Using clients software version of Adobe Acrobat DC Pro version 2018.011.20035 on Windows 7 64 bit. Created a pdf form with check boxes last week. Sent out for comments. Tried editing form today, Monday, September 17, 2018. I added more text to my form, so had to move the text boxes. If I try one of the following methods the application crashes.
Next step, I was going to talk to our clients IT about upgrading to the latest build, but there are no release notes to support this will fix the issue.
Hi lttl.espana,
As per the issue description mentioned above, Acrobat is crashing when trying to edit a pdf form, is that correct?
Could you let us know if this happens with this specific pdf form? Have you tried with another pdf form or editing a test pdf file( without form fields)?
Would it be possible to share the pdf form you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
You may also share the link for the pdf via private message - How Do I Send Private Message
Let us know if you need any help.
Shivam
No, I could not recreate the issue. I did try to within another document, but was unable to recreate the issue.
I ended up recreating the document, and this time the pdf form did not crash after I created new check boxes. Plus I added security lock which seems to be helping. I will know next week how my new document is holding up, for we will be distributing it out to our staff for usage.
