For as long as I've had Creative Cloud, I've never been able to get InDesign to launch. It pulls up the loading screen but will stop there and crash. I also have Photoshop, Illustrator, Lightroom, and Premiere Pro downloaded and have never had this issue until I tried to open InDesign. I've tried everything the forums suggested before, and deleted and reinstalled Creative Cloud MULTIPLE times with nothing working. Help!!
There was a corrupt file, which an InDesign tech found and deleted.
Sent from my iPad
indesign works perfectly in win 7 to win 10, well, most of the time. What is your config?
Did you try Indesign on a fresh user profile on your computer? I had multiple times that corrupted user profiles made strange things to the software.
I tried opening InDesign on a new user file on my computer, it did the same thing. As far as configuration goes, I have no clue how to determine that (it also doesn't help that instructions on how to find that are a bit confusing)
Photoshop will tell you your configuration. Look in Help->System info. Copy the data up to "Subscription type". After that come a few personal data, the do not need to be posted here.
Below is my current one, just to give you an idea how it looks:
Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750 x64
Number of Launches: 202
Operating System: Windows 7 64-bit
Version: 7 SP1 6.1.7601.24150
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3392 MHz
Built-in memory: 16179 MB
Free memory: 2 MB
Memory available to Photoshop: 14363 MB
Memory used by Photoshop: 60 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Disabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: East Asian
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=-2, left=1920, bottom=1078, right=3840
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA Quadro K2200 "
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="10.18.13.6191"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro K2200/PCIe/SSE2"
glgpu[0].GLRendererID=5050
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
glgpu[0].GLDriverDate="20160208000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=4096
clgpu[0].CLName="Quadro K2200"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="361.91"
clgpu[0].CLBandwidth=6.43117e+10
clgpu[0].CLCompute=406.854
License Type: Subscription
Bold is what is really of interest here!
Adobe Photoshop Version: 19.1.5 20180604.r.346 2018/06/04: 1175273 x64
Number of Launches: 1
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.17134.1
System architecture: Intel CPU Family:6, Model:12, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
Physical processor count: 2
Processor speed: 1094 MHz
Built-in memory: 1879 MB
Free memory: 1185 MB
Memory available to Photoshop: 1693 MB
Memory used by Photoshop: 70 %
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 128K
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=768, right=1366
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLMemoryMB=1024
glgpu[0].GLName="Intel(R) HD Graphics"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="21.20.16.4565"
glgpu[0].GLRenderer="Intel(R) HD Graphics 500"
glgpu[0].GLRendererID=23173
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_f309e6bcb5a833d6\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_f309e6bcb5a833d6\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_f309e6bcb5a833d6\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_f309e6bcb5a833d6\igd12umd64.dll"
glgpu[0].GLDriverDate="20161210000000.000000-000"
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 21.20.16.4565"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=743
clgpu[0].CLName="Intel(R) HD Graphics 500"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="21.20.16.4565"
clgpu[0].CLBandwidth=8.23077e+09
clgpu[0].CLCompute=21.0311
It sounds like you need to contact Customer Care Contact Customer Care . They should be able to analyze your system better than can be done on the user to user forum.
They hung up on me when I called and tried to also contact through chat yesterday, but I will try again.
Hi Olivia,
We are very sorry for this bad experience. Were you able to get connected through chat? Please let us know if you need any help from our side.
Srishti
Did you ever gets this problem fixed, I am having the same issue with Indesign?
Hi there,
Sorry to hear about this. I would request you to please share a few more details like:
Also, please try resetting preferences for InDesign and check if that helps: Set preferences in Adobe InDesign
Srishti
This issue has been addressed successfully
How? What did help?
Sent from my iPad
