I logged in to Premier to get this:
That is a list of missing fonts. I am unable to do any playback and Premier locks up. It worked fine yesterday. Any help is greatly appreciated. Thanks in advance.
There are threads here that describe how to fix weird stuff that happens during your start of the program ( whatever version that is or OS). Basically, just do a search in forum for " fix weird stuff " and you'll find it.
No such luck. Is it worth it to uninstall and re-install the program?
I don't know. If your program worked before with fonts installed but now all of a sudden they aren't there, then maybe you did something in computer that effected that, or maybe a gazillion other things. There's a way to start the program 'fresh' and you should probably try that first. Otherwise you have to supply more info ( how to ask question info needed for others to help).
Or just re-install but use that cleaner tool thing … maybe someone else will be a font expert and give you magic solution.
