After 10-20 editing, the controls on the Develop become disabled. There is a " Loading Box" on the bottom of the screen. This is on a brand new system, a I7, 16 gb Ram, 500gb SDD, 1060-4gb GPU. It was doing it on the old system so I was hoping for improvements in the new computer. Turning the GPU on or off makes no difference. When I exit LR I do get a message about Plugin Photoupload becoming unresponsive but you don't see this until the program exits.
Suggestions?
Al
Disabled meaning greyed out? Or something else?
So the develop module controls never become active again (as opposed to disabled) no matter how long you wait?
Can you show us a screen capture of this?
It finally did it again after two days. Typical editing and using Pinterest
plugin to export. After this photo, develop stopped working for all photos
in the library. This is after a 10 minute wait.
Thanks for looking into this.
Al
Al
This does not appear to answer my questions or request for information.
Happened on 9/24, after about 8 successful exports to an internal drive, the Export dialog froze and no more Develop. Develop Control is frozen but Library still works. It wil stay this way until I exit LR and kill the task. This is on a new system.
It appears to be frozen during the exporting of an image using the Pinterest plug-in. Don't know anything about that plug-in. You might check with its developer to see if there is an issue to consider.
Get the same results on LR export. A typical export of a one low res jpg to my internal HDD takes seconds but after 7 or 8 of these the export box in the upper left corner just sits for minutes for one file. You can leave it hanging for a long time but it still remains on the screen. Then occasionally the Dev module is disabled. My solution is to exit LR, go to the Task Manager and kill the LR task which is still running and restart LR. This is on the new computer, new W10.
After 18 minutes waiting for LR Export. One file, 1200 pix, jpg. Previous files took seconds.
