Hello, I was wondering if anyone has had any experience using a PDF in full screen mode using a touchscreen display? I have an interactive PDF that I've made using Adobe Indesign and when I click on an area that is not a button in the PDF it shows an 'x' close button which allows the user to exit from the PDF. Is there a way to disable that? Many thanks.
Hi Alvista123 ,
As you want "close" button to not appear when clicking on an area which doesn't have interactive field on the pdf in Acrobat in full-screen mode, disabling this option is not available as this behavior is as designed.
Let us know if you have any further query.
Shivam
Hi Alvista123 ,
Shivam
I've created fullscreen touch files for the past 11 years and am only now seeing the "X" button pop up when someone touches a non-button part of the screen.
The "X" button appearing gives the user the option to close the window, which is something I don't want them to have.
Surely there is a way to diable this.
I having this isue problem also. I use this full screen as interactive project with tablet device running in adobe acrobat dc. The close button keep show and use click exit the full screen mode. I try find out the solution or javascript till can't get it. Please help...
