Rokinon/Samyang have a profile available for their 24mm T/S lens. I have downloaded the profile - it is a .lcp file - and have copied into the following location
C:\Users\UserName\AppData\Roaming\Adobe\CameraRaw\LensProfiles\1.0
I also tried installing it in the root LensProfiles folder.
In both cases, the profile does not appear in either Lightroom nor Camera Raw. Lightroom was closed when the profile was copied to the folder and re-opened afterward.
Does anyone have insight into the installation of lens profiles and why the profile may not be showing up?
Thanks.
Lens profiles are normally for raw images or jpeg images, not for both. Have to checked that you have selected the correct image type? The location should be correct.
I assumed, perhaps incorrectly, that the profile would be for RAW files. I'll create a JPEG and see what happens.
I downloaded the 24mm T/S lens profile for Nikon D800E (I have Canon full frame cameras but there are not versions for full frame Canon) and opened it with a text editor. It looks like it's not a raw profile:
<stCamera:CameraRawProfile>False</stCamera:CameraRawProfile>
Thanks JohanEl54. That may be the issue. I'm using a D800, but the profile shouldn't be body specific.
You can try turning the profile into a raw-specific profile by simply editing the lip file in a text editor and setting the CameraRawProfile property to True. It might work.
Will give it a try tomorrow.
That might make the profile available when a raw file is selected, but it won't be a raw-specific profile. It will still be a profile created with jpegs.
True. But the barrel distortion should be consistent. So if the profile has been created to correct that in the unshifted state, it's fine.
Yes but it will only matter for the vignetting. It should correct the
geometric distortion correctly as that will be the same whether you shoot
raw or jpeg. If one desires it is pretty easy to generate a lens profile
yourself using the profile creation tools Adobe provides.
It is, and if this doesn't work, I will probably go to that next stage.
OK, it worked. At first I didn't think it did, but despite the file name being Rokinon, it shows up under the Samyang group in Lightroom.
It does appear to correct the barrel distortion.
