Script to hide layer named "Draft" in multiple files.
Sep 28, 2018 Sep 28, 2018
new to scripting... please help! I have this script:
app.activeDocument.save();
var myWaterLayerName = "Draft";
try{app.activeDocument.layers.item(myWaterLayerName).visible = false;}
catch(_){alert("Can't find layer: " + myWaterLayerName);exit();};
that hides a layer in the active document. how can i modify to work on all open documents?
Scripting
1.3K
Community Expert , Sep 30, 2018 Sep 30, 2018
Hi Malcom,
you need no loop because you can work with the collection of documents:
app.documents.everyItem().layers.itemByName("Draft").visible = false;
This is working even if some of the documents do not contain a layer named "Draft".
getElements() will give you an array. Because of that you have to loop.
Uwe
[ moved from InDesign  to InDesign Scripting  ]
Participant ,
Hello!
I am new at scripting as well, but I think I’ve come up with a solution for you. The script may take a while to run if you have a lot of documents open.
Try the code below.
        for(myCounter = app.documents.length;
              myCounter > 0;
              myCounter--){
        try{
            app.documents.item(myCounter-1).layers.item(myWaterLayerName).visible = false;
            app.documents.item(myCounter-1).save();
a similar but simpler script to do the job,
var toHideLayers = app.documents.everyItem().layers.itemByName("Draft").getElements();
for ( var i = 0; i < toHideLayers.length; i++)
    toHideLayers.visible = false;
This will get the layer called "Draft" from every open document.
Hope this helps.
Malcolm
Hi Malcom,
Uwe
Oct 01, 2018 Oct 01, 2018
thanks! this is working perfectly! Much appreciated.
Of course, don't know how I didn't see that.
Regards
Malcolm
thanks everyone for the help!
