Hey everyone!
Searching for your good advice!
I have a text that goes something like this:
text 88
some text poem very beautiful written
just filling the lines for your understanding
so, now I need to turn it to this:
text 88 some text poem very beautiful written
My idea was to create a text frame with the text number and anchor it to the text.
Is there a faster way to do that???
The rest of the text is in one column.
if you mean a side numbering with the word (text) before numbering, from paragraph panel menu> Bullets and Numbering
add the word text before the number under numbering style.
You can use tabs,
you have used spaces, from type> show hidden characters to see how its done, the first is what you did, the second with tabs
The thing is I have 700 verses like that to change
I have 18 chapters each in a separate file. In total it's 700 verses but in different chapters, each different number of verses.
the text number is in Paragraph style and the text itself also in a different paragraph style.
Also you can do it as table with hidden frames like below, so you can center the text within the cell.
Thanks, I'll see if that works, the thing is that I forgot to write is that I have 700 instances like that in the book I'm working on!!!
You're better off with an anchored object. Very easy to apply with object styles.
The problem with this solution is that sometimes I have verses that are together, for example:
text 1-3
