No known changes in any Lightroom settings but in the past week the Adjustment Brush is nearly unusable. I click on "New" and set up initial parameters, use brush to make a mask, with or without the color overlay option checked. All is good. B it, if I move to the slider area to make a setting adjustment almost always the "Erase" option becomes highlighted. If I recheck either A or B and move back to the image the Erase function again becomes highlighted, the brush now contains a "-" and pressing the Option key does not make it change. No number of times rechecking on the A or B options will make one of these "stick." If I quit the adjustment brush and then go back to it I can sometimes restart work, but then if I go back to the slider are the same thing happens. Almost impossible to get any work done on an image. Quitting and restarting the program has not helped. Anyone else having the same problems or know what to do? Thanks.
Hi tomw,
We're really sorry for all the hassle. Please reset the Lightroom preferences back to defaults and let us know if that helps.
To know more about resetting Lightroom preferences, please refer to the following link: How to set Lightroom Classic CC preferences
Mohit
Hi tomw,
Mohit
Thanks...have tried the brush on a few images after the reset and seems to be working...Assume I must have changed something without even realizing it. Will write again if it stops behaving. Minor PITA reseting the preference changes I have made, but I'll live.
Great, thanks for the update.
Mohit
