It would be most helpful to hear from somebody who actually
did it which steps are exactly necessary. The project is Russian,
and I would need to view the output in Rusian.
If I set the project settings and the local system language
to Russian (language setting in the HPP is 0x419), then I can
produce a CHM and all HTML pages are fine, but..
* The window title is scrambled text, perhaps an ANSI
conversion of the Russian unicode title. In the HHP file, the title
is displayed correctly as it should be.
* The index shows the same problem in the CHM, but is already
produced with wrong characters by RoboHelp.
* The TOC on the other side if fine too.
I feel that it may be only a small step left, but I find no
more options.Releated issues were covered in several previous
posts, but none of the suggestions I found solved the
problem.
