I hope someone can help. I have a Sony HDR-FX1 camera and using Premiere Pro CC the video doesn't show in the Capture window. No changes to the computer except Pro CC was updated.
My video settings are correct as far as I can tell. It does still capture the video though.
Any Ideas would be appreciated.
Please check to make sure that the capture format box in the capture panel matches the format of the video that you are trying to capture.
It does, Video and setting is HDV
You may want to re-start the machine and see if the video drivers are up to date. You may want to try capturing even if you can’t see the video in the capture window. This has happened to me in the past with HDV video. I was still able to capture, I would just have to watch it on the capture devices monitor.
Not ideal... But it worked.
The last time I captured hdv on the latest build I did not have preview either but it did capture.
If you want preview you might want to use HDV split.http://www.videohelp.com/software/HDVSplit
