2 Replies Latest reply on Oct 12, 2018 6:57 PM by hericdehon
    Adding object, table and cell styles to CC Libraries
    hericdehon Level 1
      Is it possible to add Object, Table and Cell styles to CC Libraries?
      Why that "cloud+arrow" icon doesn't apear in pannels? Am I doing something wrong?
        • 1. Re: Adding object, table and cell styles to CC Libraries
          Steve Werner Adobe Community Professional & MVP
          Those attributes cannot be directly added to CC Libraries. They are only used in InDesign.
          However, if you select objects in an InDesign file, and drag them to a CC library, you create a "Graphic." It is saved in two formats: (1) It save an InDesign snippet. If you drag the graphic to another InDesign file, the snippet will "reconstitute" itself into the same InDesign objects.
          The InDesign "graphic" is also saved as a PDF file which can be viewed and printed in another application (e.g., Illustrator).
          Original file with Object Style:
          I dragged the frame to the Graphics Test CC Library. Click on the menu under the + icon and choose Graphics to pick the right attributes to copy
          Then I dragged it into a new file (shown below):
          1 person found this helpful
