A lot of errors when syncing with lightroom classic (most of them stating: "bad argument #1 to '?' (number expected, got nil)" some others like"WFSQLiteStatement:bind() - illegal data type used as value". I have tried several things:
- delete sync date from preferences menus
- rebuild sync data, also from preferences menu
Still errors coming again. Has anyone a workaround or is Adobe dealing with the issues?
Moved to Lightroom Classic CC — The desktop-focused app​
Hi Mikaelc,
We're sorry to hear about the sync error, could you please try going to Lightroom's Preferences > Lightroom Sync and check under Sync Activity? You will see images which might be causing the issue, please try removing them and see if it helps with the issue.
Sahil
Thanks for your answer, unfortunately there are so many images with errors
that this solution is not acceptable.
Le lun. 17 sept. 2018 Ã 19:48, Sahil.Chawla <forums_noreply@adobe.com> a
écrit :
sync errors unable to solve created by Sahil.Chawla
<https://forums.adobe.com/people/Sahil.Chawla> in *Lightroom Classic CC —
The desktop-focused app* - View the full discussion
<https://forums.adobe.com/message/10625036#10625036>
