I. I work with Premiere pro cc - make some simples movies. Today i have one problem - when i use right click on 2 movies and choose "apply deafult transition" i have error "insufficient media. this transition will contain reapeated frames". and cross disolve on movies is beetween but consnant power is only in first audio path. (not in the middle). Perhaps i use some shortcut and mayby change something in options? yesterday everything works ok (the same movies, clips etc). i check old projects when i use this method to fast transition end there are but when i clear transition end go again- the same error.
what the hell?
marekz43854306 wrote
what the hell?
You need handles for your media:
Applying transitions in Premiere Pro
MtD
thanks - i google this answer many times but this is not for me.
let me explain:
i have two movie files (1 - 30s, 2- 45s ) - when i put on timeline and choose deafult transition i have this error message. i worked with premiere pro for 4 years and always do this way - for the first time i have this error.
when i cut 1 movie (f.e. in the middle and choose deafult transition - everythink ok).
in first case. when i ignore error massage and again make deafult transition - i have something like this:
the transitions are on the end of first movie (not in the middle). i cant manualy put them on middle (only on the end of 1 movie or start of 2 movie).
i reapeat - yesterday everythink works perfect with this. i dont know whats going on?
MtD
yes, i have 30s more video in this clips.
but - for 4 years i work the same schema: put videos on timeline, cuts, right click: ripple delete gaps, right click: default transitions. this way works great - no problems, everythink ok. i dont care about cut videos before end to have some space avalible for transitions - everythink works automatic.
mayby the are some options i turn on (short key?)? to disable this automatic deafult transition works?
