The exact same issue has now happened to me on two different completely independent systems. Both running 12.1.2
Problem - When moving an un docked window, the source and record windows stop updating and freeze, occasionally with a white screen, but can also be in the middle of a re-draw, or can go black. When this happens, you can not scroll through the time line, or the source, but you can hit play and hear audio. You must crash Premiere. It will either freeze and not exit - or if it does exit, it remains running in the background and must be terminated. Then you frequently can not export. Media Encoder freezes and must be terminated.
Two different systems, two different CC accounts do EXACTLY THE SAME THING. The only common issue I can find is that in both cases, the project was "up-converted" from a previous version. Sometimes the issue will clear on a restart of Premiere, sometimes on a restart of Windows, and sometimes you need to manually trash the preferences.
I have been on the phone with Adobe for a grand total of 12 hours with 3 different techs, and no one can seem to fix this issue. The last thing I got was "Well, Premiere is really only designed to run on a single monitor" which is complete BS - AND - the problem still happens when run on a single monitor. We have tried cashe clears, different media, new user accounts, uninstall and reinstall of graphics drivers, updated graphics drivers, clean reinstall of the program using CC Cleaner, and multiple other steps with no improvement. The tech can get it working long enough to get me to say the words "appears to be resolved" so they can get off the phone call but in less than half an hour I'm right back where I started and back on the phone. I CANNOT USE THE SOFTWARE THIS WAY.
System 1 is literally BRAND SPANKING NEW, right out of the box. It has no other software on it. System 2 has run Premiere in a multiple monitor situation for nearly 5 years without a major issue until this update.
System 1 - Alienware I9, 32gig ram, Nvidia 1080 video card. Windows 10 pro, 64 bit
System 2 - HP Envy, i7, 12gig ram, Nvidia 840m, Widows Pro, 64 Bit
Can anyone make any suggestions???? At this point I cannot revert because the projects already have work done to them which would be lost. I have not verified the problem with a new, clean project. If anyone from Adobe is listening, this is a HUGE problem that needs to be solved.
We have found the problem. After more than 10 hours on the phone with Adobe - a mere 30 minutes on the phone with Dell Tech Support (alienware) solved the problem.
There is a conflict between the Nvidia G-Sync and Adobe PRemiere. Disabling G-Sync in the Nvidia control panel solved the issue.
It sounds like you are constantly moving undocked windows around while other processes are running?
Neil
No. I am not "Constantly" moving an undocked monitor. However, if you
have to frequently reset your preferences, you do find yourself
frequently undocking and moving windows to get your workspace back the
way you like it. And crash.
It can happen any time, however it happens most often when adjusting or
moving an undocked window.
I like to work with my timeline and source windows on one monitor, and
my program window on the 2nd. Frequently I put my bins and project
window to the left on a third. The program window may occasionally
require adjustment. Then crash....
Ahh... your first post wasn't clear about that.
PrPro can be finicky about which monitor the main window (with menus) is on. And from others posting on here, moving project panels away from that monitor can be dicey.
I only run 2 so far. I got a very wide main monitor just to keep from running three.
Neil
Many monitor functions need to be turned off before they're useful for pro video editing. All the gaming/enhancing-the-experience stuff. A lot of people don't do this, sadly.
Neil
