I'm using InDesign CC to build evaluation/score type form-fills.
I will be using this type form field repeatedly, and it will always need to have the same Properties (accept 2 numeric characters which fall within the 1-10 range).
Right now, the only way I've been able to do this is to create the layout in InDesign CC, save as an Interactive PDF, open in Acrobat and adjust the Properties of the text field from there. And I have to do it to EACH text field...
Is there a way to streamline this? I can't seem to access the field Properties menu from within InDesign. Maybe there is a way and I just haven't found it yet?
My first thought was to make it an asset in a library with all of the correct Properties set. But can't find Properties in InDesign, nor asset libraries in Acrobat. What about field "Styles"? Such a thing? Anything?
Any suggestions more experienced users have is greatly appreciated...
At this moment of time the answer is no. May be in the future releases.
Is it also true that there is no way to access form field Properties from within InDesign? Has to be done in Acrobat?
Yes, it is. When I have has such work I was pay to our programmer for do an Acrobat script to add some text properties in text fields through all pages of PDF.
Great! Thank you so much. I had looked and looked for an answer and wasn't finding any. Really appreciate it.
