Font rendering issue..
Occurrence: PDF files.
Arial font working OK in other applications.
Attached images: Left, friend's screen. Right, my screen
Hi kfir-br,
As per the issue description mentioned above, you are facing issue with fonts when viewing a pdf file in Acrobat, is that correct?
Could you try changing the settings under preferences as the following forum threads suggest and check if that works:
Is there a fix for jagged poor font quality and bad image resolution (Installation & updates)
Font rendering extremely bad (no anti-aliasing, nearest neighbor)
Let us know if you need any help.
Shivam
Shivam,
I've tried all the options in "rendering" section, it didn't solve the problem.
Thanks.
Hi kfir-br,
Could you confirm dot version of Acrobat and the operating system you are using on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Also, would it be possible to share the pdf file you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
You may also share the link for the pdf via private message - How Do I Send Private Message
-Shivam
