I'm unable to work, Acrobat crashes when I try to copy and paste text from comments to a Indesign file.
Check-mark button has disappeared from comments. Does anyone knows how to check-mark comments without using the menu or the shortcut (shift-K)?
iMac late 2015, 24Gb/1Tb, macOs High Sierra 10.13.6
Hi Bpossum,
As per the description above, Acrobat is crashing when trying to copy paste text from pdf to an indesign file, is that correct?
Could you try rebooting the machine once and try copying text into an InDesign file and check if Acrobat still crashes?
Also, you can checkmark the comments by right-clicking one of the comments and select "Add checkmark". Please find below the screenshot for the same:
Let us know if you need any help.
Shivam
Hi Bpossum,
Shivam
