I've just installed the latest version of LR 7.5 on a new computer, and I cannot access any of my downloaded presets.
When trying to access the location via Edit/Preferences/Presets instead of the regular option 'Show Lightroom Presets Folder', I can only see 'Show Lightroom Develop Presets' and 'Show all other Lightroom Presets'.
When I select the first option, it actually opens a pathway to Camera Raw, NOT Lightroom?
Can someone please advise how I go about fixing this and/or how I can add my presets for use?
Thankyou
Presets changed in Lightroom Classic 7.3
If Classic finds any presets in the old Develop Presets folder, it will copy them to the new location and convert the file format. As it wouldn't make sense to repeat this every time it opens, it also marks the converted preset's name with tildes as in "~~Sharpening - Fuji X-T2.lrtemplate".
As you are trying to load some old presets into Classic 7.5, follow the Other button and put them in the old Develop Presets folder, then restart LR. It will convert them to the new location.
Hi John,
Thankyou for your reply and information.
Unfortunately, I had already tried putting my .lrtemplate files in the old Develop folder location, restarting LR but none of the files have been moved or converted to the new location by LR. I also tried restarting the computer, but this also did nothing.
Is this something I can do manually myself to rectify the issue? Can the files be converted to .xml/.xmp files and placed in the new 'settings' folder?
BTW, I'm still running LR 7.4 on my old computer, and I'm having no issues accessing the presets there. They are still sitting in the following location:
c:\users\appdata\roaming\adobe\lightroom\develop presets
and they are lrtemplate files (that appear to have been converted by LR as they show ~~ at the front of their file name).
I've tried again to put these files into the old location and open LR but nothing is happening, no conversions are being done automatically as you advised?
Do the filenames have tildes?
The problem may be that you are trying to use files which have filenames including tildes - 7.3 or 7.4 would have added them when it converted the presets. On the new computer, remove the tildes from the filenames which you put in the old location.
Alternatively, on the old computer go to the location I mentioned above for 7.3. Copy those xmp files and put them in the new location on the new computer.
