Illustrator file only previews in Separation Preview mode.
Sep 12, 2018 Sep 12, 2018
I have an Illustrator CC 2018 file saved as .ai with PDF compatibility. It is just a rectangle with a pattern fill. The pattern uses simple shapes and a compound path filled with process black (which overprints) and a Pantone solid. When I place the file in InDesign CC 2018 the cursor previews the file, but only a blank image shows. InDesign will only preview the file when Separation Preview is on.
Odder still, whatever the image is behind does not show. So if I send the image to the back, everything is hidden. If I bring it to the front everything is visible, except the image. With Separation Preview on everything looks as it should.
I saved as IDML and deleted preferences. The problem is still occurring. This also happens when placing the Illustrator file in a new document. The file behaves normally when I expand the pattern.
Cross posting in Illustrator.
450
Community Expert , Sep 13, 2018 Sep 13, 2018
Hi Scott,
I think this is an old bug with InDesign.
The cause is the overprinting elements in the pattern.
You can try this workaround:
Add a white rectangle to the page or the spread that introduces transparency by defining a blend of 0% to its fill.
Hope, that helps…
Uwe
Hi Scott,
Hope, that helps…
Uwe
Sep 15, 2018 Sep 15, 2018
Thanks. I have never heard of this, and there was nothing on Uservoice about it that I could see. Posted bug.
Sep 16, 2018 Sep 16, 2018
Hi Scott,
did my workaround work for you?
Can you post the link to your posted bug report?
Uwe
Sep 17, 2018 Sep 17, 2018
I didn't try it. I was trying to avoid transparency issues because I'm preparing a file for overseas printing and want to avoid complications. I expanded the pattern.
