Hallo,
auch wenn in PhotoShop CC unter "Bearbeiten -- Voreinstellungen -- allgemein" das Häkchen bei "Bild beim Platzieren skalieren" nicht gesetzt ist, wird das eingefügte Bild immer noch skaliert. Was mache ich falsch?
Hi JossieX,
Sorry that your image scaling changes while placing the image in Photoshop.
Which version of Photoshop CC are you using?
What size is the image and to which size is it scaling to?
Also, take a look at this discussion Wrong image size when placing and let us know if that helps.
Akash
thanks for your fast reply. Reading the other thread I learned that the resolution associated with each image governs the scaling. However, I would have thought that if I uncheck the option for scaling no scaling would be done and the image imported would be placed into the image on a pixel to pixel basis. This is what I want.
Hermann-Josef
Hi JossieX,
Since one can obviously let go hope for Adobe-sided fixes, did you find a proper workaround yet?
