Hello, apologies for JavaScript illiteracy and the need for help.
In creating an action to size (by pixel) and position a layer, I happened upon this awesome script here (shown below): Action records layer transform in percentage NOT pixels???
I use this script to resize to 2400 pixels wide, while constraining proportions. For most graphics, this is fine and does the job. My problem is that my end-product cannot be greater than 3210px in height and very once in a while I have a tall and narrow graphic. I need to somehow alter this script to check the height after resizing, and if it is greater than 3210, then to instead resize (constraining proportions) to a height of 3210.
Script I'm using to make layer graphic 2400 pixels wide |
#target photoshop function main(){ if(!documents.length) return; var startRulerUnits = app.preferences.rulerUnits; app.preferences.rulerUnits = Units.PIXELS; var doc = activeDocument; var res= doc.resolution; var LB = activeDocument.activeLayer.bounds; var Width= LB[2].value - LB[0].value; var onePix = 100/Width; var newSize = onePix * 2400; doc.activeLayer.resize( newSize , newSize, AnchorPosition.MIDDLECENTER); app.preferences.rulerUnits = startRulerUnits; } main(); |
I just need some help with how to put in the If/Then logic.
So, if it finishes that, and the height is greater than 3210, then it should probably do this:
Height resize script |
#target photoshop function main(){ if(!documents.length) return; var startRulerUnits = app.preferences.rulerUnits; app.preferences.rulerUnits = Units.PIXELS; var doc = activeDocument; var res= doc.resolution; var LB = activeDocument.activeLayer.bounds; var Height= LB[3].value - LB[1].value; var onePix = 100/Height; var newSize = onePix * 3210; doc.activeLayer.resize( newSize , newSize, AnchorPosition.MIDDLECENTER); app.preferences.rulerUnits = startRulerUnits; } main(); |
function main()
var newHeight = newSize/100 * Height;
if (newHeight > 3210) newSize = 100/Height * 3210;
doc.activeLayer.resize(newSize , newSize, AnchorPosition.MIDDLECENTER);
main();
