Hi!
I have a table that I'm changing the first row cells to graphic cells with this script:
app.selection[0].properties = {
leftEdgeStrokeWeight:0,
rightEdgeStrokeWeight:0,
topEdgeStrokeWeight:0,
innerColumnStrokeWeight:0,
graphicRightInset:2,
graphicLeftInset:1,
graphicBottomInset:2
app.selection[0].convertCellType(CellTypeEnum.GRAPHIC_TYPE_CELL, false);
First row selected after run the script:
Before run the script:
My question is: With the row selected like in the image, how can I reach (with a loop?) each frame inside each graphic cells to apply a object style? Without need to select one by one to apply?
My final goal is something like that:
Hope that I explained in the right way.
Thanks in advance!
app.selection[0].allPageItems should give you all the rectangles
-Manan
-Manan
I used your answer with a loop and works!
var myDoc = app.activeDocument;
var mySel = app.selection[0].allPageItems;
for (i = 0; i < mySel.length; i++) {
mySel.appliedObjectStyle = myDoc.objectStyles.itemByName("cell");
Thank you so much!
