I have an image of an old document that consists of 2 facing pages. I want to make a version of each page individually and so I cropped the image to include one of the pages. I did some edits with exposure and color and exported it to a jpg. Now I want to do the same thing with the other page. But I cropped the other page out and I can't reimport the image since it's already been imported into LR. How can I access the original image and what should I do in the future with the same scenario? Make a copy of the image in LR so I can work on both sides separately? Thanks.
If you cropped in Lightroom only-
1) create a Virtual Copy of the (now cropped- Page 1) image in the Grid view (shortcut= Ctrl+' )
2) Select the Virtual Copy and Click on the [Reset] button. You should now see the 'original' image of "2 facing pages" re-appear.
3) Crop and Develop the Virtual Copy for Page 2.
Note that the two Previews (Original and Virtual Copy) are still referencing the one same original file, so you would need to Export each version to have separate files of Pages 1 and 2 if
...Copy link to clipboard
Note that the two Previews (Original and Virtual Copy) are still referencing the one same original file, so you would need to Export each version to have separate files of Pages 1 and 2 if needed for a printer or such.
Thank you. Where is the reset button? Isn't it supposed to be in the bottom right corner? As you can see from my screen shot, it's not.
It will be in the bottom right when you go into develop mode. In library (where you are now) you can reset the image using the reset all button in the quick develop section on the right.
Thank you!
Assuming that your tone and color edits for Page 1 will be valid for Page 2 as well, there is no need to do a reset of all the edit settings; resetting and then recomposing only the crop tool will be enough:
