4 Replies Latest reply on Sep 28, 2018 11:26 AM by Dan Niemi
    Script to select a color swatch?
    plug_in_guy
      What is the JavaScript code to select a color swatch in InDesign CS4, assuming I have the zero based index of the color swatch I want to select?
      TIA,
      Steve
        • 1. Re: Script to select a color swatch?
          [Jongware] Most Valuable Participant
          There is no such thing.
          JavaScript does not control or mimick the user interface; rather, it works directly with objects in the documents and application itself. Instead of selecting an object and applying a swatch, you can apply any swatch directly to any object. The swatches themselves are objects, but not selectable ones -- you can only select document objects.
          However: if you have the reference to a swatch (for example, by index), you can manipulate it: duplicate, remove, change its color, etc.
          I assume your goal is not to select a swatch as such, but rather do something to/with one. If you explain a bit more, there might be a more conventional way to do what you intend.
          1 person found this helpful
          • 2. Re: Script to select a color swatch?
            plug_in_guy Level 1
            Jongware
            Thanks for your post. I understand what you are saying and perhaps I wasn't clear enough in explaining what I needed. I wanted to select a color swatch so that the next object the user drew would be the color my script selected. I discovered and settled on the following after much pain:
            var myDoc=app.activeDocument;
            myDoc.selection = NothingEnum.nothing;            // deselect all objects to prevent replacing the color of an object that might be selected already
            myDoc.pageItemDefaults.strokeColor = "None";   // set document default stroke color to "None"
            myDoc.pageItemDefaults.fillColor = "red";            // set document default fill color to "red" where "red" is the name of the color I wanted
            This might "encourage" (or make it easier for) the user to draw objects in the color I've left him/her auto-selected to.
            Thanks again,
            Steve
            • 3. Re: Script to select a color swatch?
              Yes, I see what you intend.
              Setting the default fill and stroke does the trick -- that's entirely similar to what happens in the UI as well.
              You could add this a refinement: if the user has one or more objects selected, you could apply the color. Something like
              if (app.selection.length > 0)
              for (var i=0; i<app.selection.length; i++)
                app.selection[i].fillColor = app.activeDocument.swatches[myFill];
                app.selection[i].strokeColor = app.activeDocument.swatches[myStroke];
              • 4. Re: Script to select a color swatch?
                Dan Niemi Level 1
                I am looking to set the default stroke and fill using a combination of the scripts above. It works for the most part, but when I use black as the fill, the stroke does not change to none. Here's a sample showing the fill change only when I run the below script. What am I doing wrong here? Thanks.
                var myDoc = app.activeDocument;
                var myFill = "Black";
                var myStroke = "None";
                var myTint = 100;
                // set active fill color
                myDoc.pageItemDefaults.strokeColor = myStroke
                myDoc.pageItemDefaults.fillColor = myFill;
                myDoc.pageItemDefaults.fillTint = myTint
                // Apply to selected
                    app.selection[i].strokeColor = myDoc.swatches.item(myStroke);
                    app.selection[i].fillColor = myDoc.swatches.item(myFill);
                    app.selection[i].fillTint = myTint;
