Hey All,
I am constantly editing videos for work but over the past week all of a sudden when I import an MP4 into Adobe Premiere Pro CC 2018 I am only able to hear the audio but can not see the video any longer. Anybody else have this issue? I have uninstalled and reinstalled the program, I have even reinstalled earlier versions with the same results. Any help would be great. I have attached an image showing the MP4 File but no image showing.
You need to run the file through Handbrake and make it Constant Framerate, then bring it into Premiere.
Will I need to do this for all videos? Here is a video I was just able to complete rather recently but now it will not display at all.
General
Complete name : C:\Users\jimpe\Dropbox (Fantasy Alarm)\Brandon Marianne Lee\Deep Cuts\9.8.18 Deep Cuts.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42/isom)
File size : 232 MiB
Duration : 3 min 55 s
Overall bit rate mode : Variable
Overall bit rate : 8 260 kb/s
Movie name : 9.8.18 Deep Cuts
Movie_More : This video is about My Movie 124
Encoded date : UTC 2018-09-08 16:06:03
Tagged date : UTC 2018-09-08 16:06:45
thmb : ÿØÿà
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 8 004 kb/s
Maximum bit rate : 768 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.290
Stream size : 224 MiB (97%)
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
This one looks fine. The first one had a wide range in framerate.
Update your videodriver.
Ok but when I upload the video into Premiere it I have the same issues. Neither video will appear just the audio
You lack the program monitor and probably also the origin, you must have windows 10, or I'm wrong ?.
You will not fix it by installing and uninstalling the program.
Press the windos + X key, device manager, screen adapters, and uninstall the graphics drivers, then reboot the PC, windows have to reinstall them, in case you do not, you do it manually, and tell us if you fix , or not.
Also, yes I have Windows 10... this is a brand new issue. The last video I was able to complete was on Wednesday. Not sure if Windows did an update or not.
