SOLVED
how to replace @properties annotation in aem 6.4 using OSGi R6 annotations
Avatar
Level 2
import org.apache.felix.scr.annotations.Component;
import org.apache.felix.scr.annotations.Properties;
import org.apache.felix.scr.annotations.Property;
import org.apache.felix.scr.annotations.Reference;
import org.apache.felix.scr.annotations.Service
@Component(label="Myproject Service")
@Properties({
@Property(name = Constants.SERVICE_RANKING, intValue = 400, propertyPrivate = true),
@Property(name = "priority", intValue = 200)
@Service({Myservice.class})
The felix scr annotations in aem 6.2 is now replaced with OSGi R6 annotations. But  how to replace it ?
I have tried one method. Please do let me know is it correct and how to use "properties" in OSGI R6.
import org.osgi.service.component.annotations.Reference;
import org.osgi.service.component.annotations.Component;
import org.osgi.service.metatype.annotations.AttributeDefinition;
import org.osgi.service.metatype.annotations.ObjectClassDefinition;
@Component(service=Myservice.class,immediate = true,name="Myproject Service",
property = {"Constants.SERVICE_RANKING="+"400","priority="+"200"  })
Is this correct ?
and how to use properties label in OSGi R6 ?
1 Accepted Solution
Avatar
Correct answer by
Employee
Avatar
Level 2
Thanks @Arun patidar
But I have already gone through the documents but it doesn't contain @properties solution.
Avatar
Community Advisor
YOU can do like below:
No need to put properties in quotes.
@Component(service = MyService.class, immediate = true, property = {
Constants.SERVICE_RANKING + "=400",
"priority=200"
Arun Patidar
Avatar
Level 2
Thanks @arun patidar
@Service
@Component(metatype = true, immediate = true, label = "Content Insights Page Name Provider", description = "Service to use custom content insights page name variable")
@Properties({
@Property(name = Constants.SERVICE_DESCRIPTION, value = "Content Insights Page Name Resolver implementation"),
@Property(name = Constants.SERVICE_RANKING, intValue = 200, propertyPrivate = false),
@Property(name = "basePath", value = "/content/myproject/language-masters/en", description="The path to be removed from Content Insights URL", label="basePath"),
@Property(name = "blogBasePath", value = "/content/myproject-blog/en", description="The path to be removed from Content Insights URL for Blogs", label="blogBasePath"),
@Property(name = "cqVarContentInsight", value = "pagedata.path", description="The CQ variable used for Content Insights URL", label="cqVarContentInsight"),
@Property(name = "langBasePath", value = "/content/myproject/language-masters", description="The path to be removed from Content Insights URL", label="langBasePath")})
Could you please help me in this ?
Avatar
Level 8
You can use OCD Attribute definitions to convert this into OSGI
EX :
@AttributeDefinition(name = "Constants.SERVICE_DESCRIPTION", description = "Content Insights Page Name Resolver implementation")
String getDescription();
https://blog.osoco.de/2015/11/osgi-components-simply-simple-part-iii/
http://keysandstrokes.info/aem-code-snippets-osgi-annotations/
You need to follow below apprach if you want to convert as it is something like adding Prorperty = { key=value,key=value }
Ex :
, Property = { Constants.SERVICE_DESCRIPTION  = "Content Insights Page Name Resolver implementation",
Constants.SERVICE_RANKING, intValue = 200, propertyPrivate = false }
@AttributeDefinition(name = "Feed Url", description = "Feed Url")
String feedUrl();
Avatar
Level 2
But for this I have to declare the new variable ? isn't it ?
Avatar
Level 8
Yes,  you need to declare new variables on top of it add AttributeDefinitions and you need to same variables name which were defined earlier
Avatar
Correct answer by
Employee
