      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
convert rectangle shape to triangle
Oct 11, 2018 Oct 11, 2018
rectangle shape> restrize layer> polygonal lasso tool to cut the rectangle but now i cannot change the color of this triangle..... is there a way to change this color or to make this triangle another way in photoshop? i use this in a business card
2.9K
Community Expert , Oct 11, 2018 Oct 11, 2018
Use Pen tool to draw triangle shape. Watch the animation below. Turn Rubber Band on (click on gear icon in the Options bar to see this option in a pop-up) to watch and ensure that you are drawing perfectly straight line. Note: my drawing mode (first drop-down in the Options bar) was set to Path.
Adobe
With the Direct Selection tool (the white arrow), click on the lower left corner, to select that point, and press Delete. You will get a message about converting a Live Shape to a regular path. Click Yes to proceed.
Switch to the Pen tool, and click on one of the two acute angles, and then the other, to connect the two points. You will see "Pick-up Path" and "Close Path" added in the History panel. Now your Shape is a triangle.
Oct 12, 2018 Oct 12, 2018
first part understand,,,second part not
first you select pen tool-path mode>draw a triangle>click shape to convert it to "shape"  >then select direct selection tool........................ thanks a lot...
Guest
Hi
You could also create the triangle from the custom shape tool
Hi in shapes use polygon tool and click on artboard you got the option for how many sides you want you can make triangle with choosing 3 sides...thanks
Ali Sajjad / Graphic Design Trainer / Freelancer / Adobe Certified Professional
