I consolidated several clips into a sequence (item). The newly created sequence doesn't use the original source timecode. The timecode from the sequence starts from zero. Does anyone know how i could display my source timecodes?
Many thanks,
Clem
In the bottom right corner of the Program Monitor, click on the wrench icon and on the drop down menu, select (check, toggle on) Overlays.
If you choose Overlay Settings, you can configure the type a placement of the overlay information:
MtD
MtD
Thank you so much!
Alternatively, use the Timecode Window or the Info panel. Both can show you source timecode.
some reason this is not working on one of my producers work stations
PS in the window with the clips they all start at 0 and not like 12;02:22
