When I use any lut on my video clip the video will have a couple frames that glitch (Image pictured below) but when I turn off CUDA and turn on M.P.E GPU Acceleration and export the video the glitches are not present in the video. If I use the CUDA to export i will see the glitches in the video. Does adobe have a fix for this
I have tried installing and uninstalling Premiere and still have the problem
Computer Spec
Intel Core i7 @ 3.20GHz
Coffee Lake 14nm Technology
RAM
64.0GB Dual-Channel Unknown @ 1333MHz (16-18-18-38)
Motherboard
Micro-Star International Co. Ltd. Z370-A PRO (MS-7B48) (U3E1) 33 °C
Graphics
K272HUL (2560x1440@59Hz)
4095MB NVIDIA GeForce GTX 1050 Ti (MSI)
Sounds like a video driver issue. As you've got an Nvidia card, go to their website and manually check for and download the latest driver. If you are on the latest driver, try rolling back one.
Neil
Sorry for the later response, the problem did not go away when I rolled back to a earlier version.
Don't know if it is my lut that is causing the problem. Hard to say
So you've tried both the latest driver available and rolling back?
Neil
Yes
Huh. I'm on a PC, using LUTs every so often, more in some things than others. Not having any issues.
From looking at the specs of your rig nothing looks at all amiss. So looking farther afield ...
What is the media used and what created it?
Are you exporting directly from PrPro or queuing over to Media Encoder?
Do you have either Max Bit Depth or Max Render Quality checked on in the export dialog box. If you do, *uncheck* then both, export, and see if it still occurs.
Neil
AndersonB,
Have you tried a different LUT? Let us know.
Kevin
