I have Windows 10 and PSE 15. I just shot some RAW files with the Canon extension .CR3. I try to open in RAW in PSE, but they won't open. I checked for updates, but my software indicates everything is up to date. How can I open Canon .CR3 files so I can edit them... or even look at them with this software? Thanks!
FAQ: Will Photoshop Elements work with my camera, or Why won't my raw files open?
You don't state the only necessary information: which is your Canon camera type? If the camera was issued after the release of PSE15, obviously its raw format can't be recognized.
ALLES OK ,Bedankt
Van: MichelBParis
Verzonden: zaterdag 8 september 2018 19:18
Aan: gerard vanpoucke
Onderwerp: PSE 15 Won't Open .CR3 Files
created by MichelBParis <https://forums.adobe.com/people/MichelBParis> in Photoshop Elements - View the full discussion <https://forums.adobe.com/message/10609088#10609088>
The CR3 - RAW format is relatively new. At the moment only the .CR3 file from the Canon M50 was supported. For other cameras Adobe has to develop the support in the appropriate applications. You have to wait until Adobe released the updates. In the meantime you must you the Canon DPP utility.
BTW: I don't know if PSE 15 is still supported. If not you have to buy an update to the newest PSE version. Or you convert the .CR3 files into the DNG format using Adobe DNG Converter. Then you can use this files in PSE 15.
Thanks Axel!
I guess they will inevitably push you to the newer product. Ha!
Yes, apparently the .CR3 format is only in Canon's EOS M50 camera... at least right now.
ALLES OK, Bedankt
Van: laconicantgnst
Verzonden: zaterdag 8 september 2018 19:08
created by laconicantgnst <https://forums.adobe.com/people/laconicantgnst> in Photoshop Elements - View the full discussion <https://forums.adobe.com/message/10609126#10609126>
