I recently purchased a new MacBook Pro with Retina Screen.
I'm a designer and use Adobe Acrobat Pro often. Since I migrated to my new computer the Adobe Acrobat Program along with all my saved PDF files are blurry. I've gone through the forums to try and find a solution and nothing. Can someone help?
My Preferences read the following:
Hi stefaniet0709,
As Acrobat's interface and the pdf files are blurry on your Mac machine, could you check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and check.
Also, try the troubleshooting steps given in the following help document-
HiDPI, Retina display support | Adobe Acrobat, Reader
Acrobat XI Pro - Blurry text on MacBook Pro Retina display (Installation & updates)
Let us know if you need any help.
Shivam
Thank you Shivam, however, when I go to check for an update I get the following error:
Hi stefaniet0709,
Could you try performing the troubleshooting steps given in the help document given below:
Resolve connection errors with Adobe Creative Cloud and Creative Suite applications
Also, try downloading and installing the updates manually from this link: Adobe - Acrobat : For Macintosh, reboot the machine after installing the update.
Shivam
