I feel like Premiere Pro is adding useless frames in my video when i import it.
Original video is smooth and something is always happens in it.
When i add it to Premiere Pro i have a few static frames, so when i try to preview it it looks like it is freezed, but its not freezed. When i watch it frame by frame, there are bout 5-6 frames which are the same. This is not in original video.
First i thought that i have problems with preview and i tried other videos and they work just fine. I don't know why it does this to my specific video.
They are all same format, same bitrate, etc. This one with problems its just a bit longer, about 40-45 seconds. The rest of them are under 15 seconds.
It's really frustrating. I tried to also render it cause i said " Well, ok, maybe its a preview bug, but it should render it correctly" and it doesn't. It renders those frames which are the same.
How was this video created? What is the format and frame rate?
Try to delete the files from the previous folder in the folder of your project, maybe those previews are playing tricks on you. Also, delete the media cache, this can also work.
We didn't hear back from you, g0dafk? Is everything OK now?
Kevin
