Timeline not selectable
Oct 10, 2018 Oct 10, 2018
hello. i tried to import footage that i had already worked with in premiere into my current project. However, when I import it, in the timeline there is no sequence. Here is a video: Well it won't let me upload footage to this. Basically, I import it (I also tried legacy titles), and it doesn't create a sequence in the timeline. But when I go into my project (Project:2018 camping trip, it says), the sequence is there. Then, I try to drag in into the timeline. it works, but the timeline is unselectable(can't scrub, select clips, etc).please help. here is my computer info:
OS Name Microsoft Windows 10 Home
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name LAPTOP-H32O60IK
System Manufacturer HP
System Model HP Laptop 15-bs0xx
System Type x64-based PC
System SKU 1TJ82UA#ABA
Processor Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz, 2701 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date Insyde F.24, 9/25/2017
SMBIOS Version 3.0
Embedded Controller Version 23.40
BIOS Mode UEFI
BaseBoard Manufacturer HP
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.17134.285"
User Name LAPTOP-H32O60IK\paral
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.92 GB
Available Physical Memory 2.78 GB
Total Virtual Memory 11.9 GB
Available Virtual Memory 5.42 GB
Page File Space 4.02 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
761
Enthusiast ,
Oct 11, 2018 Oct 11, 2018
It sounds like you did a screen capture movie to show the problem, any chance you can upload to Vimeo, Youtube etc and insert a link to that in the chat here?
To explain some of your questions:
- when you import footage into Premiere it doesn't create a sequence. It just imports footage, that's it. You need to create sequence yourself
- if you open an exisiting Premiere project then there may be a sequence in there if you created one in the past
-as to the problem with Timeline, did you try resetting Premiere?
Adobe Community Expert
Adobe Certified Professional
Yes, I created a sequence. It still doesn't work. actually, it's the playhead that's not selectable.
Enthusiast ,
Oct 12, 2018 Oct 12, 2018
Thanks,  I did notice after your title clip drag that the timeline does not activate/focus when you attempt to drag the playhead but notice your playhead in the Program Monitor moves.
Could you attempt after dragging the title clip to simply click the timeline -- anyway blank --  or type Shift 3 and get the focus on the timeline before trying to drag the playhead.  I know you should not have to do this but it would be interesting to see if it works because when you maximise/undock the timeline it works because the focus is on that panel
Enthusiast ,
Actually the timeline should focus because of the drag & drop and not because you attempt to move the Playhead.  Nevertheless try pressing Shift 3 after the drag and drop and before you scrub the playhead
That is odd. When you take Timeline into fullscreen mode it works but when set back to default it doesn't..
And, as you were moving playhead in Timeline (or actually trying to move it), it was actually moving in Program Monitor...
Update your graphics card driver: looks like a redraw issue of the UI.
Also note your laptop is but 2 core.
Test with actual footage and not the titler which is beginning to get obsolete.
Nov 04, 2018 Nov 04, 2018
tried with the same footage a while later. It worked! I didn't have to do anything. Thanks for helping. Anyway, I tried to load the news graphic in, and there was a red line above it. When I play that 1 section, it lags alot. Can I render this so it doesn't lag or something?
