3 Replies Latest reply on Sep 9, 2018 8:09 AM by BarlaeDC
    script to generate a setup of layers in indesign
    lister110 Level 1
      Hi, I have used a script in the past to generate a set of pre-defined layers:
      for some reason if I un this AppleScript I get an error now 'Expected end of line but found identifier.' with LayerName highlighted. I can't work out why this has happened now. Can anyone help? code below.
      thanks
      lister
      tell application "Adobe InDesign CS6"
         set LayerName to "Background"
         tell document 1
            -- Is this layer is exist ?
            try
               set myLayer to layer LayerName
               -- No? -> create it
            on error
               set myLayer to make layer with properties {name:LayerName}
            end try
         end tell
         set LayerName to "UCL Logo"
         tell document 1
            try
               -- No? -> create it
            on error
            end try
         end tell
         set LayerName to "Blank SRP"
         tell document 1
            try
               -- No? -> create it
            on error
            end try
         end tell
         set LayerName to "Cutting/Ratio Guide"
         tell document 1
            try
               -- No? -> create it
            on error
            end try
        delete layer "Layer 1"
         end tell
      end
        • 1. Re: script to generate a setup of layers in indesign
          BarlaeDC Adobe Community Professional
          I was able to run your script without any problems, although find a new version of your script below which uses a function to avoid any duplicate code, therefore making it easier to spot any errors.
          my createNewLayerWithName("Background")
          my createNewLayerWithName("UCL Logo")
          my createNewLayerWithName("Blank SRP")
          my createNewLayerWithName("Cutting/Ratio Guide")
              tell document 1
              end tell
          end tell
          on createNewLayerWithName(LayerName)
                  tell document 1
                      try
                      on error
                      end try
                  end tell
              end tell
          end createNewLayerWithName
          Hope this helps
          Malcolm
          • 2. Re: script to generate a setup of layers in indesign
            lister110 Level 1
            Thanks for this, Im not sure what Im doing, but when open the script and try to save this (in script editor) I get a syntax error "". not sure why?
            • 3. Re: script to generate a setup of layers in indesign
              Can you post a screen shot of the code and the error?
              Regards
              Malcolm
