Hello, I'm having an erro with Coldfusion, and I'm curious if
this is a known issue, or if it's something I can fix on my side.
Well the biggest problem is that a page that I have that uses
an insert statement is inserting the record it's supposed to insert
once, twice. So I'm getting double the records inserted into the
database than I want.
I checked the IIS logs, and I see three requests for the page
with the following status codes: 401.5, 401.1 then 200. I use the
CGI username to log the user in, because that way the user doesn't
have to type in their username and password everytime they log in.
So what I'm getting from those status codes is that the page is
trying to get the CGI variables, it fails, then it gives the
generic login failed status, then it finally gets the user's info
and logs them in correctly.
I'm trying to find out if there's someway that I can get the
user to login on the first request instead of having to make 3 of
them everytime. I am using coldfusion version 6,1,0,83762. Is that
something that that version of Coldfusion just has problems with or
is there something that I can do to fix this?
Any help would be absolutely amazing, and I appreciate your
time immensely
Thanks again,
Aaron
