quote:
Originally posted by: Colum McAndrew
Have you got the "TOC & Index" and "Search" tabs selected in your window properties? Even though you are using the window in your master project, without these options selected in the slaves, it will not build the necessary index keyword and search term lists.
quote:
Originally posted by: NL_Derek
I have had a similar problem; in my case I solved it by editing the HHP and XPJ files.
Open these files using Notepad (close RoboHelp first) and look for the merged files entries (usually near the end). In the HHP file (projectname.hhp) you should find an entry like:
[MERGE FILES]
FirstSlaveFile.chm
SecondSlaveFile.chm
In the XPJ file (projectname.xpj) you should find:
<mergedhelpfiles>
<file>
<name>FirstSlaveFile.chm</name>
<comments></comments>
</file>
<file>
<name>SecondSlaveFile.chm</name>
</file>
</mergedhelpfiles>
In my case these entries contained absolute path names like:
C:\RoboHelp\MyProject\FirstSlaveFile.chm
and this was messing up the search. I edited both files and deleted the CPD; that solved the problem.
--- Derek
Like Derek I have never used TFS but this can not be the cause of the problem if it works on your PC. This goes back to the question I asked about the test PC. If it doesn't have the required s/w components installed, it won't work!
to prove this copy one of the child CHMs across and search on a term that you know exists. Does this work?
