So I've made a script to change data in multiple tables. I want to target each table by looking for an index-number. This index-number is generated with a Paragraph Style Bullets & numberings (then using just a space to print that) inside a table cell. I wonder, is there anyway to actually target that value?
Here's a rough example:
Table one | index_0 |
Value 1 | value 2 |
Value 3 | Value 4 |
Table Two | index_1 |
Value 1 | value 2 |
Value 3 | Value 4 |
Here's my code that works with normal text in a cell:
app.findGrepPreferences.findWhat = "index_0"; // Find table with index
Here's a full example of my code (more items in wee though, just left two in there, will that help?
...var week_2020_1 = {
index: "item_0",
week: "Vecka 1",
month: "December",
year: "2020",
monday: {
date: "31",
spec: "Nyårsafton",
holiday: true
tuesday: {
date: "01",
spec: "Nyårsdagen",
holiday: true
wednesday: {
date: "02",
spec: "",
holiday: f
… For doing what after? …
Best,
Michel, for FRIdNGE
Well, it doesn't really matter for the question in hand, but to match tables with an array of variables and then inserting them as data in the tables.
Carl,
Give a sample with screenshots!! Thanks! …
Best,
Michel
var week_2020_1 = {
index: "item_0",
week: "Vecka 1",
month: "December",
year: "2020",
monday: {
date: "31",
spec: "Nyårsafton",
holiday: true
tuesday: {
date: "01",
spec: "Nyårsdagen",
holiday: true
wednesday: {
date: "02",
spec: "",
holiday: false
thursday: {
date: "03",
spec: "",
name: "Alfred, Alfrida",
holiday: false
friday: {
date: "04",
spec: "",
holiday: false
saturday: {
date: "05",
spec: "",
name: "Hanna, Hannele",
holiday: false
sunday: {
date: "06",
spec: "",
name: "Kasper, Melker, Baltsar",
holiday: true
var week_2020_2 = {
index: "item_1",
week: "Vecka 2",
month: "Januari",
year: "2020",
monday: {
date: "07",
spec: "",
name: "August, Augusta",
holiday: false
tuesday: {
date: "08",
spec: "",
holiday: false
wednesday: {
date: "09",
spec: "",
holiday: false
thursday: {
date: "10",
spec: "",
name: "Sigurd, Sigbritt",
holiday: false
friday: {
date: "11",
spec: "",
name: "Jan, Jannike",
holiday: false
saturday: {
date: "12",
spec: "",
name: "Frideborg, Fridolf",
holiday: false
sunday: {
date: "13",
spec: "",
holiday: true
var weeks = {
item_0: week_2020_1,
item_1: week_2020_2,
for (var item in weeks) {
//alert(weeks[item]['week']);
//updateWeekTablesData(weeks[item]);
insertWeekTablesData(weeks[item]);
/* UPDATE WEEK TABLES */
function updateWeekTablesData(itemData) {
app.findGrepPreferences = app.changeGrepPreferences =null;
app.findGrepPreferences.findWhat = itemData["index"]; // Find table with index
var found = app.documents[0].findGrep();
for(i=0; i<found.length; i++)
if(found.contents)
found.select();
alert(found.contents);
replaceData();
function replaceData() {
var source = app.selection[0].parent.parentColumn;
var table = source.parent; //Target table of selection
function newMonthData(newMonth, newYear) {
//ri = row index
//ci = column index
var tableCell = {
month : table.rows[1].cells[10],
year : table.rows[1].cells[11],
tableCell["month"].texts[0].contents = newMonth;
tableCell["year"].texts[0].contents = newYear;
return newMonthData;
var monthyear = newMonthData(itemData["month"], itemData["year"]);
function newDayData(ri, ci, newDate, newSpec, newName, holiday) {
//ri = row index
//ci = column index
var tableCell = {
date : table.rows[0 + ri].cells[0 + ci],
day : table.rows[1 + ri].cells[0 + ci],
spec : table.rows[0 + ri].cells[1 + ci],
name : table.rows[1 + ri].cells[1 + ci]
tableCell["date"].texts[0].contents = newDate;
tableCell["spec"].texts[0].contents = newSpec;
tableCell["name"].texts[0].contents = newName;
if (holiday == true) {
tableCell["date"].appliedCellStyle = "date-holiday";
tableCell["day"].appliedCellStyle = "day-holiday";
} else {
tableCell["date"].appliedCellStyle = "date";
tableCell["day"].appliedCellStyle = "day";
if (newDate == itemData["sunday"]["date"] || newDate == itemData["saturday"]["date"]) {
tableCell["spec"].texts[0].contents = newName;
tableCell["name"].texts[0].contents = newSpec;
return newDayData;
var monday = newDayData(0, 0, itemData["monday"]["date"], itemData["monday"]["spec"], itemData["monday"]["name"], itemData["monday"]["holiday"]);
var tuesday = newDayData(0, 2, itemData["tuesday"]["date"], itemData["tuesday"]["spec"], itemData["tuesday"]["name"], itemData["tuesday"]["holiday"]);
var wednesday = newDayData(0, 4, itemData["wednesday"]["date"], itemData["wednesday"]["spec"], itemData["wednesday"]["name"], itemData["wednesday"]["holiday"]);
var thursday = newDayData(0, 6, itemData["thursday"]["date"], itemData["thursday"]["spec"], itemData["thursday"]["name"],itemData["thursday"]["holiday"]);
var friday = newDayData(0, 8, itemData["friday"]["date"], itemData["friday"]["spec"], itemData["friday"]["name"], itemData["friday"]["holiday"]);
var saturday = newDayData(2, 0, itemData["saturday"]["date"], itemData["saturday"]["spec"], itemData["saturday"]["name"], itemData["saturday"]["holiday"]);
var sunday = newDayData(4, 0, itemData["sunday"]["date"], itemData["sunday"]["spec"], itemData["sunday"]["name"], itemData["sunday"]["holiday"]);
The first step in your script would be to replace the automatic paragraph numbers with literal text. Something like this (Select the frame that contains the table):
cells = app.selection[0].tables[0].cells.everyItem().getElements();
for (i = 0; i < cells.length; i++) {
if (cells.paragraphs[0].bulletsAndNumberingListType == ListType.NUMBERED_LIST) {
cells.paragraphs[0].contents = cells.paragraphs[0].bulletsAndNumberingResultText;
Then disable automatic paragraph numbering in the paragraph style. Maybe another approach is more efficient, depends on what your table looks like.
P.
So, there's no way to actually search the output of a numbered list without converting it?
I'll try this and see if it works alright
I don't understand how your marked self-answer answers the question. To check, I attempted to run your script but I don't see what it should be run on.
What does "search the output of a numbered list without converting it" mean? If you have a numbered list "1, 2, 3" and you want to search for "2", yeah, that won't work. But you can iterate over the list and inspect their "bulletsAndNumberingResultText". Basically, what Peter said two weeks ago.
Use the paragraph's bulletsAndNumberingResultText property.
Sorry, pretty new to inDesign-scripting could you give a code example please?
I used code above, but used a GREP-search instead:
f
unction convertIndexToString () {
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = "\\b\\w+?\\b";
app.findGrepPreferences.appliedParagraphStyle = "vecka.index";
indexFound = app.activeDocument.findGrep();
if (indexFound) {
for (f = 0; f < indexFound.length; f++ ) {
thisItem = indexFound
; if (thisItem.paragraphs[0].bulletsAndNumberingListType == ListType.NUMBERED_LIST) {
thisItem.paragraphs[0].contents = thisItem.paragraphs[0].bulletsAndNumberingResultText;
