Locked
Cannot load apedelta.swc (reason: ERROR: Load Verify)................
Engaged ,
Sep 11, 2018 Sep 11, 2018
Hello,
I got a UI for Illustrator CS5.1 ( extension ) .It's developed few year back by others .
This extension is currently working well for Illustrator CS 5.1 version .
          Now I have to modify this extension UI for the same Illustrator version ( CS5.1) , for this I have to make current extension code running well in Flash Builder .
For running the existing extension UI code , I install the Flash Builder 4 and I configure Flex SDk 3.6A with the Flash Builder 4 and also append the required SWC file for the Project .
1.  Install the Flash Builder 4  and Configure the Flex SDK 3.6A with this .
2. Add the required SWC files.
                    After configuring all these  , this is not executing well , It's giving a warning due to that warning , it's not running .
Warning is giving due to added SWC files , It's  mention below
1. Design mode: Cannot load apedelta.swc (reason: ERROR: Load Verify). It may require classes (such as Adobe AIR components) that are not supported by design mode.
2. Design mode: Cannot load CSXSLibrary-2.0-sdk-3.4-public.swc (reason: ERROR: Load Verify). It may require classes (such as Adobe AIR components) that are not supported by design mode
3. Design mode: Cannot load apedelta.swc (reason: ERROR: Load Verify). It may require classes (such as Adobe AIR components) that are not supported by design mode.
          Please guide how I will remove this error and what is the correct swc for the crosspanding Flex and Flash Builder .
Please help me .
220
