Hello,
I'm trying to import .xmp LUTs with the new profile explorer. But when I try to had it, the importation start and get this error (sorry in French), meaning (title) Import profiles (content) The Folder can't be found. I tried to desinstall and reinstall LightRoom (Losing my whole catalogue on the same time ><) and it didn't change anything... Any idea ?
Thanks !!
I was able to easily use your profile.
I simple did a Copy & Paste to the folder- C:\Users\myname\AppData\Roaming\Adobe\CameraRaw\Settings
I have Lightroom Classic v7.5 in Windows-10.
Upload one of the .xmp files to Dropbox and post the sharing link here. This will let us determine whether there's something wrong with the .xmp file or with your LR configuration.
Hi, thanks for your answer, here is one of them : Dropbox - VF-Sadatoni.xmp
If you want to make a profile that Lightroom can read from a LUT (cube or csv), you should follow the instructions and examples in the profiles SDK that you can find here. You need Camera Raw for that and I don't think there is a way to do it in Lightroom. If that is what you did to create the xmp profile than better to post the xmp file indeed.
SDK profiles here: Digital Negative (DNG), Adobe DNG Converter | Adobe Photoshop CC
Well since April 2018 release, you can use this to import .xmp .lmp or .dcp LUTs.
Thank you that worked!! I just don't understand why I could import it with the tool made for it, but anyway it works now. Thank you from the bottom of my heart.
I was able to import the profile using the Profile browser. So something is going wrong with your particular configuration. But at least you have a solution.
I was able to import it directly through the profile browser too. Not sure what could be wrong with your configuration.
