I'm using RH HTML 7.0.3 on Windows XP Pro, SP3. Two
disturbing symptoms have suddenly begun to occur, only within the
last week.
Symptom 1: In only one project, my compiled CHM file no
longer displays browse sequences. Nothing relevant in the project
has changed (for example, the windows definition correctly
specifies that browse sequences be displayed) as far as I know.
Other CHM files in other projects that were compiled over a week
ago and earlier all display browse sequences (the HHActiveX.dll
file is installed). Browse sequences in the broken project CHM file
are displayed neither on my PC nor on other PCs.
Symptom 2: Another problem has begun to occur within the same
time frame (within the past week): when I click any TOC book or any
TOC topic in the CHM file, the following HTML Help Author Message
appears: "The window name "<name>" passed to HH_GET_WIN_TYPE
has not been specified." But it HAS been specified, and correctly.
(I've even checked all the XML project files.) Other CHM files that
were compiled over a week ago and earlier do not evoke this author
message. The HTML Help Author Message appears only on my PC (where
RH is installed)—it does not appear on other PCs (where RH is
not installed), and it appears only in the CHM that I'm currently
working on. (I should add that I've deleted all my RH Window
definitions and created new ones, but this has not changed the
behavior.)
One other odd symptom that I suspect might be relevant: after
I compile the CHM, the following three files appear in the top
level folder of the project: ~$<projectname>.BRS,
~$<projectname>.hhc, and ~$<projectname>.hhk
Does anyone have an idea what might be causing these two
symptoms? or where to start looking in order to fix the
problem?
