I created a test project in Responsive HTML 5 I experiment with, and use to store different designs. Now I want to create the real project, and import a screen layout from the test project. Online help just says the following: "To import a screen layout, select Import and specify an SLZ file name."
There is no illustration, and no instructions on where to go to locate "Import," which I don't see anywhere. In older versions it used to be under File, but it isn't there in 2017. When I look for .SLZ files in the Robohelp project directory, nothing displays.
How do I do this?
See Rick's post#7 in this thread - Re: Gallery doesn't show my new screen layout to export the screen layout .slz from the test project. Then I think you can right-click in the Output Setup pod and Import it in the new project.
I'm wondering if the issue is simply that the layouts created have not been exported as SLZ files. Then they are imported as Jeff describes. The Gallery issue is, I believe, when a home brewed layout needs to be imported and is not yet in a project for export / import.
See www.grainge.org for free RoboHelp and Authoring information.
