Me va demasiado lento el Premiere, tanto en la edición y vista previa como en la renderización, pues me tardó alrededor de una noche exportar un video a un .wmv de tan solo 130MB de peso, NECESITO SABER URGENTEMENTE EL ORIGEN DEL PROBLEMA ESPERO QUE ALGUIEN ME PUEDA AYUDAR, Muchísimas gracias...
Mi ordenador es un portátil ASUS F555L:
I7-5500U
NVIDIA GEFORCE 920M
12GB RAM
DOS DISCOS DE 1 TB HDD
WINDOWS 10
PREMIERE PRO CC ULTIMA VERSIÓN
Hi acsinframe,
The hardware requirements for Premiere Pro for getting better performance will be dependent on the complexity of the timeline and the type of media and effects applied to the media clips. Generally, to edit 4K or higher resolution media efficiently you would need a better processor like i7 8700K or higher and also a better GPU like GTX 1080 or similarly performing GPUs. RAM requirement would be dependent on the length and complexity of the timeline. Usually, 32GB-64GB should be a g
...Copy link to clipboard
That is only a dual core processor and you should have more RAM.
You need a more powerful computer.
Hi acsinframe,
The hardware requirements for Premiere Pro for getting better performance will be dependent on the complexity of the timeline and the type of media and effects applied to the media clips. Generally, to edit 4K or higher resolution media efficiently you would need a better processor like i7 8700K or higher and also a better GPU like GTX 1080 or similarly performing GPUs. RAM requirement would be dependent on the length and complexity of the timeline. Usually, 32GB-64GB should be a good starting point.
You may refer to this link to know how different hardware would perform with Premiere Pro.
Hope you find it useful, let us know if you have any questions.
Regards
Sumeet Kumar Choubey
