I have an Illustrator CC 2018 file saved as .ai with PDF compatibility. It is just a rectangle with a pattern fill. The pattern uses simple shapes and a compound path filled with process black (which overprints) and a Pantone solid. When I place the file in InDesign CC 2018 the cursor previews the file, but only a blank image shows. InDesign will only preview the file when Separation Preview is on.
Odder still, whatever the image is behind does not show. So if I send the image to the back, everything is hidden. If I bring it to the front everything is visible, except the image. With Separation Preview on everything looks as it should.
I saved as IDML and deleted preferences. The problem is still occurring. This also happens when placing the Illustrator file in a new document. The file behaves normally when I expand the pattern.
Cross posting in Illustrator.
Hi Scott,
I think this is an old bug with InDesign.
The cause is the overprinting elements in the pattern.
You can try this workaround:
Add a white rectangle to the page or the spread that introduces transparency by defining a blend of 0% to its fill.
Hope, that helps…
Uwe
Hi Scott,
Hope, that helps…
Uwe
Thanks. I have never heard of this, and there was nothing on Uservoice about it that I could see. Posted bug.
Hi Scott,
did my workaround work for you?
Can you post the link to your posted bug report?
Uwe
I didn't try it. I was trying to avoid transparency issues because I'm preparing a file for overseas printing and want to avoid complications. I expanded the pattern.
