Hi. I am using the Adobe Acrobat 9 at my work. I have created a sales order form and it is not working correctly.
Everything works except for the Total Price at the bottom right. Problem stated at the bottom of this PDF setup outline.
5 columns (Quantity, Model Number, Description, Price, Total)
Each row's "Total" is the product of "Quantity" and "Price"
Bottom left block is the sum of all "Quantity" for a total item count
Bottom right block is the sum of all "Total"s for a total price
Problem: The total at the bottom right does not update until I enter the next row's "Quantity". This means that after the last item is entered, you must go to the next row and enter a "0" in the quantity. So...if someone forgets to do that, the total price at the bottom right will not be correct.
Can you help me fix this? Thank you. Brian - Omaha, Nebraska
The field calculation order is not set correctly.
Ah...I'll experiment with that. Thank you.
Thank you! It worked perfectly!
When you refer to the order of the added items, is that based on their position within the document or the order they are listed when you access the "Pick" list?
Neither. The calculation order is its own thing. It can be set in Form Edit mode, via Tasks - Other Tasks - Set Field Calculation Order.
