f4aff7 +com.adobe.ATEWrapper.framework (12.1.2 - 12.1.2.69) <CAD2611D-B7D8-341E-B13F-4A2D87F311AA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
       0x1094b9000 -        0x10973ffcb +com.adobe.PlugPlug (8.0.0.55 - 8.0.0.55) <B685BDFA-3EA3-3BF7-A88A-5EE5164DBCED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
       0x1099b8000 -        0x109c69ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libxerces-c-3.1.dylib
       0x109e19000 -        0x109ecbfff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libgit2.dylib
       0x109eef000 -        0x109fe9fff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
       0x109ffa000 -        0x10a0b5fff +com.adobe.dvaaudiofilterhost.framework (12.1.2 - 12.1.2.69) <B68A17BE-0CD9-35FA-8D86-4AED6C0AC62C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
       0x10a1dc000 -        0x10a33aff7 +com.adobe.dvaaudiofilters.framework (12.1.2 - 12.1.2.69) <2090E919-55A3-36B8-8C3C-CE2CC321A444> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
       0x10a52d000 -        0x10a589ff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <DD6F8D1F-69EE-335A-8654-72B24E25423D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
       0x10a5cf000 -        0x10a60dff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x10a635000 -        0x10a761ff7  com.apple.AudioVideoBridging (503.2 - 503.2) <90DFEC17-1857-3C9E-BDFC-41AFE115296A> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
       0x10a816000 -        0x10a82ffff  libexpat.1.dylib (15.1) <588CA992-60BB-363B-BEE7-3CC0A26C1AFA> /usr/lib/libexpat.1.dylib
       0x10a839000 -        0x10a84dff3  com.apple.AudioServerApplication (1.0 - 200.9) <4977039B-FC27-3D6E-9B3E-81B3071ADBB3> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
       0x10a85d000 -        0x10a86cfff  com.apple.TimeSync (1.0 - 503.1) <D06817FE-7DEC-3F8C-9484-2EA4CFBC0889> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
       0x10a87e000 -        0x10a937fff +com.adobe.dvanet.framework (12.1.2 - 12.1.2.69) <FA83A194-6156-3BA8-B834-0F666F2DB153> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
       0x10aa5a000 -        0x10b1bdfff +com.adobe.EAClient.framework (12.1.2 - 12.1.2.69) <F57BDECE-C558-370B-AB80-1BDAF7FA4B74> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
       0x10bbcb000 -        0x10bbeffff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanControl.dylib
       0x10bc1c000 -        0x10bc57ff7 +VulcanMessage5.dylib (5.3.0.18 - 5.3.0.18 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <9E8F32A6-84F5-33EF-854C-9D0590105050> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanMessage5.dylib
       0x10bca1000 -        0x10bcb9fff +com.adobe.TeamProjectsLocalClient.framework (12.1.2 - 12.1.2.69) <674A1891-89B4-3035-94E7-82AA716912BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLocalClient
       0x10bcf3000 -        0x10bdb3ff7 +com.adobe.dvaeve.framework (12.1.2 - 12.1.2.69) <9EBF04FD-F699-35CD-9080-903E763BA3A7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
       0x10bf0d000 -        0x10c000ff7 +com.adobe.dvanetsync.framework (12.1.2 - 12.1.2.69) <81666DDC-1449-36B0-9CC2-91F88EEA266C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
       0x10c174000 -        0x10c2e6ff7 +com.adobe.dvaworkspace.framework (12.1.2 - 12.1.2.69) <5167E87B-9BFF-3482-8ED3-D97177623CDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
       0x10c5ee000 -        0x10c6aeff7 +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.162860) <E8B0F4F8-F9FB-3A4E-9B6F-A3C4CAB5D995> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompareAndMerge
       0x10c819000 -        0x10c9e8fff +com.adobe.GPUFoundation.framework (12.1.2 - 12.1.2.69) <95B23730-940A-3BC4-B774-7BF7A28767C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
       0x10cb21000 -        0x10cb34fff +com.adobe.RuntimeInstaller.framework (12.1.2 - 12.1.2.69) <56CF8516-E47B-34D7-8CA7-028B4FAA623B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
       0x10cb53000 -        0x10cc37ff7 +com.mainconcept.mc.mfimport (10.5 - 10.5.17.5963) <C3926B1A-0AB4-37B6-9F44-39E399CD2B94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
       0x10cc46000 -        0x10cdcdfff +com.adobe.atl-audio.framework (12.1.2 - 12.1.2.69) <44F6270C-417D-3B01-A05A-8AEFE2E1F2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
       0x10cdf7000 -        0x10cecdfff +com.adobe.dvaaudiodevice.framework (12.1.2 - 12.1.2.69) <A95196BF-AF0A-30B2-9186-2AF95ACA18FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
       0x10d087000 -        0x10d15bfff +com.adobe.OpticalFlow.framework (12.1.2 - 12.1.2.69) <3D947580-654E-3718-AF85-801839184764> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
       0x10d221000 -        0x10d22dfff +com.adobe.BravoInitializer.framework (12.1.2 - 12.1.2.69) <436469E3-B3AE-320B-B960-3EB40539BCA8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
       0x10d24a000 -        0x10d356fff +com.adobe.ACE (AdobeACE 2.20.02.40104 - 2.20.02.40104) <4E99F32C-DF9A-30DE-ADCB-75498D2B206C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x10d36f000 -        0x10d868fff +com.adobe.AGM (AdobeAGM 4.30.87.40104 - 4.30.87.40104) <D7DD88C5-47A8-3771-AA98-D3898889A554> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x10d915000 -        0x10d92bfff +com.adobe.BIB (AdobeBIB 1.2.03.40104 - 1.2.03.40104) <8FB4C147-F145-3886-BBC9-66F4027EBAE5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x10d934000 -        0x10dc34ff7 +com.adobe.CoolType (AdobeCoolType 5.17.00.40104.1 - 5.17.00.40104) <BD3DFF22-2E03-391E-8E1A-933AA0046204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x10dc86000 -        0x10ddb0ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
       0x10de06000 -        0x10de26ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.40104 - 1.1.40104) <3D52E2D3-C27B-314F-83B6-BCBA00F6D87D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x10de2e000 -        0x10de3efff +com.adobe.ProjectConverterHost.framework (12.1.2 - 12.1.2.69) <3BA089F2-EE8C-39FF-9E0C-E7DD6D23F06B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
       0x10de66000 -        0x10de87fff +com.adobe.ImmersiveVideo.framework (12.1.2 - 12.1.2.69) <36E93CA8-ECAF-352D-B139-FA538A56DD19> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
       0x10deab000 -        0x10df17ff7 +com.adobe.DisplaySurface.framework (12.1.2 - 12.1.2.69) <C9B98269-28C9-3F52-96EA-C0AE3D9E3CAC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
       0x10df97000 -        0x10e350fff +com.adobe.UIFramework.framework (12.1.2 - 12.1.2.69) <868C7FBC-6E27-3059-A2A1-95247905D36B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
       0x10eb87000 -        0x10ebacff7 +com.adobe.dvavirtualui.framework (12.1.2 - 12.1.2.69) <46C049C3-FD4D-3880-950F-7F43883330EE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavirtualui.framework/Versions/A/dvavirtualui
       0x10ec07000 -        0x10ec6fff7 +com.adobe.PlayerHost.framework (12.1.2 - 12.1.2.69) <2D45B21F-9E60-3F8E-94F4-0D6D99365F91> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
       0x10ed4b000 -        0x10ee17ff7 +com.adobe.ExporterHost.framework (12.1.2 - 12.1.2.69) <8CA3E0BA-FB21-373B-95BC-B1BAF9164374> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
       0x10ef33000 -        0x10f0c5fff +com.adobe.EncoderHost.framework (12.1.2 - 12.1.2.69) <8C6A2EBD-ED0A-3438-9C22-3F67AAF19BBE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
       0x10f2c6000 -        0x10f331ff7 +com.adobe.RecorderHost.framework (12.1.2 - 12.1.2.69) <CEDFCFD3-8C14-3995-B21E-0D88C75DA73B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
       0x10f42a000 -        0x10f45eff7 +com.adobe.AudioFilters.framework (12.1.2 - 12.1.2.69) <91453FBC-53DC-3B29-A566-75527CBC3A55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
       0x10f4d2000 -        0x10ff60fff +com.adobe.Mezzanine.framework (12.1.2 - 12.1.2.69) <15380DB2-236C-3B52-A156-BE7A11113AD0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
       0x110b53000 -        0x110b8bff7 +com.adobe.MediaCoreUI.framework (12.1.2 - 12.1.2.69) <FC3FFAE7-F381-34B8-96A1-DB959675BA38> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
       0x110beb000 -        0x110e4bff7 +com.adobe.SettingsUI.framework (12.1.2 - 12.1.2.69) <E52003A4-B314-3F16-AE88-BFF7941F7DBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
       0x1112c3000 -        0x11172cfff +com.adobe.HSL.framework (12.1.2 - 12.1.2.69) <D575B13E-1FEA-3BDB-B5B9-B853FAA8021D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
       0x111d98000 -        0x111ddbfff +com.adobe.TransmitHost.framework (12.1.2 - 12.1.2.69) <037FEF47-EC5C-3762-BFB9-858AB74779FF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
       0x111e3e000 -        0x111f03ff7 +com.adobe.exo.framework (12.1.2 - 12.1.2.69) <968342CE-E32F-3E52-811C-B7F1B9EE4B84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/exo.framework/Versions/A/exo
       0x1120ce000 -        0x112113ff7 +com.adobe.dynamiclinkUI.framework (12.1.2 - 12.1.2.69) <1F3F6F73-FEA2-3210-B6C6-4CAB1870B85F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
       0x1121a8000 -        0x11223cfff +com.adobe.drawbotagm.framework (12.1.2 - 12.1.2.69) <3CC7CD7A-D378-3C33-9ED0-274F038E9E42> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
       0x1122fa000 -        0x1124eefe7 +com.adobe.CodecSupport.framework (12.1.2 - 12.1.2.69) <8FE9AE4A-B2D3-3765-9CA2-51AABA7D2CD8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
       0x11269d000 -        0x112836fef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.17.5963) <6566B253-5F5D-38B7-9667-E1D62249F4BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
       0x112845000 -        0x112ad7fcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.17.5963) <9CF5072E-9C3F-3E48-B18A-48D8DB988539> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
       0x112aee000 -        0x112cc6fe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.17.5963) <3D65323B-3AA2-399F-923A-3C7E670957D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
       0x112cd9000 -        0x114242fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
       0x11443e000 -        0x114484fef +com.adobe.ProResOpt.framework (12.1.2 - 12.1.2.69) <93A0800B-59F1-3E14-9128-8C0547C640B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
       0x1144bb000 -        0x1144c7fff +com.adobe.QT64Utils.framework (12.1.2 - 12.1.2.69) <2FC70546-FAC0-36B3-AA2E-D6C30AD71A68> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
       0x1144df000 -        0x1149c0fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libDNxHR.dylib
       0x114aaf000 -        0x114c1dff7 +libSonyRawDev.dylib (3) <0DEAB123-EEB1-3567-BEB4-074484F55878> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libSonyRawDev.dylib
       0x114cb9000 -        0x115f15fff +libArriRawSDK.dylib (0) <EB0D5F76-6989-3DAC-8560-35016D7E4D47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libArriRawSDK.dylib
       0x11663a000 -        0x116716fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmp4decMT.dylib
       0x116775000 -        0x11687ffff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDDecoder.dylib
       0x116920000 -        0x116a22fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDEncoder.dylib
       0x116ad1000 -        0x116b0eff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.6.5.dylib
       0x116b1a000 -        0x116c3afef +libiomp5.dylib (0) <24D4D9F0-95F7-3930-9662-CD356D42B2C1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libiomp5.dylib
       0x116caa000 -        0x116cd9ff7 +libcilkrts.5.dylib (0) <04FF28DE-1EA4-3A82-ACED-7B8BD7CA100A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcilkrts.5.dylib
       0x116cf7000 -        0x116d1cff7 +com.adobe.QTParser.framework (12.1.2 - 12.1.2.69) <451126BD-5016-3F2C-A571-CC87C87CF169> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
       0x116d44000 -        0x116e29fdf +libProResDecoder.dylib (0) <F006F4E9-D737-3E29-949E-113035495E4B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libProResDecoder.dylib
       0x116e6a000 -        0x116ea5fff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.dylib
       0x116eb3000 -        0x116ed9ff7 +com.adobe.TimeCarving.framework (12.1.2 - 12.1.2.69) <EF7B833B-1611-3F22-92F5-55CDD228697E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
       0x116f1d000 -        0x116f9dfff +com.adobe.MediaFinder.framework (12.1.2 - 12.1.2.69) <9656E167-BFDD-38CE-AA0F-252BA63C6BF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
       0x1170a0000 -        0x117249fff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
       0x117375000 -        0x117409fff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <ED3A028B-68A7-37D8-9127-F99AB0970B65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
       0x11749e000 -        0x11753aff7 +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <265AC5A0-FA72-3D47-99CF-9371A7582B62> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
       0x1175da000 -        0x117622ff7 +com.adobe.ahclientframework (3.0.0.7 - 3.0.0.7) <4D54E721-153B-3DE0-BC31-5B1500295EEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x11765a000 -        0x11767afff +com.adobe.AMEAppFoundation.framework (12.1.2 - 12.1.2.69) <93F41D3D-9879-3EE7-8B42-EBEBAE7EA6D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
       0x1176cb000 -        0x1176d0fff +com.adobe.dvaundo.framework (12.1.2 - 12.1.2.69) <15A81932-504B-31EA-89C0-92BF8EA83387> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
       0x1176de000 -        0x117778fff +com.adobe.essentialsound.framework (12.1.2 - 12.1.2.69) <83657D4C-A0A8-3D72-B581-1C7E858EECA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
       0x117882000 -        0x1178dbfff +com.adobe.FontEngine.framework (12.1.2 - 12.1.2.69) <2DB8738C-F712-3FAB-B598-1177C00F8E20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
       0x11796f000 -        0x117986fff +com.adobe.TitleLayer.framework (12.1.2 - 12.1.2.69) <589EF00E-F74A-398C-AC9A-5810FF6151A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
       0x117b23000 -        0x117b2bff7 +com.adobe.TitleImageManager.framework (12.1.2 - 12.1.2.69) <4006371A-05F0-3F0B-93CF-66B4AE75C274> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
       0x117b3a000 -        0x117bbeff7 +com.adobe.TitleCharacterFactory.framework (12.1.2 - 12.1.2.69) <2610FFB0-AB4E-350E-8B63-689E590039D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFactory
       0x117c42000 -        0x117d91ff7 +com.adobe.TitleCG.framework (12.1.2 - 12.1.2.69) <5B6BCB7E-DA1E-3551-93FF-118B4535FD86> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
       0x117e9e000 -        0x1180cbfff +com.adobe.TitleLayout.framework (12.1.2 - 12.1.2.69) <8B58ECBA-468E-3BA8-8BD7-FCA86B167518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
       0x1185d9000 -        0x118629fff +com.adobe.TitleRenderer.framework (12.1.2 - 12.1.2.69) <0BBB073A-A497-39E3-BA4E-8E4AD308857A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
       0x1186b9000 -        0x11870cff7 +com.adobe.dvaaudiofilterhostui.framework (12.1.2 - 12.1.2.69) <6F650B83-DF5D-3693-9D24-CB28E876D6C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostui
       0x1187e7000 -        0x1188b7fff +com.adobe.dvametadataUI.framework (12.1.2 - 12.1.2.69) <8695151E-E481-3EF6-83D2-62A819D4D67E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
       0x118a04000 -        0x118a0eff7 +com.adobe.dvamarkerUI.framework (12.1.2 - 12.1.2.69) <20C88E1E-80B8-3B90-A141-DBE43575A58D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
       0x118a33000 -        0x118c45fff +com.adobe.EACodec.framework (12.1.2 - 12.1.2.69) <74428346-9289-3935-9E2C-A43C9383AF82> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
       0x118d23000 -        0x118fe3ff7 +com.adobe.EAMedia.framework (12.1.2 - 12.1.2.69) <D4B5E45E-0040-3A67-B9EA-8F1D8522BC14> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
       0x119346000 -        0x119850ff7 +com.adobe.EAProjectBridge.framework (12.1.2 - 12.1.2.69) <6AFF03E3-AF61-3AE6-AB89-192F9D835371> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
       0x119eaf000 -        0x119ec8fff +com.adobe.dvastoryparser.framework (12.1.2 - 12.1.2.69) <BE91B646-3223-3A8A-9C4C-A46E480CF6B6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
       0x119ee9000 -        0x119f11ff7 +com.adobe.dvatypekit.framework (12.1.2 - 12.1.2.69) <594817A4-3D82-3333-B5AF-DBA5AE97DDDF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
       0x119f50000 -        0x119ffbfff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
       0x11a027000 -        0x11a03cff7 +com.adobe.postprocess.framework (12.1.2 - 12.1.2.69) <A90C6102-223B-3B36-A5F3-60E4ACEB690A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
       0x11a06d000 -        0x11a3defe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.17.5963) <68C4B627-70A1-3451-8178-5B00CBDC4779> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
       0x11a517000 -        0x11a729fc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.17.5963) <ABB8EB0E-532F-3C65-84A3-3D1206FC2E89> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
       0x11a73b000 -        0x11a9ccfff +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.17.5963) <9C81FC97-3172-30C6-AB48-AB49515BA1D6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
       0x11a9f9000 -        0x11aa35ff7 +com.adobe.boost-serialization.framework (12.1.2 - 12.1.2.69) <006B6435-0439-3B99-8820-20EF07908B34> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
       0x11ab02000 -        0x11b04eff7 +com.adobe.TeamProjectsLocalLib.framework (12.1.2 - 12.1.2.69) <07742390-2F94-3303-B21D-D7BBF4D2C132> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalLib
       0x11b5fe000 -        0x11bb94b27 +adobe.cloudservices.liveedit.LiveEditClient (1.0 - 1) <9A981AA5-734D-3591-A029-96B2DAF10888> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LiveEditClient.framework/Versions/A/LiveEditClient
       0x11bfb1000 -        0x11c485ff7 +com.adobe.Dialogs.framework (12.1.2 - 12.1.2.69) <C436E904-AE02-38C3-8EA8-14B552E64C0C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
       0x11ca55000 -        0x11cb0cff7 +com.adobe.PProDynamicLinkServer.framework (12.1.2 - 12.1.2.69) <6CBD4908-B736-3D35-A4AA-FBF6C989DB70> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkServer
       0x11ccd0000 -        0x11ce79fff +com.adobe.EAPrBridge.framework (12.1.2 - 12.1.2.69) <C80D2C85-95AB-3D4B-BBAB-F5A8F9B6B50E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
       0x11d10b000 -        0x11d122ff7 +com.adobe.dvacaptioningui.framework (12.1.2 - 12.1.2.69) <684F757A-CE8A-376B-A88F-1E3F1E4E4607> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
       0x11d14a000 -        0x11d326ff7 +com.adobe.RendererGPU.framework (12.1.2 - 12.1.2.69) <9E5C7BA8-3A0E-3A78-B69E-D3CE87494016> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
       0x11d468000 -        0x11d63dff7 +com.adobe.IngestCore.framework (12.1.2 - 12.1.2.69) <0B61D9D8-35A2-36AD-8DAF-6EF0342ACE1A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
       0x11d972000 -        0x11da36fff +com.adobe.IngestDialog.framework (12.1.2 - 12.1.2.69) <0696C3F1-A7ED-3FE8-AE93-334B0EFF4F9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
       0x11dbef000 -        0x11dc1eff7 +com.adobe.dvacontrolsurfacehost.framework (12.1.2 - 12.1.2.69) <2E26F17D-512F-3D0C-B47E-15A436C04DA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurfacehost
       0x11dca8000 -        0x11dcdbfff +com.adobe.dvaaudiodeviceui.framework (12.1.2 - 12.1.2.69) <8D705EA9-5C4A-37BB-B534-1B1C0CD1CF49> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
       0x11dd36000 -        0x11dd67fff +com.adobe.Registration.framework (12.1.2 - 12.1.2.69) <98218561-A270-3828-91E0-96E44F38184A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
       0x11dda0000 -        0x11ddb5ff7 +com.adobe.OnBoardingBase.framework (12.1.2 - 12.1.2.69) <F9007BB0-1CF9-32B1-BD5E-229B213F4C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoardingBase.framework/Versions/A/OnBoardingBase
       0x11ddef000 -        0x11df3dfff +com.adobe.MobileAppLayer.framework (12.1.2 - 12.1.2.69) <3160CBBA-F49F-3DEE-A586-D496564AA3E5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MobileAppLayer.framework/Versions/A/MobileAppLayer
       0x11e274000 -        0x11e3c0fff +com.adobe.ScriptLayerPPro.framework (12.1.2 - 12.1.2.69) <85CED389-8750-39BE-893A-0F6DC25BDA06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
       0x11e5ba000 -        0x11e993ff7 +com.adobe.ScriptLayerPProQE.framework (12.1.2 - 12.1.2.69) <E60D0D25-8AC8-3ADE-AEC1-7B6BB2C548E7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
       0x11f376000 -        0x11f3afff7 +com.adobe.HandlerAudioMiniMixer.framework (12.1.2 - 12.1.2.69) <7570454C-7BDA-3A5D-B00A-4CCB27DC676C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniMixer
       0x11f422000 -        0x11f4ddff7 +com.adobe.HandlerColor.framework (12.1.2 - 12.1.2.69) <C4E933D5-5F56-3A76-9C7C-1C00A328C92D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
       0x11f609000 -        0x11f635ff7 +com.adobe.HandlerCSXS.framework (12.1.2 - 12.1.2.69) <2F0CCDDA-3650-3ADA-A8CA-25FA87B4E122> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
       0x11f6b2000 -        0x11f8ccff7 +com.adobe.HandlerEffectControls.framework (12.1.2 - 12.1.2.69) <4A4AB44C-0EAD-3496-9359-3478834CD518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectControls
       0x11fb71000 -        0x11fbb5ff7 +com.adobe.HandlerMediaBrowser.framework (12.1.2 - 12.1.2.69) <9B16483B-6AB3-3E24-96A2-F7F925DC4619> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
       0x11fc6d000 -        0x11fdd1fff +com.adobe.HandlerProgramMonitor.framework (12.1.2 - 12.1.2.69) <7AC73AB3-D2FA-360B-A19A-1CF5042AF0B8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMonitor
       0x11ffea000 -        0x1202beff7 +com.adobe.HandlerProject.framework (12.1.2 - 12.1.2.69) <DF846AD2-04FF-3F47-BAAF-646651AA1689> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
       0x12072e000 -        0x120a56ff7 +com.adobe.HandlerTimeline.framework (12.1.2 - 12.1.2.69) <66195A9B-954E-3616-9967-0FF5202AF7F6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
       0x120e26000 -        0x120e7cff7 +com.adobe.HandlerTools.framework (12.1.2 - 12.1.2.69) <F8E6F606-EAAA-3D64-B2FE-39827AAD02BB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
       0x120fa6000 -        0x12115dff7 +com.adobe.HandlerTitler.framework (12.1.2 - 12.1.2.69) <1863F354-F666-3565-8873-1EC5CA65EFA0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
       0x1214b0000 -        0x12150afff +com.adobe.HandlerAudioClipMixer.framework (12.1.2 - 12.1.2.69) <16776F6C-A52E-347E-8451-2D3BDA5167B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipMixer
       0x1215c7000 -        0x121667ff7 +com.adobe.HandlerAudioMixer.framework (12.1.2 - 12.1.2.69) <E3D2B286-E9D9-35CC-9400-2FC60570FB90> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
       0x121774000 -        0x1217c8fff +com.adobe.HandlerCaptions.framework (12.1.2 - 12.1.2.69) <253CB6E4-EE41-313A-B033-E84192E8B59F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
       0x121866000 -        0x1218eafff +com.adobe.HandlerCapture.framework (12.1.2 - 12.1.2.69) <6C3FB66F-018E-3434-9302-FE9AF70B35A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
       0x1219f5000 -        0x121a3dff7 +com.adobe.HandlerEditToTape.framework (12.1.2 - 12.1.2.69) <C826C51D-D1B3-3955-A070-5A1383EBD9D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
       0x121ae5000 -        0x121b53fff +com.adobe.HandlerEffects.framework (12.1.2 - 12.1.2.69) <8D6F4079-4A81-3AB8-B2C4-D0F6C9AEBDEE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
       0x121c1a000 -        0x121c33ff7 +com.adobe.HandlerEssentialSound.framework (12.1.2 - 12.1.2.69) <AD99F017-8C49-33B4-B78F-AD693FCB2ADE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEssentialSound.framework/Versions/A/HandlerEssentialSound
       0x121c81000 -        0x121ca0ff7 +com.adobe.HandlerEvents.framework (12.1.2 - 12.1.2.69) <27D4B764-ACE7-394F-8B42-021CA925919F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
       0x121cf4000 -        0x121d08ff7 +com.adobe.HandlerGetProperties.framework (12.1.2 - 12.1.2.69) <F6583899-3713-3A40-86C3-65EEE84AFCD2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperties
       0x121d3f000 -        0x121ec7ff7 +com.adobe.HandlerGraphics.framework (12.1.2 - 12.1.2.69) <D8932F8B-8420-35FD-A5CA-09C9D6BEB1C9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGraphics.framework/Versions/A/HandlerGraphics
       0x122142000 -        0x122159ff7 +com.adobe.HandlerHistory.framework (12.1.2 - 12.1.2.69) <90FDBC3E-6DA7-31EE-9E4B-84A436F11B93> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
       0x122196000 -        0x1221b7fff +com.adobe.HandlerInfo.framework (12.1.2 - 12.1.2.69) <D38E5CE9-4073-3F84-ACA2-A891A10C7AEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
       0x122204000 -        0x122248ff7 +com.adobe.HandlerMarkerList.framework (12.1.2 - 12.1.2.69) <16F37EC8-0C68-3DBC-9125-288FEFCE9EF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
       0x1222ee000 -        0x12233ffff +com.adobe.HandlerMetadataEditor.framework (12.1.2 - 12.1.2.69) <0B0E30F2-E36A-3FBD-9D31-14B8D2A20369> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEditor
       0x1223f8000 -        0x1223fcfff +com.adobe.HandlerProgress.framework (12.1.2 - 12.1.2.69) <9ADC2841-083C-3DCA-BB34-565949086C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
       0x12240f000 -        0x12241fff7 +com.adobe.HandlerScopes.framework (12.1.2 - 12.1.2.69) <E40CD507-7749-3D75-9585-4803E5EED496> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
       0x122447000 -        0x1225d1ff7 +com.adobe.HandlerSourceMonitor.framework (12.1.2 - 12.1.2.69) <9AC7779E-369C-3AF6-A256-667AC8F2ADBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonitor
       0x12279c000 -        0x1227a5ff7 +com.adobe.HandlerStoryPanel.framework (12.1.2 - 12.1.2.69) <5A6FBEB5-467E-3253-BEDC-36C8B3BF1207> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
       0x1227c5000 -        0x1227f1ff7 +com.adobe.HandlerTimecode.framework (12.1.2 - 12.1.2.69) <110975EB-9974-3598-AF65-39F0449B2F3F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
       0x122856000 -        0x122b71fff +com.adobe.dvaadameve.framework (12.1.2 - 12.1.2.69) <D839908C-CEB6-3152-AF34-F930AF4F891D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
       0x1231ff000 -        0x1233a5fff +com.adobe.dvaaudiofiltersui.framework (12.1.2 - 12.1.2.69) <734266EF-9DA3-34C2-BB10-1ABDA9103CFA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofiltersui.framework/Versions/A/dvaaudiofiltersui
       0x1236e5000 -        0x123766fff +com.adobe.ControlSurface.framework (12.1.2 - 12.1.2.69) <EBD39BF2-2EB4-32CD-8CD9-F747A6BD13D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
       0x123810000 -        0x123830ff7 +com.adobe.OnBoarding.framework (12.1.2 - 12.1.2.69) <4B808FC0-40EE-3DD7-AECE-6936F46C5568> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoarding.framework/Versions/A/OnBoarding
       0x12388a000 -        0x1239f8ff7 +com.adobe.Batch.framework (12.1.2 - 12.1.2.69) <AF7F59B9-2E08-374C-8599-A40538A29BE8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
       0x123cda000 -        0x123cf5ff7 +com.adobe.IngestGlue.framework (12.1.2 - 12.1.2.69) <A0A8EB59-2206-3F2E-A0E7-EB43B41314FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
       0x123d3a000 -        0x123edcfff +com.adobe.headlights.LogSessionFramework (7.4.1.112.46866) <F8E6A446-3724-3F70-A396-E1A01325FE0A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x124078000 -        0x124176ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
       0x1241a4000 -        0x124248fff +com.adobe.dvascriptingES.framework (12.1.2 - 12.1.2.69) <3483CB3E-1DC2-3486-961F-8520D8A3FB28> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
       0x124340000 -        0x124384ff7 +com.adobe.dvastorypanel.framework (12.1.2 - 12.1.2.69) <8C9C700C-1C8B-3700-B30A-929AB6303AFD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorypanel.framework/Versions/A/dvastorypanel
       0x12441f000 -        0x1244abff7 +com.adobe.essentialsoundui.framework (12.1.2 - 12.1.2.69) <AB7B2F5C-D98B-36FD-8CAA-50D896B60C04> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsoundui.framework/Versions/A/essentialsoundui
       0x1245dd000 -        0x124651ff7 +com.adobe.ScriptLayer.framework (12.1.2 - 12.1.2.69) <408C5B51-D263-3A41-82D3-7F00E0FD95CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
       0x124fc1000 -        0x124febfff  GLRendererFloat (14.0.16) <32A016EE-63CF-3D07-9BAB-C4EB3E8E479D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x124ff5000 -        0x124ff7ffb  com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x1295d7000 -        0x12977dfff  GLEngine (14.0.16) <E8C60E20-6414-32B2-8964-41882943D9C1> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x12a800000 -        0x12b254ff7  com.apple.driver.AppleIntelKBLGraphicsGLDriver (10.25.17 - 10.2.5) <EFBF3628-9022-3843-9499-0ADE8FC2C9C8> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
       0x12b780000 -        0x12b781fff +com.adobe.TransmitDesktopAudio.framework (12.1.2 - 12.1.2.69) <DC555A97-F712-317D-9758-29CBCF49B940> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesktopAudio
       0x12c4a9000 -        0x12c4bbff3  libTraditionalChineseConverter.dylib (70) <EA69A689-C005-3636-B647-A20DE3715E2D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
       0x12c4c4000 -        0x12c4e0ffb  libJapaneseConverter.dylib (70) <F96283F0-C366-30FE-853E-9C5C0F44FE14> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x12c4e6000 -        0x12c4f5ffb  libSimplifiedChineseConverter.dylib (70) <9DF419B1-9049-3FB1-B6BB-85267B8E3B06> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
       0x12fcc4000 -        0x12fcc8fff  libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x12fcd1000 -        0x12fcf7fef +com.mainconcept.mc.enc.dv (10.5 - 10.5.17.5963) <C8D63373-D045-39AA-B486-72076413C2A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
       0x12fd0c000 -        0x12fd10fff  com.apple.audio.AppleHDAHALPlugIn (279.48 - 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x12fed0000 -        0x12fef2fff  libKoreanConverter.dylib (70) <6C272E7B-5507-3B42-A885-500FED07DDE4> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x1306c1000 -        0x1306c7ff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.17.5963) <8339AD25-167D-3BFE-A37A-D914F6A10B32> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
       0x130900000 -        0x13098efff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (10.25.17 - 10.2.5) <1DABF9B1-3110-31CC-A50B-1351183E4AF3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
       0x135e40000 -        0x136063fe7 +REDR3D.dylib (0) <3F88935C-39CB-3D8F-AA68-478BEF1CC694> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDR3D.dylib
       0x137344000 -        0x13741afff +REDCuda.dylib (0) <DC0FCD27-04BD-319F-A701-7369107E056E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDCuda.dylib
       0x138a1e000 -        0x138c0fff7 +REDOpenCL.dylib (0) <D54DBEDF-8CEB-3FFF-9C86-D92670D10D66> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDOpenCL.dylib
       0x138d18000 -        0x138d1aff7 +T.dylib (0) <291DE13A-BFAF-37FF-A00C-B493F87B2817> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/T.dylib
       0x139d80000 -        0x139daaff7 +com.adobe.EASequenceRenderer.framework (12.1.2 - 12.1.2.69) <BA94E812-51CE-3D7C-8936-F88F0E00EAD3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRenderer
       0x13a1e4000 -        0x13a260ff7 +com.adobe.ExporterMPEG2.framework (12.1.2 - 12.1.2.69) <9C5C4423-F378-30C1-AB6B-A714BAFBD550> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
       0x13a2e6000 -        0x13a2f5fff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.17.5963) <8011D934-1E46-3917-A050-F1BD6C7DB12A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
       0x13a325000 -        0x13a515fe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.17.5963) <111832A9-C088-350C-8096-0EDF0BEA00D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
       0x13a589000 -        0x13a691ff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.17.5963) <FA2E5FB7-A906-38AC-A19D-16D3B5B031E2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
       0x13a999000 -        0x13aae5fe7 +com.adobe.ExporterMPEG4.framework (12.1.2 - 12.1.2.69) <85D17E66-6CD9-3C84-A9B3-FDF3AA8DF0C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
       0x13ac05000 -        0x13add3fff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.17.5963) <6DC87BB2-C6B8-3606-B594-4A456FD44149> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
       0x13ae47000 -        0x13b1c0fff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.17.5963) <16AA44F7-D279-35D8-AD8D-7D48BFB06E65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
       0x13b31a000 -        0x13b3c0fef +com.adobe.IPPMPEGDecoder.framework (12.1.2 - 12.1.2.69) <FB14E648-0856-368C-A42B-E0138F91A643> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
       0x13b780000 -        0x13b8b6ff7 +com.adobe.ExporterMXF.framework (12.1.2 - 12.1.2.69) <AF061E97-35D2-3ACB-85A1-F3233147E223> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
       0x13b9f5000 -        0x13ba1fff7 +libMOG_Framework.5.0.14.dylib (0) <4D5416B3-194E-30A2-B35B-7F500E754E1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.14.dylib
       0x13ba9d000 -        0x13c227fff +libMXF_SDK.5.0.14.dylib (0) <29E0F2C6-A091-3C82-9962-A0DB3071FC4E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.14.dylib
       0x13d47d000 -        0x13d527fff +com.adobe.ExporterXDCAMHD.framework (12.1.2 - 12.1.2.69) <89CE6B00-959C-3315-866A-D15E348BCC18> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
       0x13d5cf000 -        0x13d5d9fff +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.5963) <1727D243-B2DD-3047-B68A-98BCA1A00A7E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
       0x13d5df000 -        0x13d5f7fff +com.adobe.ImporterAVFoundation.framework (12.1.2 - 12.1.2.69) <A24E42DF-FAAA-31A2-9AD7-24741C960F80> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFoundation
       0x13d618000 -        0x13d648ff7 +com.adobe.PlatformAudioCodecs.framework (12.1.2 - 12.1.2.69) <D09914DB-85F8-30E1-B618-9ED666CEAD6C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
       0x13d67a000 -        0x13d769fff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.17.0258) <C86FD5AF-C224-31B6-B073-023A5217E3F9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
       0x13d77b000 -        0x13d78eff7 +com.adobe.ImporterDataStream.framework (12.1.2 - 12.1.2.69) <E78A8666-3F9A-3169-9239-F93497100971> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterDataStream.bundle/Contents/MacOS/ImporterDataStream
       0x13d7b4000 -        0x13d855fff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 018 - 79.162672) <E5812E75-AF80-3066-B077-2A74FCF23C5A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
       0x13d8fd000 -        0x13d980ff7 +com.adobe.ImporterRED.framework (12.1.2 - 12.1.2.69) <1CEDD72E-20C3-31B1-A2E6-A216D01CC5E6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
       0x13da13000 -        0x13dbe3fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
       0x13ddb3000 -        0x13ddc1ff7 +com.adobe.PremiereFiltersMetaPlugin.framework (12.1.2 - 12.1.2.69) <FA8AE1CB-9997-36C8-8AAC-F11CBE825C94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFiltersMetaPlugin
       0x13ddd3000 -        0x13dde2ff7 +com.adobe.TransitionsMetaPlugin.framework (12.1.2 - 12.1.2.69) <AF8E096B-A87A-3F44-868E-4B7533602178> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMetaPlugin
       0x13ddf5000 -        0x13e24afff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
       0x13e70d000 -        0x13e71fff7 +com.adobe.TransmitDV.framework (12.1.2 - 12.1.2.69) <F888C04F-C05B-3901-AF92-100FB4FBC18D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
       0x13e73d000 -        0x13e767ff7  com.apple.AVCVideoServices (1.0 - 42) <FEAE1854-5F7E-3B3E-B6EA-BD825B3CB467> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
       0x13e7a2000 -        0x13e7a9ff7 +com.adobe.TransmitFullScreen.framework (12.1.2 - 12.1.2.69) <B81D958C-5209-3296-95BA-377CCFD5A52B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullScreen
       0x13e7b8000 -        0x13e814fff +com.adobe.PlayerMediaCore.framework (12.1.2 - 12.1.2.69) <A50C7094-8BB4-3254-9D8B-ECD64499B48B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
       0x13e87e000 -        0x13e8b1fff +com.adobe.RendererCPU.framework (12.1.2 - 12.1.2.69) <D6F9D3C4-B510-36D9-B730-DEA05C755E47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
       0x13e8f2000 -        0x13eacafff +com.adobe.TransmitScopes.framework (12.1.2 - 12.1.2.69) <C390FFD2-1720-35AF-9413-83110826D152> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
       0x1402ef000 -        0x140372fff +com.adobe.TransmitVR.framework (12.1.2 - 12.1.2.69) <EBAE97DE-9EAC-3484-BD5E-7F2D7419B9CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitVR.bundle/Contents/MacOS/TransmitVR
       0x140412000 -        0x140461fff +com.adobe.ExporterQuickTimeHost.framework (12.1.2 - 12.1.2.69) <5A393D08-B475-384B-979C-879E85E127DB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuickTimeHost
       0x1404a3000 -        0x1404bbff7 +com.adobe.QTWriter.framework (12.1.2 - 12.1.2.69) <31B98252-B41F-35AE-86F6-D9BB27EFA16D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
       0x14060c000 -        0x14064bfff +com.adobe.ExporterMPEGPreview.framework (12.1.2 - 12.1.2.69) <96227B34-145C-359F-9382-2C9E5B69918B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGPreview
       0x140682000 -        0x1406bbff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.17.5963) <D4FB82FE-A372-38EA-B45F-5ACC4A72A273> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
       0x14103f000 -        0x1410acfff +com.adobe.ICUData (4.0 - 3.61) <604A18BB-29F6-34EC-98D4-3CC65EA9298C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
       0x1410c1000 -        0x1411a6fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.39392 - 3.8.0.39392) <B14D700D-5B31-353D-947A-CCE76A2CF281> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x141258000 -        0x141270fff +M.dylib (0) <BA9E08E4-7A64-32C8-901E-7834B7B2C32B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/M.dylib
       0x141284000 -        0x141287ff3 +VAL.dylib (0) <E6CCE008-C8CE-39B6-B4C9-D0B25ADA3EE2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VAL.dylib
       0x141298000 -        0x141365ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.39530) <5C13ACD4-BD1F-3DF5-B8A7-B388E27D7660> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x1413ad000 -        0x1413deff7 +com.adobe.ARE (AdobeARE 1.5.02.40104 - 1.5.02.40104) <C6C3440E-3FD8-36A9-9D5E-90E999486EE6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
       0x1413ef000 -        0x14174ffff +com.adobe.MPS (AdobeMPS 5.8.1.40104 - 5.8.1.40104) <02FC8477-213B-310D-8330-A648E85BE77C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x1419e2000 -        0x1421acfff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.40112) <4EB2970C-AC64-3E1B-B67A-4B7B23581025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
       0x14288f000 -        0x1428b4fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.39392 - 3.8.0.39392) <FC4F241D-05A6-36E1-8CFE-8FDC58F2AB2B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x1428e1000 -        0x142907fff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.39392 - 3.8.0.39392) <A2837D5A-14F4-3A5C-BD33-2DFA5039CF99> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
       0x142af4000 -        0x142b96ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
       0x142bc1000 -        0x142bc8fff +LIST.dylib (0) <D20BF7AA-F2BF-3AFD-B47A-BFCBBB8D1376> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LIST.dylib
       0x142bd9000 -        0x142be6fff +BEZ.dylib (0) <D365A64F-DA8F-3582-8D7F-F7487986C909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEZ.dylib
       0x142bf1000 -        0x142bf5fff +BM.dylib (0) <8F54C751-9641-305B-AD33-838C90FEF4AD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BM.dylib
       0x142fac000 -        0x143030fff +U.dylib (0) <43C3CC11-0C31-32B3-BF12-375624B4BCC6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/U.dylib
       0x1431eb000 -        0x1432d7ff7 +MEE.dylib (0) <83D216FE-DD20-38FC-BCFE-218287BB4559> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MEE.dylib
       0x1433d0000 -        0x143427ff7 +display.dylib (0) <23CB95FF-9595-3DC1-81D1-97C343EB4E1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/display.dylib
       0x143475000 -        0x143495fff +FILE.dylib (0) <0995DABB-6017-3BB9-A9D3-D28ACE7BC3FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FILE.dylib
       0x1434cb000 -        0x143510fff +SLU.dylib (0) <30AD4361-3AF8-3F0B-8F3B-9534F6AEDEAA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SLU.dylib
       0x14359f000 -        0x1435b7fff +PREF.dylib (0) <C6F46919-5B11-35E8-9D31-7B058C54ACA1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREF.dylib
       0x1435d9000 -        0x14360bff7 +MC.dylib (0) <8745408B-9DCB-3DC2-B648-33E43349ED36> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MC.dylib
       0x14365c000 -        0x14366dfff +PLUG.dylib (0) <73416E55-A2C3-398D-AF2F-BCF809F5209F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PLUG.dylib
       0x143686000 -        0x1436bbff7 +COR.dylib (0) <2DA5CF16-8294-3FCB-B452-33B436060C1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/COR.dylib
       0x143716000 -        0x1439ecff7 +PF.dylib (0) <718ACB33-4985-3756-95E1-6CECFCDE9458> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PF.dylib
       0x143b67000 -        0x144044fff +TXT.dylib (0) <565FC3ED-E9E3-38D4-BD34-4769C298410C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TXT.dylib
       0x14461b000 -        0x14466bff7 +TDL.dylib (0) <9EB1F420-1D58-35F5-9A88-D2412C19CE27> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDL.dylib
       0x1446ab000 -        0x1446f9ff7 +TDB.dylib (0) <AE1B295A-3190-34BA-8C60-3EBE8859AC23> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDB.dylib
       0x144766000 -        0x1447a1ff7 +OM.dylib (0) <1FD80A95-3F36-3B83-8E75-E480794E78C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OM.dylib
       0x1447df000 -        0x144804fff +P.dylib (0) <CBFB6FB1-CD61-37EB-8402-575D62FB394B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/P.dylib
       0x14481e000 -        0x144847fff +PREM.dylib (0) <1C98433E-50AA-3690-B57B-0B284C119A0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREM.dylib
       0x144899000 -        0x1448e8fff +SND.dylib (0) <E9C7F81E-F718-38EF-A89F-4AA5B5B7302A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SND.dylib
       0x144966000 -        0x144995fff +RG.dylib (0) <83F4B8FF-28C3-3F37-B478-08C66EDC09F5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RG.dylib
       0x1449d7000 -        0x144a2bff7 +MSK.dylib (0) <1A21A0F7-CD8A-326C-A3CA-2E08FED05C3D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MSK.dylib
       0x144a7e000 -        0x144a96fff +PR.dylib (0) <004CB06D-C1BE-3159-B6CC-A985D57FC92C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PR.dylib
       0x144acb000 -        0x144ad2fff +SAM.dylib (0) <FDF6A8ED-6054-3E8F-B0AC-199D0F63A598> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SAM.dylib
       0x14aa0e000 -        0x14ac63fff +PIN.dylib (0) <AEB340E2-1C60-3853-8702-9B1247AB3795> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PIN.dylib
       0x14aec2000 -        0x14af69ff7 +FLT.dylib (0) <1EADE55E-4FB0-3F22-B848-4BBAB0B34204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLT.dylib
       0x14b0a9000 -        0x14b162fff +FRP.dylib (0) <37F400AB-08B8-3868-8841-FB0CE30935B5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FRP.dylib
       0x14b256000 -        0x14b278fff +SegMatServices.dylib (0) <1DB59F6A-8061-3E11-9D08-7997652F766F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SegMatServices.dylib
       0x14b2c2000 -        0x14ba27ff7 +BEE.dylib (0) <E32F7614-52EB-3EEF-AACF-BCF02D5AD109> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEE.dylib
       0x14c6a7000 -        0x14c6f0ff7 +FLO.dylib (0) <4D52795F-3A52-39E4-8CCA-DB1DE1D1A4A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLO.dylib
       0x14c712000 -        0x14c74cfef +libtbb.dylib (0) <10144FAB-48B9-34ED-833B-A3F7E65BC4ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbb.dylib
       0x14c78f000 -        0x14c7b3fff +libtbbmalloc.dylib (0) <4AED21B6-C175-31A4-BA52-70A811C1B0F8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbbmalloc.dylib
       0x14c7eb000 -        0x14c9fdfcf +com.adobe.AIDE (1.5.0 - 1.5.0.40084) <F51445AC-916B-3012-8872-9E633C7AF505> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
       0x14ca2d000 -        0x14cae8fff +com.adobe.dvaplayer.framework (12.1.2 - 12.1.2.69) <4DE4839D-0EC6-3C20-947C-3BACF0B5CB1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
       0x14cc72000 -        0x14cc83ff7 +com.adobe.GPUKernels.framework (12.1.2 - 12.1.2.69) <2BAAC10B-71D2-35A3-9E91-E163A5D2EE88> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
       0x14cc92000 -        0x14cca9ff7 +com.adobe.eaurl.framework (12.1.2 - 12.1.2.69) <317BA78E-888B-3312-AA15-77E2E787720A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
       0x14ccd6000 -        0x150856fdf +com.adobe.psl (AdobePSL 15.1.0.38776 - 15.1.0.38776) <22036635-21E0-35A5-8103-CCD034766DE3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
       0x150d4e000 -        0x150e3fff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
       0x150e8c000 -        0x151d32fe7 +libmkl_intel_lp64.dylib (0) <3A603969-1A39-3CAB-8CED-1350DFA6DFC7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_lp64.dylib
       0x151f0a000 -        0x153836fff +libmkl_intel_thread.dylib (0) <B03E1F34-4E4E-3FBE-A9DE-14D37A5E440A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_thread.dylib
       0x153eac000 -        0x1555d0f4f +libmkl_core.dylib (0) <ED21EAB7-AFC8-3C50-8480-E28823A5D4CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_core.dylib
       0x155874000 -        0x155a46fff +libicui18n.dylib (0) <1B56F6C7-045A-3A03-99C1-57D1A91A7909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicui18n.dylib
       0x155bf6000 -        0x155d3afff +libicuuc.dylib (0) <77E17D41-9214-3C2D-B526-CE0D81FAEC05> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicuuc.dylib
       0x155e0c000 -        0x155e1bfff +libv8_libbase.dylib (0) <7CD26441-BBE7-3BFF-9935-7BCC739ADE37> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libbase.dylib
       0x155e35000 -        0x155e40fff +libv8_libplatform.dylib (0) <9EA88668-D5D6-3FC1-B9C6-CE1E53D228CE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libplatform.dylib
       0x155e53000 -        0x156902ff7 +libv8.dylib (0) <1A68B9C1-DC1C-3A70-83A4-73890130CAF9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8.dylib
    0x7fff8e0e7000 -     0x7fff8e42cff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff8fc5e000 -     0x7fff8fc62ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <00D11B5C-E29F-3938-A8DD-D40A26201821> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fff8fc63000 -     0x7fff8fe24fff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff8fe25000 -     0x7fff8fec7ff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff8ff92000 -     0x7fff8ff92fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff8ff93000 -     0x7fff8ffaaffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff8ffab000 -     0x7fff904c4feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff904c5000 -     0x7fff90636ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff90637000 -     0x7fff9064bffb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff9064c000 -     0x7fff90a42fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff90a43000 -     0x7fff90a59fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff90a5a000 -     0x7fff90a60fff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff90a61000 -     0x7fff90a75ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff90a76000 -     0x7fff90bfdfe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff90bfe000 -     0x7fff90cb0fff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff90cb1000 -     0x7fff90cb1fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff90f70000 -     0x7fff91d49ff3  com.apple.AppKit (6.9 - 1504.83.101) <12BF4F22-5FDE-309E-8A19-BC97CC293D46> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff91d5b000 -     0x7fff91d5bfff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff91d5c000 -     0x7fff91dcaff7  com.apple.ApplicationServices.ATS (377 - 422.3) <73C230CF-3213-3DCA-B528-664FEC76A90C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff91e64000 -     0x7fff91f93fff  libFontParser.dylib (194.13) <BE507D17-17D0-37E8-A317-6921118BD283> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff91f94000 -     0x7fff91fdefff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff9203b000 -     0x7fff9206efff  libTrueTypeScaler.dylib (194.13) <F982F582-E2C8-3902-9C79-BB3F4B8199D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff920db000 -     0x7fff92185ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff92186000 -     0x7fff921d7fff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff921d8000 -     0x7fff921e7ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff921e8000 -     0x7fff92235fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff92236000 -     0x7fff92271fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff92272000 -     0x7fff9227dfff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff9227e000 -     0x7fff9248aff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <AF56E94D-5F38-3718-99A3-D23BA0B56BA9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff9248b000 -     0x7fff9248bfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <860636FF-F3B1-32AB-BD6E-75357FB16625> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff925f4000 -     0x7fff929d0fff  com.apple.CFNetwork (811.8 - 811.8) <3FB812CB-F4BF-3C47-B772-042FC4D59A33> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff929ea000 -     0x7fff929eafff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff929eb000 -     0x7fff929eefff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff929ef000 -     0x7fff92cf8fff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff92cf9000 -     0x7fff92cfcff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff92cfd000 -     0x7fff92d02fff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff92d03000 -     0x7fff92d9aff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff92d9b000 -     0x7fff92db5fff  com.apple.openscripting (1.7 - 172.1) <78F3256B-AF4C-324A-A591-ECA4443A469F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff92db6000 -     0x7fff92db7ff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff92db8000 -     0x7fff92dbaff7  com.apple.securityhi (9.0 - 55006) <3CC6C7D1-613E-36A9-8159-113A634AEE6C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff92dbb000 -     0x7fff92dc1ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff92dc2000 -     0x7fff92ea1ffb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff92ea2000 -     0x7fff92ea2fff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff92fec000 -     0x7fff93079fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff9307a000 -     0x7fff9308dfff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff9308e000 -     0x7fff93389fff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff9338a000 -     0x7fff93437ff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff93438000 -     0x7fff938d1ff7  com.apple.CoreFoundation (6.9 - 1349.90) <F07A2387-602E-3D9E-8708-3B3430BD7D82> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff938d2000 -     0x7fff93f54fff  com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff93f55000 -     0x7fff94198ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff94199000 -     0x7fff941feff7  com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff941ff000 -     0x7fff942b0fff  com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff942b1000 -     0x7fff942fcff7  com.apple.CoreMediaIO (805.0 - 4932) <B12C56E0-2FE8-3734-8C45-4B03CAA18A0B> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff942fd000 -     0x7fff942fdfff  com.apple.CoreServices (775.19 - 775.19) <5046FF69-034E-3570-AC30-D14AA469F669> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff942fe000 -     0x7fff9434ffff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff94350000 -     0x7fff9462bff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff9462c000 -     0x7fff9465ffff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff94660000 -     0x7fff94668ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff94669000 -     0x7fff947d5ff7  com.apple.LaunchServices (775.19 - 775.19) <76F27409-F3E0-31A7-BA40-060FBD10CB8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff947d6000 -     0x7fff94886ffb  com.apple.Metadata (10.7.0 - 1075.40) <B734F567-EC70-39AF-BB86-46C97065580F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff94887000 -     0x7fff948e6fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <E6EB5564-B9AB-366F-ACF0-723D394482C0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff948e7000 -     0x7fff94957fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff94958000 -     0x7fff9499dff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff94a26000 -     0x7fff94b73ffb  com.apple.CoreText (352.0 - 544.16) <543AFBA5-4E6B-3F81-BC45-81ED9707BD9C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff94b74000 -     0x7fff94ba9ff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff94baa000 -     0x7fff94c1bffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <64338DCB-8204-3B62-A9C5-0CDDC89F60D6> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff94c5a000 -     0x7fff94d18ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff94d19000 -     0x7fff94d1efff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff94eb0000 -     0x7fff95256fff  com.apple.Foundation (6.9 - 1349.91) <F24B1521-454A-3AE7-B41F-F8FA95BA0490> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff95282000 -     0x7fff952b3ff7  com.apple.GSS (4.0 - 2.0) <30A77A95-CBD4-3BD7-9BFF-8426071F5D9D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff95373000 -     0x7fff95416fff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <5C79A832-84A9-3DC0-9F46-F2B10A3072DC> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff95417000 -     0x7fff954adff7  com.apple.framework.IOKit (2.0.2 - 1324.60.4) <454036AD-86AA-3ABB-8C53-B5F654A6824D> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff954ae000 -     0x7fff954b4ffb  com.apple.IOSurface (159.12 - 159.12) <E3D6FCED-F938-30A3-AD08-0998B674A492> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff95507000 -     0x7fff95667fef  com.apple.ImageIO.framework (3.3.0 - 1599.13) <443879A7-48C6-37ED-AC0B-166EEEABA662> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff95668000 -     0x7fff9566cfff  libGIF.dylib (1599.13) <11C5D9D7-B8A1-3D53-BA50-B25976FE6379> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff9566d000 -     0x7fff9575dff7  libJP2.dylib (1599.13) <C495FB08-0CD2-36FC-8196-FAD3D598A010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff9575e000 -     0x7fff95781ffb  libJPEG.dylib (1599.13) <D22E2431-76A5-39B4-AF0B-174CF282A1CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff95782000 -     0x7fff957a9ff7  libPng.dylib (1599.13) <561865FA-A51B-3EFF-ABFF-B4566B90B1A2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff957aa000 -     0x7fff957acff3  libRadiance.dylib (1599.13) <6559253B-8FE2-3884-BC93-95BB7705A6D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff957ad000 -     0x7fff957fbffb  libTIFF.dylib (1599.13) <8FC594B3-6BBF-3A70-9994-203E9B330B5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff95959000 -     0x7fff96563fff  com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff96564000 -     0x7fff9657dff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff9657e000 -     0x7fff965b4fff  com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff96807000 -     0x7fff9680dfff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff96823000 -     0x7fff96d5cff7  com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff96d5d000 -     0x7fff96db8fff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff96db9000 -     0x7fff96dd1fff  com.apple.MetalKit (1.0 - 76.1) <BA9002FF-00C1-32C8-BC06-634C81C3DB02> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
    0x7fff96dd2000 -     0x7fff97651fff  com.apple.ModelIO (1.0 - 1) <366820F9-6795-3D93-AAF2-630D94B395E6> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
    0x7fff976a1000 -     0x7fff976a9fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff97880000 -     0x7fff97888ff7  libcldcpuengine.dylib (2.8.5) <8086D6FA-2006-3582-B20E-4209D81ACC58> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff97889000 -     0x7fff978d7ff3  com.apple.opencl (2.8.6 - 2.8.6) <A6140AC4-7579-3AC2-B7EE-08A8899BC811> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff978d8000 -     0x7fff978f1ffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff978f2000 -     0x7fff978fdff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff978fe000 -     0x7fff97900fff  libCVMSPluginSupport.dylib (14.0.16) <AA2468D1-9169-3424-8EE4-0470E9050E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff97901000 -     0x7fff97904ff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff97905000 -     0x7fff97909fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff9790a000 -     0x7fff97913ff7  libGFXShared.dylib (14.0.16) <170D07F3-2D30-3D4B-80A0-971E0A765709> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff97914000 -     0x7fff9791ffff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff97920000 -     0x7fff9795cff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff9795d000 -     0x7fff97ad3ff3  libGLProgrammability.dylib (14.0.16) <A81F1B95-445C-3191-ADB1-07BAEA5A204D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff97ad4000 -     0x7fff97b15ff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff9847d000 -     0x7fff9848bfff  com.apple.opengl (14.0.16 - 14.0.16) <B428BB89-8FE1-3527-BF3E-F8F0A1060884> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff98fdd000 -     0x7fff991ddfff  com.apple.QuartzCore (1.11 - 453.39.4) <31B739DC-81E1-3249-9A43-E501FECA8240> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff991de000 -     0x7fff99233fff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff9972e000 -     0x7fff99745ff7  com.apple.ScriptingBridge (1.3.3 - 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
    0x7fff99746000 -     0x7fff99a48ff7  com.apple.security (7.0 - 57740.60.20) <A7DA9073-C3C2-3FEA-B531-471AB9F40609> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff99a49000 -     0x7fff99abefff  com.apple.securityfoundation (6.0 - 55132.50.7) <1276FFB8-05B8-3760-9EA7-2037B7FE2FBC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff99ae9000 -     0x7fff99aecff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff99e73000 -     0x7fff99ee2ff7  com.apple.SystemConfiguration (1.14 - 1.14) <B471E0FA-3AC6-3A34-82C8-4FCF4B389368> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff99ee3000 -     0x7fff9a291fff  com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff9bfbe000 -     0x7fff9bfc5ffb  com.apple.APFS (1.0 - 1) <6E79797E-26BD-3E49-891C-03B223F7BD59> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff9c739000 -     0x7fff9c754ff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff9c755000 -     0x7fff9c762ff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff9c763000 -     0x7fff9c785ffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <6C01014A-49D0-312D-A4EF-BFB5B7882F9C> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff9c786000 -     0x7fff9c795feb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff9c87f000 -     0x7fff9c90a97f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff9c93a000 -     0x7fff9c942ffb  com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff9c947000 -     0x7fff9c999fff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <B272678B-2EA8-3F04-BB0F-3CE62D1E4F58> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff9c9a3000 -     0x7fff9c9aaff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fff9cd3d000 -     0x7fff9cdbbff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff9cde4000 -     0x7fff9ce21ffb  com.apple.bom (14.0 - 194.1) <0CBECAF1-B5E0-302F-99EC-D7ED14E12B84> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff9da46000 -     0x7fff9da6dff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff9da6e000 -     0x7fff9dafaff7  com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff9e392000 -     0x7fff9e39bffb  com.apple.CommonAuth (4.0 - 2.0) <44E4467E-90BB-3CC4-9E57-9B09D7E90081> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff9e520000 -     0x7fff9e8ffff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff9e900000 -     0x7fff9e930fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff9e9cb000 -     0x7fff9e9d3ffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff9eae4000 -     0x7fff9eaf4fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff9ee2f000 -     0x7fff9ee5fff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff9f0f0000 -     0x7fff9f17fff7  com.apple.CoreSymbolication (62046) <9685A34A-C6FD-3681-8F7E-211D48298DD2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff9f180000 -     0x7fff9f2bffe7  com.apple.coreui (2.1 - 431.3) <8D0FA478-9B6C-3D6D-8ADF-8677BA0BF134> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff9f2c0000 -     0x7fff9f390ff3  com.apple.CoreUtils (5.1 - 510.31) <7FBB03B5-13E2-3284-B5DF-6C73AD774479> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff9f3e0000 -     0x7fff9f445ff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <926A9CE7-6F3F-3EB6-A392-81FF485F0B7A> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff9f446000 -     0x7fff9f454ff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff9f4c6000 -     0x7fff9f4d0ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff9f4d1000 -     0x7fff9f4d5ff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff9f50b000 -     0x7fff9f580ffb  com.apple.datadetectorscore (7.0 - 539.1) <84F04DEF-DF0A-3F93-AEE9-B6FAC781164B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff9f5bc000 -     0x7fff9f5fbfff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff9f5fc000 -     0x7fff9f70dfff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff9f712000 -     0x7fff9f7e7fff  com.apple.DiskImagesFramework (444.50.16 - 444.50.16) <533370F7-DB79-311C-99DE-6A04BBF72EFD> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff9f8a0000 -     0x7fff9f8a2ffb  com.apple.EFILogin (2.0 - 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff9f9f5000 -     0x7fff9fe26ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffa117d000 -     0x7fffa117dfff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffa118a000 -     0x7fffa1195ff3  libGPUSupportMercury.dylib (14.0.16) <1216909A-E38E-335F-9F46-9362753AE0D1> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffa144e000 -     0x7fffa146afff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffa1483000 -     0x7fffa1b35fff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fffa1b7b000 -     0x7fffa1bf1ff3  com.apple.Heimdal (4.0 - 2.0) <9541C717-96FF-32D3-8F0B-5048525DAA70> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffa220c000 -     0x7fffa2213ffb  com.apple.IOAccelerator (311.16.2 - 311.16.2) <96FA28B6-B03D-3A5E-AF07-0AE4486D2968> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffa2215000 -     0x7fffa2229ff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffa222a000 -     0x7fffa224cfff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffa22e8000 -     0x7fffa22f8ff3  com.apple.IntlPreferences (2.0 - 216) <15B0DF1F-24C3-3A51-9032-1DD150B7D321> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fffa2333000 -     0x7fffa24eafff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffa25e6000 -     0x7fffa26a8ff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fffa2b5a000 -     0x7fffa2b5dfff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fffa2c36000 -     0x7fffa2c6aff3  com.apple.MediaKit (16 - 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fffa2e0b000 -     0x7fffa2e84ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffa2e96000 -     0x7fffa2ff1fdf  com.apple.mobiledevice (988.70.1.100.34 - 988.70.1.100.34) <5D9B7AC8-4B6C-3CBF-BCB1-558D2B754C21> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
    0x7fffa3011000 -     0x7fffa3039ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <E2FE1821-C7CC-3C35-BEB3-6DC693F5128D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffa30eb000 -     0x7fffa30f6fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffa39ce000 -     0x7fffa3a0fff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <ED3CFDFC-878E-30C2-929B-C2CD43D702DE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffa40bc000 -     0x7fffa40f6ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fffa40f7000 -     0x7fffa4111fff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffa4112000 -     0x7fffa4121ff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fffa412a000 -     0x7fffa414dff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffa4e17000 -     0x7fffa4e1afff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fffa4ea9000 -     0x7fffa4f36fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffa4f57000 -     0x7fffa51bdfeb  com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffa539c000 -     0x7fffa53a8ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffa5a94000 -     0x7fffa5b08fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffa5f47000 -     0x7fffa5f4dff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffa5fd9000 -     0x7fffa609fff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffa6113000 -     0x7fffa6114fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffa6115000 -     0x7fffa62a5ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffa6d74000 -     0x7fffa6e34fff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fffa727f000 -     0x7fffa7285fff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fffa7356000 -     0x7fffa7358ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffa73ad000 -     0x7fffa73c8ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
    0x7fffa73c9000 -     0x7fffa73d4fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
    0x7fffa73d5000 -     0x7fffa7465ff7  libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
    0x7fffa7466000 -     0x7fffa7467ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffa7468000 -     0x7fffa767bfff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
    0x7fffa7697000 -     0x7fffa769efff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
    0x7fffa769f000 -     0x7fffa769ffff  libOpenScriptingUtil.dylib (172.1) <0F1BA407-97D1-36F6-882D-A355EAAD5E00> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffa76a0000 -     0x7fffa76a4ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
    0x7fffa76a5000 -     0x7fffa76a6ffb  libSystem.B.dylib (1238.60.2) <03D8D904-05E2-3A15-B14E-3472703550DC> /usr/lib/libSystem.B.dylib
    0x7fffa7712000 -     0x7fffa773dff3  libarchive.2.dylib (41.70.2) <907D1FB1-9A65-33F5-AFC8-0B6E5AE9D83A> /usr/lib/libarchive.2.dylib
    0x7fffa773e000 -     0x7fffa77bafc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
    0x7fffa77be000 -     0x7fffa77beff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
    0x7fffa77bf000 -     0x7fffa77cfff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffa77d0000 -     0x7fffa77deff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
    0x7fffa77df000 -     0x7fffa7835ff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
    0x7fffa7836000 -     0x7fffa785fff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
    0x7fffa7860000 -     0x7fffa7870ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffa7871000 -     0x7fffa7887fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
    0x7fffa7888000 -     0x7fffa7888ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
    0x7fffa7889000 -     0x7fffa788aff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffa7944000 -     0x7fffa7a28ff7  libcrypto.0.9.8.dylib (64.50.7) <B34BC0FA-18ED-37C5-9D46-393803CADEBB> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffa7bba000 -     0x7fffa7bc5fff  libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
    0x7fffa7bc6000 -     0x7fffa7c19ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
    0x7fffa7c1a000 -     0x7fffa7c6cfff  libcurl.4.dylib (95.70.4) <D81AEB1D-8501-3EEC-9651-D6D476C2A387> /usr/lib/libcurl.4.dylib
    0x7fffa7c6d000 -     0x7fffa7c74ff3  libdscsym.dylib (148.3) <2A78774F-6679-3B72-9903-B295B9825872> /usr/lib/libdscsym.dylib
    0x7fffa7c96000 -     0x7fffa7c96fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffa7ca4000 -     0x7fffa7ca5fff  libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
    0x7fffa7ca6000 -     0x7fffa7cabff7  libheimdal-asn1.dylib (498.50.9) <92C953A2-5E1D-39E9-875E-92F29A12D6FB> /usr/lib/libheimdal-asn1.dylib
    0x7fffa7cac000 -     0x7fffa7d9eff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffa7d9f000 -     0x7fffa7fc4ffb  libicucore.A.dylib (57167.0.1) <E720801C-2D92-3108-B853-469551EDF21F> /usr/lib/libicucore.A.dylib
    0x7fffa7fca000 -     0x7fffa7fcbfff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
    0x7fffa7fcc000 -     0x7fffa7fe5ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffa7fe6000 -     0x7fffa7ffcff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
    0x7fffa7ffd000 -     0x7fffa82a5ff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
    0x7fffa82d8000 -     0x7fffa8352ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
    0x7fffa8353000 -     0x7fffa8725047  libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
    0x7fffa8728000 -     0x7fffa872cfff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffa872d000 -     0x7fffa875efff  libpcap.A.dylib (67.60.2) <B2D36AD8-D5C8-3875-AC81-4787A15E44C2> /usr/lib/libpcap.A.dylib
    0x7fffa877b000 -     0x7fffa8797ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffa8798000 -     0x7fffa87d1fff  libsandbox.1.dylib (592.70.2) <1A879867-1FB4-382F-8139-CCF034D835E9> /usr/lib/libsandbox.1.dylib
    0x7fffa87d2000 -     0x7fffa87e4ffb  libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
    0x7fffa87e5000 -     0x7fffa87e6ff3  libspindump.dylib (231.3) <9E50A114-FC58-3E22-9027-5002B60005BE> /usr/lib/libspindump.dylib
    0x7fffa87e7000 -     0x7fffa8935ff7  libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
    0x7fffa8958000 -     0x7fffa8990ff3  libssl.0.9.8.dylib (64.50.7) <3B6EAD4B-F7FA-369C-AB54-755B08219D2A> /usr/lib/libssl.0.9.8.dylib
    0x7fffa8991000 -     0x7fffa89e1fff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
    0x7fffa89f3000 -     0x7fffa8a25fff  libtidy.A.dylib (15.18.1) <513B2676-8EE0-3A4C-845C-CACDD25280CA> /usr/lib/libtidy.A.dylib
    0x7fffa8a26000 -     0x7fffa8a29ff7  libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
    0x7fffa8a2a000 -     0x7fffa8a37fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
    0x7fffa8a38000 -     0x7fffa8b27ff3  libxml2.2.dylib (30.18) <75135C3D-47B1-3217-AC2B-B566E2E1A4A3> /usr/lib/libxml2.2.dylib
    0x7fffa8b28000 -     0x7fffa8b51fff  libxslt.1.dylib (15.9.1) <A1EFC225-2115-3710-A2FD-B11FDE15B01F> /usr/lib/libxslt.1.dylib
    0x7fffa8b52000 -     0x7fffa8b63ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffa8b72000 -     0x7fffa8b76ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
    0x7fffa8b77000 -     0x7fffa8b81fff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
    0x7fffa8b82000 -     0x7fffa8b89fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
    0x7fffa8b8a000 -     0x7fffa8b92fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
    0x7fffa8b93000 -     0x7fffa8c16fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
    0x7fffa8c17000 -     0x7fffa8c48fff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
    0x7fffa8c49000 -     0x7fffa8c4effb  libdyld.dylib (433.5) <990CF9D7-4AD1-310D-A4B4-010F6D84FFD8> /usr/lib/system/libdyld.dylib
    0x7fffa8c4f000 -     0x7fffa8c4fffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
    0x7fffa8c50000 -     0x7fffa8c5cfff  libkxld.dylib (3789.72.11) <FB155780-34ED-3EC4-A478-764061D1EC32> /usr/lib/system/libkxld.dylib
    0x7fffa8c5d000 -     0x7fffa8c5dfff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
    0x7fffa8c5e000 -     0x7fffa8c63ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
    0x7fffa8c64000 -     0x7fffa8c66ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
    0x7fffa8c67000 -     0x7fffa8c68ffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
    0x7fffa8c69000 -     0x7fffa8c81ff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
    0x7fffa8c82000 -     0x7fffa8c82ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
    0x7fffa8c83000 -     0x7fffa8d10fef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
    0x7fffa8d11000 -     0x7fffa8d14ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
    0x7fffa8d15000 -     0x7fffa8d18fff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffa8d19000 -     0x7fffa8d31fff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
    0x7fffa8d32000 -     0x7fffa8d38fff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffa8d39000 -     0x7fffa8d62ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
    0x7fffa8d63000 -     0x7fffa8d85ff7  libsystem_kernel.dylib (3789.72.11) <EADB8F12-726C-3E26-855B-062924729F42> /usr/lib/system/libsystem_kernel.dylib
    0x7fffa8d86000 -     0x7fffa8dcdfe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
    0x7fffa8dce000 -     0x7fffa8decff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
    0x7fffa8ded000 -     0x7fffa8e46ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
    0x7fffa8e47000 -     0x7fffa8e50ff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffa8e51000 -     0x7fffa8e5aff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
    0x7fffa8e5b000 -     0x7fffa8e63fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
    0x7fffa8e64000 -     0x7fffa8e6eff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
    0x7fffa8e6f000 -     0x7fffa8e72ff7  libsystem_sandbox.dylib (592.70.2) <19320A42-2E3B-361B-BBDA-2F5F2E87B100> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffa8e73000 -     0x7fffa8e74ff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
    0x7fffa8e75000 -     0x7fffa8e7cffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffa8e7d000 -     0x7fffa8e90ff7  libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
    0x7fffa8e91000 -     0x7fffa8e96ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
    0x7fffa8e97000 -     0x7fffa8ec0ff7  libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 997
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.1G resident=0K(0%) swapped_out_or_unallocated=1.1G(100%)
Writable regions: Total=445.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=445.1M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
ATS (font support)                32.0M       11
ATS (font support) (reserved)        4K        2         reserved VM address space (unallocated)
Accelerate framework               128K        2
Activity Tracing                   256K        2
CG backing stores                 10.7M        2
CoreUI image file                  112K        2
Image IO                          5484K        3
Kernel Alloc Once                    8K        2
MALLOC                           251.0M       77
MALLOC guard page                   48K       10
Memory Tag 242                      12K        2
STACK GUARD                       56.1M       22
Stack                             18.2M       22
VM_ALLOCATE                       75.7M      174
VM_ALLOCATE (reserved)              36K        2         reserved VM address space (unallocated)
__DATA                            92.5M      767
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       453.9M      328
__NV_CUDA                         8184K        4
__TEXT                           703.7M      589
__UNICODE                          556K        2
mapped file                      151.2M       20
shared memory                     16.4M       12
TOTAL                              1.8G     2037
TOTAL, minus reserved VM space     1.8G     2037
Model: MacBookPro14,2, BootROM MBP142.0167.B00, 2 processors, Intel Core i5, 3.1 GHz, 8 GB, SMC 2.44f1
Graphics: kHW_IntelIrisGraphics650Item, Intel Iris Plus Graphics 650, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3039
Memory Module: BANK 1/DIMM0, 4 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3039
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x171), Broadcom BCM43xx 1.0 (7.21.171.133.1a2)
Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.2
Contributor ,
Sep 06, 2018 Sep 06, 2018
Does anybody know?
Contributor ,
Sep 08, 2018 Sep 08, 2018
I am on
Adobe Premier CC 2018 is the version I am trying to open
Yes I am the administrator on this machine.
3rd party plugins I am not sure what you mean I have some other programs that I use for my work
Contributor ,
Sep 13, 2018 Sep 13, 2018
Thanks for help everyone.  CC 2017 is still working so if CC 2018 doesn't work and crashes every time just uninstall it and use CC 2017.
