Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Target Recommendation Feed Via URL
Avatar
Level 3
  1. In the create Feed section, if instead of FTP, we select URL than which URL we should have it? Could it be URL of AEM DAM if we save our file there?
1 Accepted Solution
Avatar
Correct answer by
Employee
Hi Abhishek,
The URL seems to be a local host which cannot be accessed externally. Could you please upload the feed on a URL which is accessible over the internet without authentication.
The unknown error is most likely being caused because recommendation is not able to access the local host
Raag
Avatar
Employee
HI Abhishek,
As long as the feed contains data in the right format and the URL does not require authentication you should be good to go. However if the URL requires authentication then you should opt for FTP because I don't think we setup credentials for URL method.
Hope that helps.
Raag
Avatar
Level 3
Hi Shanker,
As in the recommendation Feed sample by Adobe, first column is for "## RECSentity.id"
Could you please let me know, what different datatypes are possible in "## RECSentity.id"? i.e Alphanumeric/numeric/character etc.??
Could we use Page URL in  "## RECSentity.id"?
Avatar
Employee
Hi Abhishek,
Entity ID is the product ID which is used to identify the products uniquely on the page. It can be Alphanumeric but not suggested to be a URL. You can refer below document for more details on entity ID
Entity Attributes
Hope that helps.
Tanvi
Avatar
Level 3
Hi Shanker
I tried uploading a feed via URL approach
Below are the steps I took
In the Publish instance of AEM DAM I uploaded a .csv file (feedwomenpage.csv).
PFB URL of feed http://localhost:4503/content/dam/we-retail/feedwomenpage.csv
Feed is available, if I check putting this URL in chrome browser
(I created a sample feed after downloading the format from Adobe Target console itself)
I provided this URL in Adobe Target console, in creation of feed section via csv and URL
In schedule section, I scheduled it for daily, and provide time after 5 minutes of the time when I created this
It does not ask for any mapping, environment all host groups and I saved it
The Feed status Changes from Waiting for downlaod --> Unknown Error (PFA image of error)
Kindly help me in understanding, where I am going wrong, Why this "Unknown Error" is coming??
Avatar
Level 3
Tanvi
Avatar
Correct answer by
Employee
Hi Abhishek,
Raag
Avatar
Level 3
Hi Shanker,
Hope you are doing great !!
My query is
I have two separate product lines
The recommendation activity which I want to run for these two different product lines is on their respective product pages
The few details which got displayed (look and feel) about these products is also different
In such a scenario,
Do I need to take one combined feed for both type of products from AEM OR should I take two separate feed from AEM. One for each type of product??
If there are two feeds, then will these two feed update the same space in recommendation catalog?? OR we can also do a separation between recommendation catalog for these two product lines??
